Old 04-24-2011, 00:18   #1 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,112
..::1280 dead any solution::..
i got this phone in dead condition
not a dropped phone not water damage
set suddenly dead
i flash with latest version but still no power
also change lcd
VBATT OFF...
VBATT ON
Setting VBATT Done!...
Booting Phone...
CPU ID Response: A200341100
CPU Type: XG110 2.1B
Phone Booted at after First attempt...
TIME STARTS HERE
Sending PBL 37888 bytes...
PBL Successfully Sent...
Sending SBL 65024 bytes...
SBL Successfully Sent...
Flash Chip Manufacturer: Samsung Electronics Corp.
Flash Chip Type: K8S6415ETC 64 Mbit (4Mb x 16) NOR
Extended Information: Multiple Bank / Burst / 1.8v
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm647_006.200
FIRMWARE Image Found...
Number of Sections: 03
FIRMWARE Certificate Block Sent Successfully...
Processing Section 01 of 03
FIRMWARE Erase Block: 0x00800000~0x00A0FFFE
Start Erasing...
Erasing Please Wait...
Block Erase Done...
Preparing Data Blocks...
Data Size: 2162688 bytes
Data Checksum: 0E71
Uploading Data Blocks to phone...
FIRMWARE Data Blocks uploaded to phone...
Processing Section 02 of 03
FIRMWARE Erase Block: 0x00C60000~0x00EAFFFE
Start Erasing...
Block Erase Done...
Data Size: 2020800 bytes
Data Checksum: 0C57
Processing Section 03 of 03
FIRMWARE Erase Block: 0x00FFC000~0x00FFFFFE
Start Erasing...
Block Erase Done...
Data Size: 64 bytes
Data Checksum: 0000
Start Data Verification... (Please wait)
Data Verification Successful...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm647_006.20aa
PPM Image Found...
Number of Sections: 01
PPM Certificate Block Sent Successfully...
Processing Section 01 of 01
PPM Erase Block: 0x00210000~0x0039D37E
Start Erasing...
Block Erase Done...
Data Size: 1627008 bytes
Data Checksum: E884
PPM Data Blocks uploaded to phone...
Processing Image File: C:\Program Files\Nokia\Phoenix\Products\RM-647\rm6470_nai06.20aa
CONTENT Image Found...
CONTENT Certificate Block Sent Successfully...
CONTENT Erase Block: 0x00EB0000~0x00F0793E
Start Erasing...
Block Erase Done...
Data Size: 358720 bytes
Data Checksum: B1D0
CONTENT Data Blocks uploaded to phone...
Exit Flash Mode Done...
Time Elapse : 00:02:20
You must Factory Reset the phone to enable the
ringtones and other customized settings to work
Waiting For Phone to go Online...
5, 4, 3, 2, 1...
ERROR : PHONE READ INFO FAILED
i try these ways
but still same
try flashing with atf and mxkey
flashing complete but ui failed
when connect to power supply and press power key set take power and needle continuously shaking but set not power on
Old 04-24-2011, 07:21   #2 (permalink)
chipset experts's Avatar
Member: 1312914
Thanks Meter: 111
first check display.....very few chances of display problem in ur case acc to log... but first check it ....
if not solve then rehot cpu ...
post result....
Old 04-25-2011, 13:06   #3 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,112
already reball cpu and flash ic.........................
Old 04-25-2011, 13:10   #4 (permalink)
..::Gsmideazone::..'s Avatar
Member: 936020
Sonork: 100.1611462
Thanks Meter: 1,168
just cheak battary connector middle point.that means bsi
Old 04-25-2011, 13:14   #5 (permalink)
HUM
HUM's Avatar
Member: 161728
Sonork: 100.1582708
Thanks Meter: 2,112
bsi print ok.....................
Old 09-05-2011, 09:11   #6 (permalink)
anshadad's Avatar
Member: 626027
Sonork: 100.1645764
Thanks Meter: 95
change display...............
Old 09-05-2011, 10:43   #7 (permalink)
Member: 1342188
Sonork: 100.1607654
Thanks Meter: 127
remove charging connector and flash again tested solution
Old 09-05-2011, 16:18   #8 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 374
change 26mhz will be ok post result back
Old 09-05-2011, 16:23   #9 (permalink)
vignesharmy55's Avatar
Member: 1531954
Sonork: 100.1619337
Thanks Meter: 286
http://www.google.co.in/imgres?q=128...1t:429,r:0,s:0
Old 09-05-2011, 16:58   #10 (permalink)
ankit9090117706's Avatar
Member: 1291109
Sonork: 100.1607039
Thanks Meter: 17
cheak display
then cheak bsi line
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-27-2015 11:57
any keyboard button turns off phone? achie Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 10-26-2014 14:45
6150 V5.20 WANTED --- DEAD OR ALIVE --- IT'S BETTER ALIVE ! ;))) tcamilo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 12-19-1999 21:30
Does any one know how to program the ESN number with nokia 6120? Bert Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-02-1999 09:45
I CAN UNLOCK 1,2,3,4 FOR ANY PHONE 40 (1+) -- 30 (20+) andrew bennett Main Sales Section 1 07-26-1999 19:33
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.29006 seconds with 8 queries
Content Relevant URLs by vBSEO
