Unlock Server
Old 05-05-2011, 14:29   #1 (permalink)
..::One-Man::..'s Avatar
Member: 1174508
Sonork: 100.1593820
Thanks Meter: 10,568
nokia c5 solution here .
Nokia C5-00 USB Device Not detected Problem Solution
The Following User Says Thank You to ..::One-Man::.. For This Useful Post:
Old 05-05-2011, 14:31   #2 (permalink)
Member: 1174508
Sonork: 100.1593820
Nokia C5-00 Display Problem Solution
Old 05-05-2011, 14:33   #3 (permalink)
Member: 1174508
Sonork: 100.1593820
Nokia C5-00 Keypad white LED light not working problem solution
Old 05-05-2011, 14:35   #4 (permalink)
Member: 1174508
Sonork: 100.1593820
Nokia C5 Headset No Audio Problem Solution
Old 05-05-2011, 14:44   #5 (permalink)
Member: 1174508
Sonork: 100.1593820
Nokia C5 Camera Flash Light LED problem Solution
The Following 2 Users Say Thank You to ..::One-Man::.. For This Useful Post:
Old 05-05-2011, 14:47   #6 (permalink)
Member: 1174508
Sonork: 100.1593820
Nokia C5 Local/Test Mode Problem Solution
Old 05-05-2011, 14:48   #7 (permalink)
Member: 1174508
Sonork: 100.1593820
Nokia C5 MMC microSD Not detected, insert memory card error problem solution
Troubleshooting hints for Nokia C5 memory card problem:
1. Try to use and replace another working microSD card.
2. Clean the microSD card holder if oxidized.
3. Check the VMEM voltage this reads from 1.8v to 3V.
4. Check replace the 47 ohms resistors and 18p and 100n capacitors.
5. If the above procedures didn't work, try to restore, flash update the device firmware.
6. If the firmware is okay. the possible faulty is the GAZOO IC. Reworking or replacing it will only fix the problem.
Old 05-05-2011, 14:48   #8 (permalink)
Member: 1174508
Sonork: 100.1593820
Nokia C5 camera problem solution
Repair hints for not working camera on Nokia C5:
1. Remove the camera module, clean the socket or holder pins if oxidized.
2. Check the VCAM 1.8V and 2.8V on across to the highlighted filter coils and capacitors. Check/replace also those coils.
3. If the voltage is missing or there is no readings, check the VBAT 3.8 volts
4. If the VBAT voltage is okay, replace the regulator IC on a specific voltage that has no readings.
5. Replace the camera module
Old 05-05-2011, 14:49   #9 (permalink)
Member: 1174508
Sonork: 100.1593820
The Following 3 Users Say Thank You to ..::One-Man::.. For This Useful Post:
Old 05-05-2011, 14:49   #10 (permalink)
Member: 1174508
Sonork: 100.1593820
Old 05-05-2011, 14:50   #11 (permalink)
Member: 1174508
Sonork: 100.1593820
No Earpiece Speaker Audio Sound
Old 05-05-2011, 14:50   #12 (permalink)
Member: 1174508
Sonork: 100.1593820
Nokia C5 Charger Not supported problem solution
Old 05-05-2011, 14:53   #13 (permalink)
jakkarzoya_2511's Avatar
Member: 613242
Sonork: 100.1626311
Thanks Meter: 579
Arrow good
good work bro keep it up
The Following User Says Thank You to jakkarzoya_2511 For This Useful Post:
Old 05-06-2011, 06:48   #14 (permalink)
Member: 1174508
Sonork: 100.1593820
Old 05-08-2011, 14:55   #15 (permalink)
Member: 289888
Thanks Meter: 59
c5 singnal prob
no network found
plz help
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-05-2014 11:33
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 29 06-27-2014 21:31
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 48 05-12-2013 13:07
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.54606 seconds with 9 queries
Content Relevant URLs by vBSEO
