Unlock Server
Old 11-01-2005, 10:35   #1 (permalink)
pawaa's Avatar
Member: 55631
Thanks Meter: 55
-= Band Convert Nokia 6101B/6102 to 6101 =-
Software Modification
No software modification is required because 6101b is already tri-band (850&900/1800/1900) but if you want then you can simply flash it with RM-76 Data Package.
Hardware Modification
A self explainer picture is attached but if you are unable to understand then consider following lines a short description.
2 network filters (Rx & Tx) are needed to be replaced with proper filters which can be taken from any damaged 6230 or similar phone or you can redirect them using a capacitor, for batter performance you can try different values.
[PaWaa]
The Following 3 Users Say Thank You to pawaa For This Useful Post:
Old 11-03-2005, 21:46   #2 (permalink)
wynasoft1's Avatar
Member: 101769
Sonork: 100.95669
Thanks Meter: 65
do you have 6101 rm76 pm please share.
regards
The Following User Says Thank You to wynasoft1 For This Useful Post:
Old 11-04-2005, 16:38   #3 (permalink)
pawaa's Avatar
Member: 55631
Thanks Meter: 55
regards
Download the attached file and remove .txt from its end.
[PaWaa]
The Following 2 Users Say Thank You to pawaa For This Useful Post:
Old 11-04-2005, 16:53   #4 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 86
Interesting, why nokia started puting this info in theyr service manuals
B.R.
Alkapone
Old 11-04-2005, 17:29   #5 (permalink)
pawaa's Avatar
Member: 55631
Thanks Meter: 55
B.R.
Alkapone
those pictures are taken from service manual but are edited and i added some information on these pictures ... ******8**
[PaWaa]
NO INSULTS
Old 11-04-2005, 17:36   #6 (permalink)
wynasoft1's Avatar
Member: 101769
Sonork: 100.95669
Thanks Meter: 65
thak you man im gong to check.
best regards
Old 11-06-2005, 13:08   #7 (permalink)
ReyTech's Avatar
Member: 135945
Thanks Meter: 65
[PaWaa]
@Pawaa
Thanks for the info! its very useful, but needed to know if we can use any value capacitor?
WBR
ReyTech.
The Following User Says Thank You to ReyTech For This Useful Post:
Old 11-06-2005, 13:20   #8 (permalink)
Member: 42165
Thanks Meter: 33
and what should be the capacitor type to be used and its value??? I really appreciate this info you shared to us...
THANK YOU VERY MUCH
The Following User Says Thank You to Abelardz23 For This Useful Post:
Old 11-10-2005, 04:51   #9 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 113
[PaWaa]
the MCU does support both 850 and 900 so no need flash but u still need to write PM from a 900/1800/1900 phone, since phone is tuned to 850 MHz otherwise no network or weak network.. and this is tested !
WBR
Syed
Old 11-10-2005, 07:53   #10 (permalink)
Alkapone's Avatar
Member: 19265
Thanks Meter: 86
@Pawaa
Dont be angry, and I dont want to say, that info you posted is not valued. It's ok, just my question, what from that info for nokia, why they started putting that kind of info.
p.s. I was smart enaught to find that info ~1 month till you posted, and understood withot sm 'modifications' ... no need to be insulting.
B.R.
Alkapone
Old 11-10-2005, 19:38   #11 (permalink)
pawaa's Avatar
Member: 55631
Thanks Meter: 55
@Pawaa
B.R.
Alkapone
Apology!!! have a good time around.
[PaWaa]
Old 11-14-2005, 19:39   #12 (permalink)
Member: 5778
Thanks Meter: 10
thanks .. but ist it hardware or software modification !!???????
please ??????????????????
Old 11-15-2005, 09:37   #13 (permalink)
ReyTech's Avatar
Member: 135945
Thanks Meter: 65
WBR
Syed
@syed
Then u mean to say that no need the hardware modification as well? and if hardware modification is necessary then can we use the jump thru capacitors as we do in 1100? and can u pls inform how is it to be jumped? like in 1100 "last contact to the center contact" & in 6101 how is it? or is it same?
WBR
ReyTEch.
Old 11-15-2005, 10:55   #14 (permalink)
pawaa's Avatar
Member: 55631
Thanks Meter: 55
Originally Posted by ReyTech
@syed
WBR
ReyTEch.
Hardware modification is the most importent thing, you can skipp software modification. you can use jump through capacitors exectly like 1100.
What every i posted is based on experiances.
[PaWaa]
Old 11-15-2005, 13:59   #15 (permalink)
Syed's Avatar
Member: 19979
Thanks Meter: 113
yes u can use capacitors.. but will have problems in network sometimes... so better to use proper filters
u can skip flashing but still need to write PM !!
WBR
Syed
convert 6102 to 6101 900MHz reaz.com Nokia Hardware & Hardware Repair 28 04-20-2012 09:18
how to convert nokia 2115 1900mzh to 800mzh victor2006 Nokia CDMA 2 05-31-2009 07:30
Need to convert nokia 1200 rh99 to nokia 1200 rh 100 krich70 Nokia Digital Core Technology 4 ( DCT-4 ) 0 05-23-2009 00:47
no network nokia 6101b wanna to change 6101 tarey888 Nokia Hardware & Hardware Repair 0 10-30-2006 10:07
nokia 6101b refuse to sent message help me maxheadquarters Nokia Hardware & Hardware Repair 0 03-29-2006 22:59
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.45142 seconds with 9 queries
Content Relevant URLs by vBSEO
