Unlock Server
View Poll Results: Best new mobile phone
nokia n80 12 21.82%
nokia 8800 black(gold chrome) 10 18.18%
nokia n91 11 20.00%
sony w810 14 25.45%
samsung i300 1 1.82%
Other 7 12.73%
Voters: 55. You may not vote on this poll
Old 05-25-2006, 01:52   #1 (permalink)
Member: 205930
Post How to repair liquid damage mobile phones??
Does any one know how to fix repair liquid damage mobile phones??
as my uncle spills some tea coffe coke or other liquid on my or his phone every month or two now i have some new phones sitting at home that are damaged and today he don it again he has spilt his coffe on my 6680 so how do i fix it?????
if any one can help it would be great
Old 05-25-2006, 10:33   #2 (permalink)
Member: 279112
sir, open the unit. wash the main board with water and detergent using a anti static brush, rinse it then see if it already shines then **** dry it with a hair ****er. **** dry also the phone assembly cause it may be also wet then when sure its already dry, assemble it then check if it powers on, if not, then the program may have been damge already due to the spilled liquid. your gona have to flash the phone if thats the case. BR
Old 05-25-2006, 12:42   #3 (permalink)
Member: 279616
diagram of 3105
Sir,
please inform that nokia cdma diagram model number 3105 and give this models diagram, I have a speaker problem and link is opened. so how that problem solve.
Old 05-25-2006, 14:37   #4 (permalink)
nomi's Avatar
Member: 78440
Thanks Meter: 56
best option
the phones that u have already damaged are on your luck.but in feature when ever u buy any phone,go to any repairing lab,open it and camofladge it with any lubricant before your uncle wet it with any liqued
Old 05-26-2006, 18:42   #5 (permalink)
bauzito's Avatar
Member: 120120
Sonork: 100.1592092
Thanks Meter: 234
there is no miracle solution for waterdamage phones. it depends on a lot of things like if battery was to full, if is sea water or not,if the owner try to put on charge before clean it,etc. for my experience i say the chances are 50%
Old 06-30-2006, 11:34   #6 (permalink)
az cells's Avatar
Member: 115516
Thanks Meter: 111
3105
Originally Posted by abbas bharmel
Sir,
check service manual
shaan
http://rapidshare.de/files/23556796/...anual.zip.html
Old 07-01-2006, 11:59   #7 (permalink)
Member: 115570
Thanks Meter: 5
tell me, how to repair a crashed car
in all case, first you have to clean PCB,
in the second part you have to search the damages,
in the third part you have to repair it
Old 07-05-2006, 06:26   #8 (permalink)
Member: 17623
Thanks Meter: 79
get the liquid use for clining clock parts dip the board for 2hrs in it then clean it by petrol n enjoy
Old 07-06-2006, 01:45   #9 (permalink)
.::MoBiLeDoC::.'s Avatar
Member: 136823
Thanks Meter: 50
The best way to TRY and fix a liquid damage phone is:-
1) Use hard brissle toothbrush to clean of dried corrosion.
2) Use a fibre pen to clean stubborn corrosion
3) Use ultra-sonic bath with ultra-wash liquid for 20 mins.
4) Rinse board in alchohol/white spirits.
5) Use flux and reflow with hot air gun the board properly.
6) Wait for borad to cool then use flux cleaner.
All also depends on the faults that the phone has. Use this method for reallly sever liquid damaged phones.
Hope it helps
MRL
Old 07-07-2006, 15:42   #10 (permalink)
Member: 8112
Hope it helps
MRL
yes , 2-3 hours hard work , but after 2-3 days phone back "not charging,
not mic, not earph , not power ON ....... "
liquid damages phones - dead phones - 90%
buy new ...........
Old 07-07-2006, 16:18   #11 (permalink)
coolmax's Avatar
Member: 157118
Thanks Meter: 156
bruv the best way to repair liqiud damage fones is to change your uncle...
Old 07-15-2006, 11:57   #12 (permalink)
Member: 136823
Thanks Meter: 50
buy new ...........
As we all know there is no guarantee that the phone will work but...
IT IS BETTER TO TRY AND THEN FAIL
THAN TO HAVE FAILED TO TRY
So just give it a try..esp if it is an expensive phone AND it is YOURS
Old 07-22-2006, 16:27   #13 (permalink)
needi's Avatar
Member: 18303
Thanks Meter: 3
With some more liquid ...but diferent ones.Sometimes works ....sometimes not.
Old 07-22-2006, 20:50   #14 (permalink)
moienshah's Avatar
Member: 258749
Thanks Meter: 10
Lightbulb use ctc
Every liquid damage mobile fone should be repaired by CTC(Carbon Tetra Chloride) .Then dry it with hot air gun.
Old 07-23-2006, 08:41   #15 (permalink)
Member: 303799
Sonork: inside outside
Thanks Meter: 59
dilute the board to a lacquer thiner..then remove it..dry it..until normal temperature regained
How to Repair a Dead Mobile Phone akram855 Various CDMA/TDMA Cell Phones 19 05-23-2015 13:52
How to Repair a Dead Mobile Phone akram855 Nokia Hardware & Hardware Repair 3 01-11-2010 13:16
How to repair V360 damaged by other tool Bi0H4z4rD Smart-Clip 3 08-11-2008 09:11
infitiny team, how to repair port damaged satcomhedi Infinity-Box 2 07-21-2008 16:13
how to repair box damaged smcu andres.erigure Universalbox 3 06-18-2007 13:11
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.53619 seconds with 9 queries
Content Relevant URLs by vBSEO
