Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Samsung > Samsung Hardware Repair Area
Samsung Hardware Repair Area Post here your Hardware Repairing Hints or Problems with Samsung Phones.
Old 04-13-2005, 18:27   #226 (permalink)
Member: 38922
Originally Posted by TUANANHTRINH79
plz help
a800 after change the cable LCD.main lcd is white.plz send me shematic of a800 cable.thanks
http://www.schema99.host.sk/index.php look at the a800 LCD Way Schematics for Download on the left side.
GreetZ
Old 04-13-2005, 18:33   #227 (permalink)
CPUKILLER's Avatar
Member: 76257
Originally Posted by masud007
hi who can help me fr sony ericssion t310,everthing is ok but when i on the switch after 2/3 min phone wil restart selfly,so any one pls help me to out of this prblm!thanks
REBALL THE FLASH IC AND FLASH PHONE AGAIN DONE IN SEVERAL UNITS
Old 04-14-2005, 03:31   #228 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
X100 hanging and Restarting....
Originally Posted by ahmedksal
Hi,
Any Solution For X100 Freezing. Keypad Freezes And Then Phone. Tried Full Flashing But No Luck. Thanks
i have this problem also, the phone hangs and restarts sometimes, i have tried full flash several times but still not working, i tried to see if resistors could be removed but i don't know which one to remove as the pcb differs from X600 which the solution has been posted here.....
please anybody with the solution to this problem?????????
Old 04-14-2005, 03:43   #229 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Originally Posted by yasirmcp
some where in circuit shot.clean the board threw cleaner and just give a hot air to board.(dry)
thanks, i think it short circuit, because i just solved tyhe problem by resoldering the U100, everything now worked ok, the power key now responds, the paused by temperature dissaperad and phone worked perfectel....
the solutuon posted here also worked for me but worked better on P400,
thaks to all for these contributions......
kudos from Nigeria
Old 04-15-2005, 02:20   #230 (permalink)
Member: 38922
E700 PCB-Sim Side Description
GreetZ
Old 04-15-2005, 09:44   #231 (permalink)
Member: 72013
s300 limited service
I have problem with s300m with network.Sametime he no network,sametime limited service and sametime he have network but no call.Help please
Old 04-15-2005, 09:56   #232 (permalink)
Member: 38922
Change p.A (Power Amplifier) and it will be ok.
GreetZ
Old 04-15-2005, 13:44   #233 (permalink)
protocolbg's Avatar
Member: 17637
SGH-T500 lcd help?
Can somebody send picture on samsung T500 lcd ways ???
Old 04-15-2005, 17:12   #234 (permalink)
Member: 94109
e630 no service
Does somebody know solution for samsung E630 no service problem? Phone works fine but sometimes lose network and send message ``no service``...
Old 04-15-2005, 18:31   #235 (permalink)
Member: 46341
E700 white lcd. I evan changed LCD interface ic but lcd stil onnly light.
Ofcorse, I do software and chek konectors oll ok. This komplete lcd working 100%
on odher ok board.
The reason of this folity is after changing flasx cable, probbly put something
short on flex. Now phone only ligt.
Old 04-16-2005, 04:01   #236 (permalink)
magixian's Avatar
Member: 61176
Sonork: 100.86572
Any solution please.......X100 hanging and restarting?
C100 antenna swich connection! does any body no it?
Old 04-16-2005, 11:43   #237 (permalink)
protocolbg's Avatar
Member: 17637
hi
I need x450 buzzer solution???
The Following User Says Thank You to protocolbg For This Useful Post:
Old 04-16-2005, 13:44   #238 (permalink)
kardelen gsm's Avatar
Member: 133173
hi all
i have e 715..white lcd..i changed lcd..flex cable..but it same..pls help
best regards
Old 04-16-2005, 14:00   #239 (permalink)
Member: 38922
Originally Posted by kardelen gsm
hi all
best regards
MMI Resettet? Update?
GreetZ
Old 04-16-2005, 14:25   #240 (permalink)
Ionel's Avatar
Member: 81232
Hi i hawe a r210s dead i can flash and no response from phone .
Can someone help.
Tnx
***All Samsung Hardware Solution*** nafisd Samsung Hardware Repair Area 4 02-25-2013 10:26
***All Samsung Hardware Solution*** bunty2008 Samsung Hardware Repair Area 28 01-12-2013 04:24
All Samsung Hardware Solution bsat Samsung Hardware Repair Area 16 08-04-2012 12:32
Page generated in 0.37868 seconds with 12 queries
Content Relevant URLs by vBSEO
