Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 09-28-2007, 19:47   #1 (permalink)
..:MumbaiGsm:..'s Avatar
Member: 205738
nokia 2626 display light
2626 display light not work
replaced Disp.ic,transistor,disp connector and display also
still same problem
whats the problem??
The Following 2 Users Say Thank You to ..:MumbaiGsm:.. For This Useful Post:
Old 09-29-2007, 05:05   #2 (permalink)
Member: 205738
yet no one Answer..............
The Following User Says Thank You to ..:MumbaiGsm:.. For This Useful Post:
Old 09-29-2007, 05:15   #3 (permalink)
shinod's Avatar
Member: 55363
try as same as nokia 1600 and 1110 display light solution first check coil and light driver
The Following User Says Thank You to shinod For This Useful Post:
Old 09-29-2007, 15:31   #4 (permalink)
Member: 244357
check all tracks as shows in diagram, check led also and check coil
if the problem is not solved reply
The Following User Says Thank You to bhardwajparesh For This Useful Post:
Old 09-29-2007, 17:48   #5 (permalink)
ansari123's Avatar
Member: 292789
dear see this pic and reply me ??
The Following 13 Users Say Thank You to ansari123 For This Useful Post:
Old 09-29-2007, 19:34   #6 (permalink)
Member: 205738
its no use brother!!
light ic easily available....i repaced it ..still problem
wbr...
Old 10-02-2007, 08:08   #7 (permalink)
Member: 443790
sir your post test after result pls
The Following User Says Thank You to ..::jothikrish::.. For This Useful Post:
Old 10-03-2007, 12:05   #8 (permalink)
linekbp's Avatar
Member: 81697
are all the tracks ok? did u check them?
The Following User Says Thank You to linekbp For This Useful Post:
Old 01-01-2008, 13:20   #9 (permalink)
Member: 167773
Bro last week i fase one problem like that finally , i replaced the Kepad LED then everything was ok. Pls try it .
The Following User Says Thank You to sathya84 For This Useful Post:
Old 01-02-2008, 19:52   #10 (permalink)
Member: 669218
brother u should change the lcd connector then check the connection from lcd connector to lower part i hope ur problem wil be solve
The Following User Says Thank You to shahidkhan1 For This Useful Post:
Old 04-19-2008, 16:42   #11 (permalink)
Member: 565755
thanks...................
The Following 2 Users Say Thank You to damio For This Useful Post:
Old 06-03-2008, 14:47   #12 (permalink)
Member: 66436
"Bro last week i fase one problem like that finally , i replaced the Kepad LED then everything was ok. Pls try it "
thanks!
The Following 2 Users Say Thank You to lephilong1980 For This Useful Post:
Old 06-03-2008, 15:36   #13 (permalink)
Member: 432679
Good job lage rahooooooooooooooooooooooooooooooooooooo
The Following 2 Users Say Thank You to syed.n For This Useful Post:
Old 06-03-2008, 15:55   #14 (permalink)
.::AZEEM::.'s Avatar
Member: 336212
Sonork: 100.1585000
Hmm u can chak tracks if all is oki than u can replace near light ic all part
If no luck some time upp also problam u can rehot it Mabe .
The Following User Says Thank You to .::AZEEM::. For This Useful Post:
Old 06-03-2008, 15:58   #15 (permalink)
akash_hul's Avatar
Member: 716744
1600 light
final solution for light
The Following 2 Users Say Thank You to akash_hul For This Useful Post:
Need Nokia 2626 Display ways.... Paavalan Nokia Hardware & Hardware-Repair Area 7 08-25-2010 20:14
Nokia 2626 blu light hang solve 1000% san9090 Nokia Hardware & Hardware-Repair Area 0 01-23-2010 13:42
Nokia 2626 display light problem yash_show Nokia Hardware & Hardware-Repair Area 1 12-08-2009 19:50
2626 Display Light ARS.Rehman Nokia Hardware & Hardware-Repair Area 8 08-19-2009 04:58
nokia 2626 no light excalliber Nokia Digital Core Technology 4 ( DCT-4 ) 2 10-28-2008 08:30
Page generated in 0.86532 seconds with 12 queries
Content Relevant URLs by vBSEO
