ZZ KEY
Old 11-16-2004, 07:49   #1 (permalink)
Member: 84278
Thanks Meter: 22
Memory Card Forgotten Unlock Code
Pls Help Me How To Reset Unlock Code Of Memory Card Of Nokia 6600.
The Following 10 Users Say Thank You to rovick For This Useful Post:
Old 11-16-2004, 08:03   #2 (permalink)
Irinel's Avatar
Member: 4201
Thanks Meter: 5
Is very strange if you forgot the code, now is very dificulty to reset code if don;t know old code,one solution is to find one phone Treo 600 and put sim card inside and will make automaticaly format without ask your code.
best regards,
Irinel
The Following User Says Thank You to Irinel For This Useful Post:
Old 11-16-2004, 08:13   #3 (permalink)
Member: 32127
Thanks Meter: 34
or u can try N9210i in formatting ur mmc.....
The Following User Says Thank You to darie cruz For This Useful Post:
Old 11-16-2004, 08:55   #4 (permalink)
Irinel's Avatar
Member: 4201
Thanks Meter: 5
In 9210i i think ask code before make format....
Best regards,
Irinel
The Following 2 Users Say Thank You to Irinel For This Useful Post:
Old 11-16-2004, 09:52   #5 (permalink)
Member: 84278
Thanks Meter: 22
how reformat in n9210i? i tried viewing using memory card reader in computer but it says "insert card in drive F". i cant view the files in computer. help......
The Following User Says Thank You to rovick For This Useful Post:
Old 11-16-2004, 16:46   #6 (permalink)
Member: 72946
Thanks Meter: 2
install an search software in your 6600, find the and send the mmc detail datas in your desktop with Bluetooth. open this file with editor, in you see inside your pass. enjoy.
The Following User Says Thank You to B-PhreaX For This Useful Post:
Old 11-16-2004, 19:15   #7 (permalink)
UCPM's Avatar
Member: 66953
Thanks Meter: 4
Format the mmc card on 9210i works 100%
The Following 2 Users Say Thank You to UCPM For This Useful Post:
Old 11-16-2004, 19:25   #8 (permalink)
desmond2727's Avatar
Member: 58704
Sonork: 100.1618753
Thanks Meter: 25
hi mate u can try use the simen SL55 to format ur mmc and select Q1.6 also can find the lock code........
1:install the select Q to that mmc lock phone
2pen the select Q
3:go option
4:go find then type MMCSTORE then press the centre button
5:it well find one data folder then send this for to ur pc
6:at pc u well see the one text file (MMCSTRORE)
7:rename the (MMCSTORE.TXT)
8pen the text file u will see the pw
REMEMBER MUST USE THAT MMC LOCK COCE PHONE IF USE ANOTHER PHONE CANT WORK.
The Following 2 Users Say Thank You to desmond2727 For This Useful Post:
Old 11-16-2004, 23:44   #9 (permalink)
Member: 87789
Thanks Meter: 7
Try this method also,it appears the same idea but with other tools.
1-Setup seleQ or handyfile program on the phone locked
2-Open C:/System
3-You will find file is named mmcstore copy it to another folder.
4-Rename it mmcstore.txt you will find the password There.
Also
you can send this file to computer and open it
This method work on 6600,3650,3660,7610
The Following User Says Thank You to aziz wahba For This Useful Post:
Old 11-18-2004, 08:17   #10 (permalink)
Member: 84278
Thanks Meter: 22
To B-phreax: what file in MMc do i have to open using editor?
Old 11-21-2004, 17:14   #11 (permalink)
yaren's Avatar
Member: 4604
select Q ??
2-Open C:/System
Also
select Q ??
Is it a program? where could I download "select Q" ?
Regards
The Following User Says Thank You to yaren For This Useful Post:
Old 11-22-2004, 16:45   #12 (permalink)
Member: 65714
Thanks Meter: 17
this is good solution
but i have problem, my nokia 6600 reflash again, and i forgot the unlock code for mmc
How to resolve this problem dude?
The Following User Says Thank You to 354boyo For This Useful Post:
Old 11-22-2004, 16:52   #13 (permalink)
Member: 87789
Thanks Meter: 7
handyfile
To yaren
handyfile is equal to seleQ
it's application its extension (handyfile.sis) must be setup on the phone.
The Following 6 Users Say Thank You to aziz wahba For This Useful Post:
Old 03-19-2005, 18:33   #14 (permalink)
Rise's Avatar
Member: 39022
Sonork: 1575244
Thanks Meter: 85
Hi dear
this is just ****
i try 9210i,9500 to format memory card
but in file manager>format memory card can't highligt
and also can;t highlight change password
how i format this f*u*c*k card
The Following User Says Thank You to Rise For This Useful Post:
Old 03-20-2005, 11:33   #15 (permalink)
bestman's Avatar
Member: 61294
Thanks Meter: 49
you can reformat your memory card.using another phone ..........
try this application now..........or you return this memory card back to the sales dept.
bestman
The Following User Says Thank You to bestman For This Useful Post:
7610 memory card corrupted show without insert it memory card amardeepsahi Nokia Hardware & Hardware Repair 13 10-25-2008 17:58
Memory Card Forgotten Unlock Code N73 suntysunty Universalbox 8 10-17-2008 12:47
Code memory card after unlock Gabiunlock BB5BOX 5 04-18-2008 02:00
need help nokia7610 memory card currapted without memory card??? gsm_khorshed Nokia Hardware & Hardware Repair 3 01-03-2008 14:46
Forgotten phone code on S45. Unlocker? zoknihegeszto x1x to x45/x50 0 04-16-2002 09:24
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.39112 seconds with 9 queries
Content Relevant URLs by vBSEO
