Unlock Server
Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > LG
Old 08-31-2009, 14:07   #1 (permalink)
Member: 76018
Thanks Meter: 56
[How To] LG Km900 Flashing (all Files included)
As I was loohing quite a while for all Files and had to test several Infos abozut how to Flash the LG Km900... I`ll share my knowledge about how to flash this one.
First you need to install the following Files:
1. LG PC-Suite III- you can get it from the LG-Site or here!
2. Install Infineon-Flash-Driver
Install both and connect turned on Handy. Use PC-Suite-Mode on the Handy to install correct driver. Now remove Handy and remove the Accu. Connect the Handy without Accu to the PC. Now the FlashDriver should be installed (you can check in your PC-Hardware-list for some seconds).
Remove Handy now.
Now you need to get Flasher and working FlashFile:
1. You can find Flasher here!
2. You need a Flashfile in "Cab"-Format (not .kdz). You can find latest Open Europe here (its V10I_06)
Now we can start:
1. Start KP500-Utils-EN.exe and connect the Handy
2. You should see this screen:
Only enter the text inside the "" for the follwing steps:
3. You choose "i" and enter
4. You enter PhoneModell "KM900" and press Enter
5. Now you enter exact Position of FlashFile. If you have put the File into same directory as the Flasher is located you need just to type the Filename: "V10I_06.cab" and Enter
6. Now you enter Firmware-Name. For my file you enter "V10I_06" and press Enter
Now and Window should open with the Flasher... Just follow the options (they differ from the FW-Version on your Handy, so dont worry). Flashing takes 20-40 Minutes. Don`t disconnect the Handy while Flashing... or it`s dead...
After all you need to do an factory-Reset:
Just type: "1809#*900#" and Choose Factory Reset
The Following 12 Users Say Thank You to Dodger For This Useful Post:
Old 10-17-2009, 16:24   #2 (permalink)
RIOPHONE's Avatar
Member: 266765
Sonork: +21624131501
Thanks Meter: 2,401
gooooooooooooood job
Old 10-19-2009, 12:34   #3 (permalink)
Sahil2007's Avatar
Member: 598395
Thanks Meter: 659
Remove Handy now.
Now we can start:
plz check Always Show This Error.
Old 10-19-2009, 13:01   #4 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,886
Grab any of Firmware from
http://forum.gsmhosting.com/vbb/show....php?p=4831335
Flash with GSMULTI 3.0
Hassle free
The Following User Says Thank You to .:SUBRATA:. For This Useful Post:
Old 06-28-2010, 16:02   #5 (permalink)
Member: 496508
Thanks Meter: 59
KM900 - Arena - Firmware - All Region - GSM-Forum
Hassle free
i have LG KM900 only show logo LG
when i connected to usb nothing happen
br
Old 06-29-2010, 08:00   #6 (permalink)
Moderator
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,369
br
Connect the phone to USB cable without Battery, should ask for Flash Loader Utility driver.
The Following 2 Users Say Thank You to nasirahmed For This Useful Post:
Old 06-30-2010, 10:26   #7 (permalink)
Member: 1223045
Thanks Meter: 3
Sahil you don't have images in C:\Documents and Settings\All Users\Application Data\LGMOBILEAX\image !
The Following User Says Thank You to BigBoy™ For This Useful Post:
Old 06-30-2010, 10:27   #8 (permalink)
Member: 1223045
Thanks Meter: 3
br
Rie2n use GSMulti for KM900
Old 01-01-2011, 15:48   #9 (permalink)
Crazy Poster
Member: 1204309
Sonork: smartcel1
but what u mean by accu ??
Old 01-04-2011, 15:16   #10 (permalink)
Crazy Poster
Member: 1204309
Sonork: smartcel1
pls help me i cant flash by this procedure
Old 01-04-2011, 16:37   #11 (permalink)
Moderator
nasirahmed's Avatar
Member: 57760
Sonork: 100.1579298
Thanks Meter: 3,369
Please check here for the procedure to flash with original flasher. Fimrware and DLL also posted in different thread. Do a search.
LG Flashing/Upgrading/Debranding Tutorial
Old 05-23-2011, 21:05   #12 (permalink)
Crazy Poster
Member: 156120
Thanks Meter: 3
thinks pro for sharing
Old 08-19-2011, 18:06   #13 (permalink)
Member: 1637748
Sonork: 03210321
Thanks Meter: 2
my lg km900 is not going to lg plz help me sir how will go to
Old 03-01-2014, 02:21   #14 (permalink)
Member: 2131906
Sonork: 1653000:esQmo
Thanks Meter: 4
Remove Handy now.
Now we can start:
Hi, can you please provide new links? 'cause those leading to hotfile aren't working anymore.
Best Regards
Where to Download LG KM900 flash files nofear99 LG 1 11-13-2009 11:32
..:: how to unlock km900 and how to anstal driver:::... algerienbox FuriousGold | Powered by FuriousTeam 9 07-10-2009 09:30
How to Run .jad and .jar files on LG KG200? umarriaz2k7 LG 0 02-26-2007 09:56
how to modify the flash file to unprotect it?? Kevin perez Mitsubishi 5 10-06-2003 11:49
How to convert The flash PPM files generated by Flash tone to wintesla PPM File ???? adawi74 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 06-25-2002 13:21
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.51181 seconds with 9 queries
Content Relevant URLs by vBSEO
