Old 02-11-2008, 08:02   #1 (permalink)
Registered User
Member: 582565
Thanks Meter: 81
Thumbs down 1208 insert sim
nokia 1208 RH-105 insert sim card problem please help me only working in 32k sim card not accepted to 16k i flash with latest ver: but same i change simcard IC & make jumper connection.still same problem please help me.
The Following User Says Thank You to sajithcellular For This Useful Post:
Old 02-11-2008, 08:35   #2 (permalink)
Member: 238712
Thanks Meter: 28
1200 sim ways
please chack this for 1200 insert sim.
The Following 14 Users Say Thank You to malikgr8 For This Useful Post:
Old 02-11-2008, 12:27   #3 (permalink)
sunnyarora's Avatar
Member: 483406
Thanks Meter: 179
its good yaar its really help full
Old 03-05-2008, 03:17   #4 (permalink)
vikas kumar's Avatar
Member: 632765
Thanks Meter: 82
thanks for sharing..................
Old 05-09-2008, 06:28   #5 (permalink)
mkg
Member: 302804
Thanks Meter: 7
yes i have made jumpers and these two points are showing short, does that mean it cannot be corrected for insert sim problem? can we do something else?
Old 05-15-2008, 14:21   #6 (permalink)
zahid_mobile's Avatar
Member: 203615
Thanks Meter: 52
hi friends
i have the nokia 1208 in the which insert sim problem its different .when on the set show ok and working well 1or 2mints after it go to the insert sim for 2or3 seconds then its working sam all time i have used the different ways but not solve.
1 change the crystal ic
2 wash the complete bord 3 times but not solve
plz help with thanks
zahid.
Old 05-15-2008, 17:10   #7 (permalink)
Member: 764716
Sonork: GsmdunyasiTeam®™
Thanks Meter: 52
Thank You...............
Old 06-23-2008, 08:40   #8 (permalink)
Member: 778895
can u explain this coz its not workin for me i make jumpers as same wot to do next
The Following User Says Thank You to lasertech786 For This Useful Post:
Old 09-15-2008, 11:15   #9 (permalink)
Member: 276060
Thanks Meter: 9
Originally Posted by zahid_mobile View Post
hi friends
zahid.
i have the same probleme any solution plz
Old 09-15-2008, 12:30   #10 (permalink)
amol_sm's Avatar
Member: 343326
Thanks Meter: 1,463
Simply Change the Sim IC.
Post result.
Old 10-22-2008, 08:59   #11 (permalink)
Member: 718186
Thanks Meter: 14
hi i change sim ic but same problem
Old 10-22-2008, 09:07   #12 (permalink)
seeruz's Avatar
Member: 860623
Thanks Meter: 65
If you did ic jumpers. So check Vsim 1.8/3v. (c2701,c2700,c2916). in the end reball UEM it will works 100%. Sometimes after 2-3 minuts "Insert Sim" than try change battary. Check BSI ways. There is no enough ideas man. Good luck.
Old 10-22-2008, 09:16   #13 (permalink)
Member: 601984
Thanks Meter: 445
good work bro nice soulution tested by me !
Old 10-22-2008, 09:19   #14 (permalink)
Registered User
Member: 688907
Thanks Meter: 509
good work.....................................
Old 06-01-2009, 19:06   #15 (permalink)
Member: 679088
Thanks Meter: 3
plz send orignel picture sim jumper plz
The Following User Says Thank You to waseekpl For This Useful Post:
nokia 1208 insert sim problem naeem mustafa Nokia Hardware & Hardware Repair 19 04-09-2013 14:14
Nokia 1200,1208 Insert sim solution Shakeel_pattoki Nokia Hardware & Hardware Repair 2 11-01-2012 13:01
1208 insert sim vikas kumar Nokia Hardware & Hardware Repair 14 07-25-2009 13:55
1208 insert sim ok mahamad ali Nokia Hardware & Hardware Repair 1 10-25-2008 05:34
1208 insert sim problem gsm-fault Nokia Hardware & Hardware Repair 6 09-05-2008 13:11
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.43227 seconds with 9 queries
Content Relevant URLs by vBSEO
