Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Nokia > Nokia Hardware & Hardware-Repair Area
Nokia Hardware & Hardware-Repair Area all what you need for Hardware Repairing for Nokia Phones. Before writing any thread here try to check the Frequently Asked Questions Section.
Old 03-17-2010, 12:55   #1 (permalink)
dawah telecom's Avatar
Member: 868940
nokia 6303 always battery low....
hello m8,i av nokia 6303,immediately i power it on,it shows nokia and says battery low,after that it shows white screen.
what can i do to make it work........m8 ??
thankx.
The Following User Says Thank You to dawah telecom For This Useful Post:
Old 03-17-2010, 12:58   #2 (permalink)
Member: 901783
did you try another battery sir?have you test if theres a leak in your phone?hope it helps
Old 03-17-2010, 13:17   #3 (permalink)
Member: 1162506
brother cheak any parts may be short.
Old 03-17-2010, 13:21   #4 (permalink)
Member: 868940
@ fengyo.
what do you mean by this above....mean while i have try different battery on it....same thing.
any other idea ??????
Old 03-17-2010, 13:24   #5 (permalink)
guljee786's Avatar
Member: 762034
Sonork: 100.1585274
Wink
thankx.
brother see shortage in ur set also see its water damg and check pa.....
Guljee
Old 04-27-2010, 11:02   #6 (permalink)
mothertelecom's Avatar
Member: 1033714
Sonork: 1615102:md
thankx.
Old 04-27-2010, 12:20   #7 (permalink)
Member: 54228
cheak betty ic bro ..........
Old 04-27-2010, 12:24   #8 (permalink)
Member: 879723
damg pa and check........................
Old 06-04-2010, 17:51   #9 (permalink)
Member: 786178
Sonork: 100.1592104
i have nokia 6260s-1 have same problem show nokia logo and battery low and then white screen. any one know where to start.
Old 06-04-2010, 18:51   #10 (permalink)
Crazy Poster
Member: 545747
brother set me sorting hai power ic and chargng ic reboll ya chang 1000000%solve your proble
Old 10-26-2010, 17:17   #11 (permalink)
ahmertelecom's Avatar
Member: 210880
Sonork: 100.1577765
Nokia 6303c Low battery after whitescreen 100% tested solution
The Following User Says Thank You to ahmertelecom For This Useful Post:
Old 12-10-2010, 15:20   #12 (permalink)
Member: 1251850
6303 show battery low when calling.
when calling 6303 show battery lowand switched off.any pm problem?
Old 12-10-2010, 17:08   #13 (permalink)
bpcentergtk's Avatar
Member: 311436
Check the battery connector properly than check bsi line,on most of the sets i have seen battery connector disconnected from board what i do is make jumper from bsi connector to condesor near battery connector
Old 01-20-2011, 12:00   #14 (permalink)
muhammad khalid's Avatar
Member: 313337
Sonork: 100.1582697
gentleman this is right solutio for your mobile
thanks to you all by gsmzaman
Old 02-02-2011, 09:12   #15 (permalink)
Member: 30455
and my battery connector damage
under the battery connector tracks damage and now no work camera and bluetooth...
any solution?
nokia 5000d-2 battery low problem peter brown Nokia Hardware & Hardware-Repair Area 2 02-03-2010 09:46
Nokia cdma 6275 battery low shivashakthi Nokia Hardware & Hardware-Repair Area 2 05-07-2009 10:22
w375 always battery low hyper_wamir Motorola Hardware Repair Section 1 05-06-2009 07:48
t191 Always showing low battery,no matter the battery isiaka ODM (Original Design Manufacturing) 8 09-02-2008 17:10
C100 Always Battery Low jamohaki Samsung Hardware Repair Area 3 11-02-2007 17:21
Page generated in 0.36304 seconds with 11 queries
Content Relevant URLs by vBSEO
