Unlock Server
Old 12-15-2010, 05:23   #1 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 89
Lightbulb Nokia 5030c hanging and autoshutdown
A customer brought nokia 5030c radio ex saying it hang and shutdown and i tried flashing with different firmware version and with different box with good pm but the same problem and i even heat the cpu but the same problem,can anybody help me with hardware solution with picture indicating the track to run or change help me somebody.
The Following User Says Thank You to wisdom001 For This Useful Post:
Old 12-15-2010, 10:41   #2 (permalink)
Member: 404765
Thanks Meter: 19
pls clean the charging jack......
Old 12-15-2010, 11:08   #3 (permalink)
stylemobile's Avatar
Member: 533098
Thanks Meter: 10
clean charging jack.and flash with latest ver
Old 12-15-2010, 11:13   #4 (permalink)
ABDUL RAJA's Avatar
Member: 665989
Sonork: 100.1597348
Thanks Meter: 548
First check whether hardware or software problem....
If WDT is on then on and shutdown will happen!!!
Post self test results!!!
Old 12-16-2010, 01:41   #5 (permalink)
Member: 1439039
Thanks Meter: 12
rehot upp..........................
Old 12-16-2010, 05:16   #6 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 89
I have rehot upp and service the phone but the same problem ,i have the same problem with nokia 2330 and 2680 and when i made jumper the problem was solved but for nokia 5030 i don't know the jumper please help me with hardware solution with picture on how to make the jumper to solve the problem.
Old 12-16-2010, 05:29   #7 (permalink)
sajidshah50's Avatar
Member: 1016490
Sonork: 100.1659566
Thanks Meter: 245
bro check to remove the charging jack
Old 12-16-2010, 07:35   #8 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 89
i will try and post reply
Old 12-22-2010, 07:23   #9 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 89
please help me with hardware solution of 5030c hanging and autoshutdown like that of 2630 and 2330 solution that work fine
Old 01-03-2011, 08:28   #10 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 89
please help with 5030 hanging and autoshutdown solution please help me somebody when i plug charger is ok and when i remove it hang and off
Old 01-11-2011, 14:14   #11 (permalink)
wisdom001's Avatar
Member: 676315
Thanks Meter: 89
Old 01-11-2011, 14:23   #12 (permalink)
Member: 516628
Thanks Meter: 8
5030 hanging
brother check the crystal. change it. the problem is there.
Old 06-24-2011, 13:02   #13 (permalink)
Member: 1324451
Sonork: mark
Thanks Meter: 9
i have the same problem of this threed starter.....
anybody solve this trouble???
please share it...
Old 06-24-2011, 14:41   #14 (permalink)
salmaan shaik's Avatar
Member: 1271316
Sonork: 501101
Thanks Meter: 22
BROTHER remove charging reglater ic (brown coluor) NEAR charging connector i hope solve ur problem best of luck post result
The Following User Says Thank You to salmaan shaik For This Useful Post:
Old 06-24-2011, 19:42   #15 (permalink)
ankit9090117706's Avatar
Member: 1291109
Sonork: 100.1607039
Thanks Meter: 17
and flash your phone
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 29 06-27-2014 21:31
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 48 05-12-2013 13:07
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-15-2011 12:08
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.47411 seconds with 8 queries
Content Relevant URLs by vBSEO
