Old 03-17-2011, 10:15   #1 (permalink)
kulu's Avatar
Member: 5871
Thanks Meter: 87
Nokia C2-01 Jumper Ways Solution
Nokia C2-01 Power/END key Jumper Ways
If the Nokia C2-01 shows charging indication when the battery charger is plug-in, but unable to turn ON. This problem is cause by a faulty power ON-OFF key . Fixing it is quite so easy, you mat first try to clean the PCB board's keypads matrix and the keypad membrane.
If the keypads mats is cleaned and doesn't solve the problem, refer to the solution below and trace the power/end key connection line paths.
There is a 10K resistor connected to the power key and the opposite side is connected to the 3.8 VBAT (battery voltage). You may try to check and replace the said resistor.
The Following 9 Users Say Thank You to kulu For This Useful Post:
Old 03-17-2011, 10:21   #2 (permalink)
kulu's Avatar
Member: 5871
Thanks Meter: 87
Nokia C2-01 Not Working Buzzer, Ringtone IHF speaker Problem Solution
Another Nokia c2-01 solution created by GsmAngel that covers for Buzzer Speaker Problem, or no ringtones and alert sound can be heard on the device even the volume control was already set to high level.
This solution below provides which components needs to be check to fix and put back the phone's buzzer function working again. Just refer to it and follow some step by step procedures we prepared.
Steps procedures to fix Nokia C2-01 buzzer speaker problem:
1. Visually check the IHF buzzer speaker for possible misaligned of the terminals and or using a multimeter, replace if found damaged. Clean if it oxidized.
2. Clean the speaker terminal PCB contact pads.
3. Check/replace the filter coils and capacitors.
4. Trace both positive and negative connection line paths.
5. If the above procedures, won;t fix the problem. The PEARL IC will be the last option to work at.
Reworking it might only fix the problem.
The Following 8 Users Say Thank You to kulu For This Useful Post:
Old 03-17-2011, 10:25   #3 (permalink)
kulu's Avatar
Member: 5871
Thanks Meter: 87
Nokia C2-01 Not Charging Solution
This solution covers for Nokia C2-01 for not charging problem, or shows no charging indication or response when the battery charger is plug-in. This simple solution shows and tells us the basic steps on how to fix the phone if such problem happens.
The solution below provides the connection line paths that holds for charging on the device. Just follow some simple hints on how the way we troubleshoot t\and fix the charging problem.
Repair hints on Nokia C2-01 Charging Failure:
1.Try to use another working charger.
2. Try to replace and use another working phone's battery. Clean also the battery connector.
3. Check, clean or replace the charging pin - DC jack connector.
4. By using a multimeter, do a continuity check and trace the positive (V+) and negative (V-) line paths.
5. Check/replace the fuse, diode, coil and capacitor.
6. If the above procedures, doesn't fix the problem. the possible faulty is the PEARL IC, reworking or replacing it might only fix the problem.
The Following 5 Users Say Thank You to kulu For This Useful Post:
Old 03-17-2011, 10:28   #4 (permalink)
kulu's Avatar
Member: 5871
Thanks Meter: 87
Nokia C2-01 Insert SIM card Problem Solution
Here's the solution for Nokia C2-01 Insert Sim Card error problems, if the phone unable to detect or read the Sim card inserted to it. This solution may help us on how to analyze and troubleshoot if such sim card error problem occurs.
The solution below shows the connection line paths of the Nokia C2-01 SIM card connector and which components needs to be check first.
If the phone doesn't detect any working sim card inserted to it, try to clean the sim card pin connector first.
Then check the Ground and VSIM pin connection. Check,replace the 33ohms resistor.
If the above basic procedure doesn't solved the problem, the possible faulty is the PEARL IC, reworking it, might only fix your Nokia C2-01.
Old 03-17-2011, 10:30   #5 (permalink)
kulu's Avatar
Member: 5871
Thanks Meter: 87
Nokia C2-01 Earpiece Speaker Problem Solution
This repair solution covers for Nokia C2-01 not working earpiece speaker problem. This problem may occurs or happens if the device suffered wet or water damaged, heavily dropped or just happens while using it. An oxidation build ups may also cause the ear speaker failure.
This solution provides the basic steps on how to fix and repair the phone. Just refer to the given solution below and follow some simple steps we prepared.
Hints on repairing Nokia C2-01 not working ear speaker problem:
1. Check the Receiver speaker terminals if not misaligned and or damaged then test it using a multimeter, replace if found damaged.
2. Clean the ear speaker terminal contact pads on the PCB board.
3. Check/ replace the filter coils and capacitors.
4. Trace the speaker connection paths from the filter coils down to the PCB terminal pads.
Old 03-17-2011, 10:34   #6 (permalink)
kulu's Avatar
Member: 5871
Thanks Meter: 87
Nokia C2-01 Keypad Problem Repair Solution
This is Nokia C2-01 solution for not working keypads problem. This solution shows the connection line paths of the C2-01 keypad matrix including the EMI filter IC jumper ways. This may help for easy troubleshooting a keypad failure on the phone.
Just refer to the solution below and analyze how each certain keypad keys being connected. This solution may also help in bypassing the keypad EMI filter IC.
Hints on Nokia C2-01 Keypad Malfunction Repairs:
1. Clean the keypad matrix including the keypad membrane.
2. Trace the connection line paths of a certain keys that doesn't work.
3. Check/replace the Keypads EMI filter IC or you can bypass it by applying a jumper wire on the open test point or spots as shown on the picture above. It will work too.
Old 03-17-2011, 10:36   #7 (permalink)
kulu's Avatar
Member: 5871
Thanks Meter: 87
Nokia C2-01 MIC Problem Repair Solution
This is the Nokia C2-01 solution for Mic, *****piece microphone not working problem. The solution repair guide below simply shows the connection line paths of the microphone for troubleshooting.
Just follow some simple hints we provide on how to troubleshoot the microphone problem on Nokia C2-01 phones.
Here's the simple step by step instruction on how to fix a not working microphone on Nokia C2-01:
1. Check the microphone visually and using a multimeter, replace if found damaged.
2. Clean the MIC's terminal contact pads
3. Trace the outer and inner core MIC's contact pads connection line paths.
4. Check/replace the Filter coils and Resistor.
5. If the above procedures doesn't fix the problem, the possible faulty is the PEARL IC. reworking it might only fix the problem.
Old 07-10-2011, 06:57   #8 (permalink)
sanjeevjha's Avatar
Member: 1270242
Sonork: 1602438
Thanks Meter: 157
super job dear thank a lot
Old 07-10-2011, 07:07   #9 (permalink)
AMEERGUL's Avatar
Member: 669947
Sonork: 100.1614053
Thanks Meter: 113
good work brother thanks
Old 07-10-2011, 07:54   #10 (permalink)
Member: 1324451
Sonork: mark
Thanks Meter: 9
very nice reference...
good job....
Old 07-10-2011, 08:08   #11 (permalink)
geraomobeem's Avatar
Member: 1612957
Sonork: 100.1607959
Thanks Meter: 51
Cool tanke
nice work keep it up i like it www.gsmgmword.com
:D
nicev workr bro i like it keer it up :)
Old 11-11-2011, 03:31   #12 (permalink)
Member: 1066806
Sonork: 10203
Thanks Meter: 18
dear friends i have changed nokia c2 01 kp ic but not working pcb water lock but now its fine then only the end key is working for powering on the mobile and powering off the mobile plz help me thanks in advance surenbarani@gmail.com plz its little urgent
Old 11-11-2011, 04:58   #13 (permalink)
anwar.welltech's Avatar
Member: 952533
Sonork: 1001607366
Thanks Meter: 91
goodwork br keep it up
Old 11-24-2011, 14:16   #14 (permalink)
Member: 726406
Sonork: jwiar
Thumbs up c2 headset
thanks
please if you have eny solution for headset way
Old 11-25-2011, 09:04   #15 (permalink)
rajeshlehal's Avatar
Member: 666540
Thanks Meter: 350
really good work done keep it up always...........
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 29 06-27-2014 22:31
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 04:50
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 48 05-12-2013 14:07
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.49658 seconds with 8 queries
Content Relevant URLs by vBSEO
