Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 10-15-2008, 23:52   #1 (permalink)
dragosgsm's Avatar
Member: 148032
Question 6120 keypad IC location???
I have a Nokia 6120 that has some keys that are not working and it's not the keypad flex the problem...Can someone locate and point me where is the keypad galss IC located on this phone?
A picture would be apreciated,
Thank you in advance!!!!!!!
The Following 2 Users Say Thank You to dragosgsm For This Useful Post:
Old 10-16-2008, 01:38   #2 (permalink)
azez.sd's Avatar
Member: 735523
Sonork: 100.1591830
hi
1st clean the bord and try to reball the keybad ic
see the photo
The Following 33 Users Say Thank You to azez.sd For This Useful Post:
Old 10-17-2008, 13:49   #3 (permalink)
dragosgsm's Avatar
Member: 148032
Thank you man,I had changed the Keypad IC pointed there and still the same:all the keys are working except when I press menu it appears # when I press 3 it deletes the entrys and soo on with other 2 keys...
What to do???????
Old 10-19-2008, 09:06   #4 (permalink)
basilbaby's Avatar
Member: 263709
What to do???????
i am also having the same problem.. any solution??
Old 10-19-2008, 09:13   #5 (permalink)
kidgz's Avatar
Member: 551599
try to chechk it again may be
bad contact on keypad ic
Old 10-19-2008, 09:20   #6 (permalink)
seeruz's Avatar
Member: 860623
yes its right. may be bad contacts
Old 10-19-2008, 09:21   #7 (permalink)
janar_jk's Avatar
Member: 154612
What to do???????
Intresting, but thisphone have two keypad ic`s i attach here pic. If not ic problem then it might come from rapido or change ui assy, maybe there is something shorted.
BR Janar
The Following 8 Users Say Thank You to janar_jk For This Useful Post:
Old 10-19-2008, 09:31   #8 (permalink)
basilbaby's Avatar
Member: 263709
6120 keypad solution
Problem solved by......
The Following 12 Users Say Thank You to basilbaby For This Useful Post:
Old 04-15-2009, 23:19   #9 (permalink)
Member: 483133
nice replay teasted 100%
Old 06-15-2009, 12:25   #10 (permalink)
Member: 478331
i have a problm in nokia 6120 all key pad not work.stuck all key,s....plz plz help me
Old 06-15-2009, 12:49   #11 (permalink)
Member: 478331
Old 07-29-2009, 19:34   #12 (permalink)
Member: 655012
i change both kp ic but problem is same menu ok 1 2 3 key not work plz help me
Old 07-29-2009, 20:55   #13 (permalink)
Member: 196876
Sonork: sabugsm
change ur front keypad panel its coming ok ...
Old 07-29-2009, 21:05   #14 (permalink)
Member: 196876
Sonork: sabugsm
sir ,how can uplord image and rar ? can u help me
Old 07-29-2009, 21:22   #15 (permalink)
usi_golden's Avatar
Member: 506993
Sonork: 100.1580692
first clean and reball the 2 keypad ic and replace it.
working 100% and tested by me.
The Following 2 Users Say Thank You to usi_golden For This Useful Post:
New Keypad Ic Jumper For 6120,6300,N76.... Jeffyoh88 Nokia Hardware & Hardware-Repair Area 6 10-31-2012 08:14
Need 6120 Zocus ic location? sharaz191 Nokia Hardware & Hardware-Repair Area 1 03-28-2008 15:00
SE keypad IC = Nokia keypad IC??? ryumahon Sony Ericsson Hardware Repair Area 22 03-22-2007 09:26
SE keypad IC = Nokia keypad IC??? ryumahon Sony Ericsson Hardware Repair Area 0 01-15-2006 15:40
Where is A800 eeprom ic located?where the located? External hooi76 VLSI, Conexant, Skyworks and Old Models 2 03-03-2005 13:47
Page generated in 0.42314 seconds with 12 queries
Content Relevant URLs by vBSEO
