Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 04-08-2010, 19:19   #1 (permalink)
JASKY007's Avatar
Member: 1125280
E52 charging solution 100% tested
i have e52 charging not show,but recognize if you plug in usb..
first i try to check charging terminal but working fine i check this
its shorted...
i change pearl ic or power ic same problem
i tryied to search here but no solution
this is your solution
you can take it in n70 check in schematic c2012
press thanks botton please...
The Following 96 Users Say Thank You to JASKY007 For This Useful Post:
Old 04-22-2010, 19:33   #2 (permalink)
Member: 757333
Good solution !!!
I`m tested this solution, phone repaired. Capacitor value is 1u0. Thanks.
The Following 4 Users Say Thank You to riplowski222 For This Useful Post:
Old 04-26-2010, 14:51   #3 (permalink)
Member: 798921
pls help 7510a sharger not support?????????????????????????????????
The Following User Says Thank You to nabilvt For This Useful Post:
Old 05-10-2010, 12:03   #4 (permalink)
3OG
3OG's Avatar
Member: 230904
Works!
Very good finding Thanx
The Following 2 Users Say Thank You to 3OG For This Useful Post:
Old 05-21-2010, 03:53   #5 (permalink)
Member: 114322
Charger now ok, tq bro. but usb still not detect
The Following 4 Users Say Thank You to McFeter For This Useful Post:
Old 05-25-2010, 11:00   #6 (permalink)
Member: 347023
gooooooooood thank you
The Following 2 Users Say Thank You to sira For This Useful Post:
Old 06-05-2010, 17:05   #7 (permalink)
Member: 225353
super work thanix so much sir
The Following User Says Thank You to anoskrdi For This Useful Post:
Old 07-07-2010, 13:56   #8 (permalink)
servtelgsm's Avatar
Member: 44038
thank you,good job!!
Old 07-24-2010, 21:12   #9 (permalink)
nelsky_1974's Avatar
Member: 1352482
thank you sir!!! good work!! keep it up!!!
The Following User Says Thank You to nelsky_1974 For This Useful Post:
Old 07-24-2010, 21:35   #10 (permalink)
Member: 39208
good job
Thank You
Byte
Cheap Hosting
Web Hosting Services, Reseller Hosting, and Dedicated Servers by HostGator
The Following User Says Thank You to Byte For This Useful Post:
Old 07-26-2010, 16:41   #11 (permalink)
Member: 104004
tested!100% good solution!thanck you
The Following 2 Users Say Thank You to nicollasgsm For This Useful Post:
Old 08-25-2010, 23:22   #12 (permalink)
Member: 1338457
its ok ............................tested
The Following 2 Users Say Thank You to sajna abu For This Useful Post:
Old 08-26-2010, 04:24   #13 (permalink)
Member: 1083123
Sonork: 100.1594766
The Following 4 Users Say Thank You to monu_bd123 For This Useful Post:
Old 08-26-2010, 04:31   #14 (permalink)
iyhan boy's Avatar
Member: 1290467
Sonork: Garuda Di Dadaku
Thanks alot...........
The Following 3 Users Say Thank You to iyhan boy For This Useful Post:
Old 08-31-2010, 13:01   #15 (permalink)
Member: 1128
Yes, for me work too. I havn't short in usb. But when plug charger, on display there is battery but not filling it.
I change capacitor and all OK. Bravo for JASKY007.
The Following User Says Thank You to Sandino For This Useful Post:
Nokia N81 Keypad solution 100% Tested solution Here gsmhosting Nokia Hardware & Hardware-Repair Area 29 09-25-2012 09:11
1202-1203-1661-1662 not charging test mode and local mode solution 100% tested /\/\A/\/| Nokia Hardware & Hardware-Repair Area 14 07-11-2011 05:49
nokia 1110 1112 1600 2310 6030 2610 charging ic jumper solution 100% test m zubair Nokia Hardware & Hardware-Repair Area 17 02-23-2011 09:03
Guru 100 (B100) Charging ways 100% Tested Nasir Mobiles Samsung Hardware Repair Area 4 03-20-2010 08:07
Auto charging solution 100% tested vvsory Nokia Hardware & Hardware-Repair Area 3 11-30-2009 09:20
Page generated in 0.87365 seconds with 12 queries
Content Relevant URLs by vBSEO
