Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 05-26-2007, 18:53   #1 (permalink)
Member: 119809
Nokia 1600 & 1110 Insert sim Prolblems (Urgent)
Hi I am having problems solving problems of Insert sim on the above mentioned phones, anyone with any solution please help will be appreciated.
Thanks.
The Following 6 Users Say Thank You to bassboli For This Useful Post:
Old 05-26-2007, 20:36   #2 (permalink)
Burebista's Avatar
Member: 235325
Sonork: 100.1593552
Hi,
What are You saying?Did You clean the contacts,changed IC SIM,checked with another battery and the problem is the same?
Old 05-26-2007, 20:43   #3 (permalink)
Member: 275451
hi bro
well just change sim ic...
if problem persist..
then ask
The Following 2 Users Say Thank You to as_ji For This Useful Post:
Old 05-26-2007, 23:29   #4 (permalink)
Member: 507594
I see...Is your SIM correct?
Tru with another...
The Following User Says Thank You to Chip_mg For This Useful Post:
Old 05-26-2007, 23:33   #5 (permalink)
milkyctg's Avatar
Member: 56855
This is a common problem if 1600,1110,1112,2310,2610, are damaged by water. Just cleaning solves this problem.
The Following 2 Users Say Thank You to milkyctg For This Useful Post:
Old 05-26-2007, 23:49   #6 (permalink)
Member: 507594
Yes, of course if mainboard isn't total destroyed...
The Following 2 Users Say Thank You to Chip_mg For This Useful Post:
Old 05-27-2007, 05:27   #7 (permalink)
TopLink Gsm's Avatar
Member: 333439
Sonork: 100.1589101
change sim ic.............................................
The Following 3 Users Say Thank You to TopLink Gsm For This Useful Post:
Old 05-27-2007, 08:50   #8 (permalink)
baldev's Avatar
Member: 153805
Clean properly if not solved change sim ic. also check by changing battery.
The Following 2 Users Say Thank You to baldev For This Useful Post:
Old 05-27-2007, 10:57   #9 (permalink)
Member: 434254
Talking change sim ic
please change sim ic....if not good try check by changing battery.
The Following 3 Users Say Thank You to idansp For This Useful Post:
Old 05-27-2007, 14:34   #10 (permalink)
digitized's Avatar
Member: 163833
Sonork: 100.1579554
change sim ic
change sim ic brthr u prblm will solve
Old 05-28-2007, 04:03   #11 (permalink)
yashtel's Avatar
Member: 170589
generally the liquid damage set the sim ic fuse very fast it must be a sim driver ic fault change it
Old 05-29-2007, 07:54   #12 (permalink)
Burebista's Avatar
Member: 235325
Sonork: 100.1593552
Smile
Hi there,in many cases the problem is not solved only by cleaning the PCB if the phone was damaged by water.In 90% of cases the IC SIM was damaged or battery was damaged in some cases.
Regards!
The Following User Says Thank You to Burebista For This Useful Post:
Old 05-29-2007, 08:30   #13 (permalink)
Member: 358441
try this picture100% working
Old 05-29-2007, 08:40   #14 (permalink)
Member: 358441
1600 insert sim solved 10000%
try this picture...............................
The Following 8 Users Say Thank You to jagadeesh22 For This Useful Post:
Old 05-29-2007, 12:49   #15 (permalink)
Member: 485257
1100 insert sim card download help pic.here
http://gsm-magic.org/ArchitRaj/Hardw...sim%20card.rar
Nokia 1600 & 1110 Network Problem de brain box Nokia Hardware & Hardware-Repair Area 22 12-05-2010 15:00
...::: Nokia 1110,1110i,1600,2310 New insert sim card Solution :::... sujan1050 Nokia Hardware & Hardware-Repair Area 3 12-13-2008 13:25
1600 2310 1110 insert sim cllins Nokia Hardware & Hardware-Repair Area 3 09-11-2008 18:55
Page generated in 3.05743 seconds with 13 queries
Content Relevant URLs by vBSEO
