Unlock Server
Old 07-25-2010, 19:29   #1 (permalink)
Member: 411831
Thanks Meter: 215
Amazing charging problem in N97.....
hi
i have a N97 charging problem.is that if i remove charger, it continous show charging icon. also glowing charging indiacator. i change betty ic but same.
what can be that problem? Any body can help me out?
thank you.
br.
msantar.
Old 07-25-2010, 20:32   #2 (permalink)
Member: 1272012
Thanks Meter: 7
first clean you borad
if not ok change betty IC 100% ok
tested by me
Old 07-25-2010, 21:47   #3 (permalink)
Member: 39208
Thanks Meter: 144
yes betty problem in most cases!
Thank You
Byte
Cheap Hosting
Web Hosting Services, Reseller Hosting, and Dedicated Servers by HostGator
The Following User Says Thank You to Byte For This Useful Post:
Old 07-26-2010, 06:04   #4 (permalink)
Member: 411831
Thanks Meter: 215
@GSMDoctors
@Byte
I CHANGE ALREADY 3 TIMES BETTY IC. BUT SAME.
Old 08-08-2010, 15:21   #5 (permalink)
Member: 418713
Thanks Meter: 9
where is betty ic in the mobile show an picture
Old 08-08-2010, 15:29   #6 (permalink)
GSMTURBO's Avatar
Member: 479496
Sonork: 1592751
Thanks Meter: 374
dear use org changer tested many time no need to change betty ic
Originally Posted by msantar View Post
hi
thank you.
br.
msantar.
Old 08-08-2010, 15:35   #7 (permalink)
ANILMPLY's Avatar
Member: 1268409
Thanks Meter: 57
Dear bro,
you alredy changed betty..ok...then you change (n3350)..this ic coming in under the sim socket.....goodluck..............
The Following User Says Thank You to ANILMPLY For This Useful Post:
Old 09-06-2010, 10:42   #8 (permalink)
Member: 1268761
Thanks Meter: 2
hello brother
i have got n97 with charging problem , i soldered the charging port and now its charging fine but whenever i make a call battery logo comes on the screen n fone turns off after sometime where as the battery is fully charged.
one time it charging bar started moving and charging light turned on.
kindly help me ....
thanks
The Following User Says Thank You to Mirza Majid G For This Useful Post:
Old 09-06-2010, 10:43   #9 (permalink)
Member: 1268761
Thanks Meter: 2
hello brother
i have got n97 with charging problem , i soldered the charging port and now its charging fine but whenever i make a call battery low logo comes on the screen n fone turns off after sometime where as the battery is fully charged.
kindly help me ....
thanks
Old 05-28-2011, 15:24   #10 (permalink)
Member: 675260
Thanks Meter: 27
Charger House placebo n97
change ic d3300 and give me result
Old 05-29-2011, 09:50   #11 (permalink)
nauman g's Avatar
Member: 459065
Thanks Meter: 466
hi
thank you.
br.
msantar.
bro just rehot avilma {power ic}
1000% ok
or
replace avilma
{power ic}
post result
Old 10-03-2011, 07:16   #12 (permalink)
Registered User
Member: 151590
Thanks Meter: 12
pls remove nonsense posting
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 15:21
Lock 2 in nokia 51xx/61xx Pablo Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-31-1999 04:35
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 00:44
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.40811 seconds with 8 queries
Content Relevant URLs by vBSEO
