Old 10-13-2008, 10:27   #1 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 48
nokia 1600 not power on
sir nokia 1600 mobile hay pehley blink ker raha tha aur boot nai krta tha main buterly uem ke oper change ki aur jahn cable lgti hay uskesath 8 wali buterfly b change ki ab software ho jata hay lakn mobile on nai hota aur power suply sey on krn to 2 tak patch leker wapis a jata hay waht can i do sir plz urgent help me
The Following User Says Thank You to faisal_fs For This Useful Post:
Old 10-13-2008, 11:03   #2 (permalink)
.:SARCAR:.'s Avatar
Member: 322206
Sonork: 100.1594813/.:SARCAR:.
Thanks Meter: 885
follow forum rules post in english only otherwise you will be bann forever
Old 10-13-2008, 11:12   #3 (permalink)
Member: 846585
Sonork: jaisen
Thanks Meter: 2
just erase full flash with s/w box than flash with good pm file using update file is 7.02 may yr prob. will b solve.....
-------jaisen
Old 10-17-2008, 05:01   #4 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 48
i have no s/w box
oly ub box jaf box and hwk ufs3 what can i do jaisan bhai
Old 10-17-2008, 05:52   #5 (permalink)
jimm07ct's Avatar
Member: 426688
Sonork: 100.1596204
Thanks Meter: 520
brther,
post in english,
just erase and flash it with 6.40 version
i think thats all for your solution
post your result
Old 10-17-2008, 08:45   #6 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 48
Originally Posted by jimm07ct View Post
brther,
post in english,
post your result
i do 6.40 but nothing
Old 10-17-2008, 18:01   #7 (permalink)
Member: 846585
Sonork: jaisen
Thanks Meter: 2
Thumbs up faisal_fs
i think box is nt a big problem its depend on yr file plz use only 7.02 version because it is d latest update nd use ufs3 with hwk as same as i do. i prefare hwk ufs 3..
yr problem will b solve soon
good luck faisal bhaiii
-----------JAISEN
nd plz use english always according to site's rule
Old 10-21-2008, 10:47   #8 (permalink)
Member: 846585
Sonork: jaisen
Thanks Meter: 2
no need tpo worry jst flash d cell with s/w usings ufs3 with 7.02 version
OR
check the power swich track with d help of meter via another 1600
Old 10-21-2008, 13:28   #9 (permalink)
Registered User
Member: 688907
Thanks Meter: 509
please post in english..................
The Following User Says Thank You to prakash6464mh For This Useful Post:
Old 10-21-2008, 14:32   #10 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 48
OR
sir i all do that but set not power on
test mode local mode show on screen before after boot flash i am using all software version but nothin flash coplete i m change the terminal and heat the uem and cpu but ,my problem not so;ve
Old 10-21-2008, 14:51   #11 (permalink)
Member: 570626
Sonork: 100.1579059
Thanks Meter: 117
u can use 3.40 v and full erase and flash, write a good pm & unlock the phone i hope your problem willbe solve
Old 10-22-2008, 11:14   #12 (permalink)
Member: 532257
Sonork: 1624266
Thanks Meter: 48
i m using all vesion 3.06 version but set nt power on
Old 11-11-2008, 08:27   #13 (permalink)
Member: 500157
I have nokia 1600 dead condition, when i flash it every thing is ok set power on through the software box after flashing when i put battery it will not power on eventhough i flash it jaf and ufs3 og box with 6.39 and rehot uem and cpu ic also same problem any body can pls help me
Old 11-11-2008, 08:48   #14 (permalink)
Member: 500157
JAF version 1.98.52
Detected PKEY:
Card life counter: 86.09%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B0, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
ADSP Flash file: NONE
APE Variant file: NONE
APE User Flash file: NONE
INI file .ini is missing. Continue searching for second ini type...
Changing flashing settings...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_06.930
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_06.93aa
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai6.93aa
Languages in ppm: English,Dannish,Norwegian,Swedish
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh64_06.93mi
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-64\rh640_nai6.93mi
Languages in ppm: English,Hindi,Tamil
Backup IMEI zone...
Setting local mode...
Failed! Aborting!
Getting MCUID...
Phone didn't answer with TX line high after power on!
Causes:
1. Phone don't power on -> Check cable
2. TX pin from phone don't make contact -> Check cable
3. UPP damaged -> change UPP
MCU ID: 0xAAAA
Failed!!!
when i make erase flash with jaf it will come like this shown in above
Old 11-12-2008, 17:11   #15 (permalink)
Member: 696370
Thanks Meter: 24
sri i'm have same problem . i fully software is good running but they cann't boot so , what i do it any help with me !!!! i do my box is jaf ,ufs with hwk
nokia 1650 not power on.plz help mittho.gsm Nokia Hardware & Hardware Repair 1 05-08-2008 00:14
nokia 6233 not power on .::PATEL TELECOM::. Nokia Hardware & Hardware Repair 4 02-13-2008 03:42
NOkia N91 Not powering on with out back door Alemano Nokia Base Band 5 ( BB-5 ) 4 07-14-2006 16:30
Nokia 1600 Cant POWER ON PIMP123 Nokia Digital Core Technology 4 ( DCT-4 ) 2 12-14-2005 04:03
Nokia 3310 not power on after water snk Nokia Hardware & Hardware Repair 1 07-07-2001 16:15
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.51241 seconds with 8 queries
Content Relevant URLs by vBSEO
