Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 12-26-2007, 08:04   #1 (permalink)
hafizjee's Avatar
Member: 234653
Question n70 no signal
i have n70 show no signals
i search network manually and after search show all networks BUT...
no access to any network
plz help me
The Following 2 Users Say Thank You to hafizjee For This Useful Post:
Old 12-26-2007, 08:19   #2 (permalink)
..::ARUN::..'s Avatar
Member: 566335
Sonork: 100.1612128
Arrow n70 no access
n70 no access solution
The Following 13 Users Say Thank You to ..::ARUN::.. For This Useful Post:
Old 12-26-2007, 09:26   #3 (permalink)
Member: 390359
answer is here: how this problem occurs??
first you shoul try software, full flashing and write pm if still same
rehot or reball inku and hinku ic (under camera, right of mmc socket)
then change pfo and apply arun's solution.
The Following User Says Thank You to zeking82 For This Useful Post:
Old 12-28-2007, 09:16   #4 (permalink)
Member: 581194
plz help me
bro this pic can solved problem.tested 100% by me
Old 12-28-2007, 09:40   #5 (permalink)
Member: 581194
plz help me
Boim80
The Following 15 Users Say Thank You to boim80 For This Useful Post:
Old 01-28-2008, 13:29   #6 (permalink)
Member: 152087
i have n70 no signal i search manually its ok but no access pls any one show some pic. thanks
Old 01-29-2008, 09:01   #7 (permalink)
WinD_VteC's Avatar
Member: 647414
try to reball the hinku ic or change it 10000% work for u all.... try it....
WinD
Old 01-30-2008, 08:49   #8 (permalink)
Member: 692937
I also have the same problem. Thing is, I already brought it to Nokia Care, and they told me that a cristal ic needs to be replaced, but it is next to a power ic which may further damage the phone. Will boim80's solution work for my problem as well?
Old 02-26-2008, 07:36   #9 (permalink)
Sagitarious's Avatar
Member: 615730
I have N70 no Network, but 3G is highlighted, I don`t know what to do.
Please help me in this purpose.
Old 02-27-2008, 13:49   #10 (permalink)
Member: 262039
@..:ARUN:..
I try your solution and it works for me Thankyou...
Old 02-28-2008, 03:11   #11 (permalink)
WinD_VteC's Avatar
Member: 647414
hello bro try reball HINKU ic and VINKU ic...... if cannot try change it....
Best Regard
WinD
Old 02-28-2008, 05:03   #12 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
bro,
n-70 is bb5 set.
and all bb5 set is risky to erase
Old 02-28-2008, 05:04   #13 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
plz help me
bro,
try to change pa
if your problem is same then change hinku and vinku ic
best of luck
Old 04-25-2008, 14:24   #14 (permalink)
allen128's Avatar
Member: 277327
Best Regard
WinD
bro, i have change both i.c and still no network....help me plsss...
The Following User Says Thank You to allen128 For This Useful Post:
Old 04-25-2008, 15:10   #15 (permalink)
Member: 756051
IF YOU Search The Networks Manually and It SHow All NetworksBut when you choose Your Network It Dont Want To Access
THEN ITS THE (PA) CHANGE IT , AND WHEN YOU HEATING HEAT FROM THE UNDER CUZ THE (PA) IS SOO SENSTIVE AND IT DAMGED WHEN YOU HEAT ON IT
The Following 2 Users Say Thank You to Sk8erboy For This Useful Post:
n70 no signal some time show 3g on signal bar need help /\/\A/\/| Nokia Hardware & Hardware-Repair Area 2 10-14-2009 10:46
n70 no signal water damage destri Nokia Hardware & Hardware-Repair Area 5 01-14-2008 05:30
n70 no signal ruvanw1979 Nokia Base Band 5 ( BB-5 ) 3 04-27-2007 18:13
n70 no signal ruvanw1979 Nokia Digital Core Technology 4 ( DCT-4 ) 1 04-25-2007 11:38
N70 no signal jakoy Nokia Base Band 5 ( BB-5 ) 7 06-13-2006 09:03
Page generated in 0.40072 seconds with 12 queries
Content Relevant URLs by vBSEO
