Unlock Server
Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Hardware Repair Area
Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 04-11-2005, 17:00   #211 (permalink)
Member: 136250
Hi, I have a Samsung E600 that I want to connect to my Mac via USB. The supposedly USB cables I've bought over the internet seem to be serial and don't work.
Can you tell me the pinouts I should connect at each end to connect the E600 directly to the USB port or is such a direct connection impossible. Software that I have found suggests this is possible but doesn't describe how to make up a cable.
Hopefully this is a very simple question for you, most of what I have seen on this site is deeply technical.
Many thanks.
Old 04-11-2005, 20:27   #212 (permalink)
Member: 120521
Originally Posted by EMINEMGSM
X600 keypad solution
if remove Micro not work
Thank you, i use your solution on x600 keypad and it works well.
Old 04-11-2005, 20:47   #213 (permalink)
Member: 120521
Originally Posted by adilusta
c100 buzzer waysssssssssssssssssss
pls what should be done to those components you circled in your diagram? PLS I NEED AN EXPLANATION.
Old 04-11-2005, 21:16   #214 (permalink)
Member: 120521
A8oo Self Charging
Can any one please post the solution for A800 that is self charging or discharging. multiroamy
Old 04-11-2005, 22:04   #215 (permalink)
Member: 134237
'' paused by temperature'' is it the same for v200. Thanks
Old 04-12-2005, 09:11   #216 (permalink)
Member: 90058
nice works for all thanks to all
Old 04-12-2005, 10:23   #217 (permalink)
Member: 38922
Originally Posted by protocolbg
Any solution about v200-no lights on display
Check/change Flex or LCD
GreeTZ
Old 04-12-2005, 11:10   #218 (permalink)
samanthe's Avatar
Member: 41791
E700 white lcd
Dear friends,
I have one phone with white lcd,I changed with good complete lcd with cable ,but it same,pls help to find the solution,
regards,
sam
Old 04-12-2005, 12:44   #219 (permalink)
Member: 51305
for E700 white lcd change the camera it will work fine
Old 04-12-2005, 16:56   #220 (permalink)
Member: 114965
Originally Posted by samanthe
Dear friends,
regards,
sam
you have take out resistor R309 - 22com --- pic
The Following User Says Thank You to Alex-in-Side For This Useful Post:
Old 04-13-2005, 11:52   #221 (permalink)
Member: 38922
Samsung D500 SERVICE MANUAL
http://rapidshare.de/files/895043/SG...anual.rar.html
click bottom: FREE and wait some seconds till it give the Link for Download.
GreetZ
Old 04-13-2005, 11:54   #222 (permalink)
Member: 38922
Originally Posted by Uvedovle
Hi:
I have samsung e330 with dead keyboard after some water; i cleaned all keyboard but the next day keyboard is dead again.
Please friend, help me.
Wbr
Make an Ultrasonic Bath with alcohol. and let wait PCB in the alc. 1-2 days. Maybe ya have Oxid under ICs..
GreetZ
Old 04-13-2005, 11:55   #223 (permalink)
Member: 38922
Dear friends,
regards,
sam
Flash the Phone and MMI) reset. Check the connections between LCD conn. and contacts.
GreetZ
Old 04-13-2005, 17:26   #224 (permalink)
tigertrn's Avatar
Member: 84922
Unhappy Please help!
Samsung e800 not power on. He can not be flashed. I think this is some hardware problem, so please help me. Give me some shematics pls.
Old 04-13-2005, 18:16   #225 (permalink)
Member: 136589
plz help
a800 after change the cable LCD.main lcd is white.plz send me shematic of a800 cable.thanks
***All Samsung Hardware Solution*** nafisd Samsung Hardware Repair Area 4 02-25-2013 10:26
***All Samsung Hardware Solution*** bunty2008 Samsung Hardware Repair Area 28 01-12-2013 04:24
All Samsung Hardware Solution bsat Samsung Hardware Repair Area 16 08-04-2012 12:32
Page generated in 0.44249 seconds with 12 queries
Content Relevant URLs by vBSEO
