Old 07-21-2011, 18:26   #1 (permalink)
luckymobile jalandhar's Avatar
Member: 1002949
Sonork: 100.1582346
unlocking gfone 301 and 411(aircel)
i want to know that gfone 301 and 411 is supported for unlock . today i unlocked one 301 and one 411 so i read the code in mmodule 3.97(latest version) the code was same for both phones 19183512 it worked too but there are two problems one is when i restart the phone it ask the code everytime , 2nd problem is that whichever sim you put in sim 1 slot phone will display "aircel" (these phones have only one sim locked to aircel having the 2 sim slot ) i want to know that 19183512 is universal temprary unlock code for gfone aircel? as i have to unlock these phones in large quantity another problem is when i tried to read the flash file backup for both the phones g301 readed successfuly while 411 failed to do so (it was successfuly readed with dragon thow ) sorry about posting the logs as gsmhosting server was down so i failed to do so because logs are in diffrent pc
Old 07-22-2011, 10:57   #2 (permalink)
Member: 1002949
Sonork: 100.1582346
there are logs
301
==== [7/21/2011 3:25:59 PM] ====
COM20 [VCP0] selected
module v3.97
Action: read unlock codes
unlock method: read codes
Model: Aircel-G301
Checking data, wait...
19200 autodetect
Initializing [6223:8A05:8A00]...
CPU: MT6223
high speed boot On
chip: 0011:BD39:000C
status: FF
Connecting at 19200, wait...
Release Power button now !
Phone detected, wait...
warning: wrong packet cs
Hardware: MT6223,E05
Date: 2000.00.00
Version: 1.0
Version: L132_JY01_F32_TXD_AIRCEL_Y97_T02_V02
Version: LENTEK23D_GEMINI_ULC_07B_HW
67 byte(s) read
imei: 91**************
connection Ok
178 byte(s) read
166 byte(s) read
Phone lock: Off
Network lock: Off
Network subset lock: Off
Service provider lock: Off
Corporate lock: Off
IMSI lock: Off
Auto lock: Off
Phone code: 1122
166 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 19183512
lock[2] code: + default
lock[3] code: + 1122
lock[4] code: - default
lock[5] code: - default
lock[6] code: + default
lock[7] code: + default
if phone do not ask for a code try: *983*8284#
if code is not accepted by phone:
- make full flash backup for emergency case
- flash phone with good eeprom file
- Power-On phone without sim-card
- Power-Off phone (do not remove battery)
- read unlock codes
- restore original imei
Finished, time used: 11 sec
Remove/Install battery now !
Old 07-22-2011, 10:58   #3 (permalink)
Member: 1002949
Sonork: 100.1582346
411
==== [7/21/2011 4:26:31 PM] ====
COM65 [Serial2] selected
module v3.97
Model: G-Fone-411-Aircel
19200 autodetect
CPU: MT6223
high speed boot On
chip: 0011:70E8:000C
status: FF
Date: 2000.00.00
Version: 1.0
Version: L98_AIRCEL_V8_0_6
Version: L90_HW
80 byte(s) read
imei: 91********************
connection Ok
185 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1122
173 byte(s) read
reading data...
972 byte(s) read
- read unlock codes
Finished, time used: 13 sec
Old 07-22-2011, 11:01   #4 (permalink)
Member: 1002949
Sonork: 100.1582346
failed flashing "read flash operation " for 411
==== [7/21/2011 3:59:05 PM] ====
module v3.97
Device: G-Fone-411-Aircel
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
boot packet size: 0400
Boot Done
====> Initialize ...
flash: 2088C4FFFF0043:2088C400000000
flash: ST Intel/Sharp ext [def 007Fx020000 0004x008000] 16Mb
otp offset: 00FE0000
Initialize Done
====> Set baud ...
921600
Set baud Done
====> Initialize bootcode ...
Initialize bootcode Done
====> Check firmware integrity ...
usb bootloader detect...
usb bootloader detect (phase #2)...
usb bootloader (chip) is absent
searching rom info...
warning: wrong cs at 0x00001754, retry...
search rom info finished
rom info structure: [standard] type (05)
TCL-ID is absent
rom info detection finished
rom info ver: 05
sw version: L98AIRCEL_PCB01_GPRS_MT6223P_S00.L98_AIRCEL_V8_0_6 .BIN
project-id: L98_AIRCEL_V8_0_6, 00000000
code offset: 00000000
ffs offset/size [01]: 00D00000/00300000
TCL-ID is absent
ffs/eeprom address assigned: 00D00000
operation aborted
Finished, time used: 19 sec
==== [7/21/2011 4:00:53 PM] ====
module v3.97
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
warning: wrong cs at 0x00000B54, retry...
read error recovered
warning: wrong cs at 0x00002B54, retry...
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
operation aborted
Finished, time used: 25 sec
==== [7/21/2011 4:01:34 PM] ====
module v3.97
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
warning: wrong cs at 0x00001B54, retry...
error: too many retries during read operation
TCL-ID is absent
rom info ver: 05
TCL-ID is absent
operation aborted
Finished, time used: 23 sec
==== [7/21/2011 4:02:02 PM] ====
module v3.97
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
warning: wrong cs at 0x00000354, retry...
error: unexpected data: 1FC4CBDA32CB3B3A3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B3B 3A3B3B3B3B3E3B3BBB3BBAFBC7C4C3C4C4C4C7C4C4C4C4C6C6 C7C6C3C6C7C3C7C7C3C3C7C3EBD3DFEBFBFBFB3B3B3B3B3B3B 3B3B3B3B3B3B3B3B3B3B3B3B393BBB3B3ABBD3C4C4C5C5C7C6 C5C5C7C6C2C6C6C2C6D3C3CFC7C3C7C3DBDB3A3B3A3B3B3B3B 3B3B3A3B3B3A3A3C313E1393DBCEC4C4C4C4C4C4C6C4C6C6C7 C6C7C2C6C6C3C6C3C3C2CBFBEB9BBBBB3B383A3B3B3B3B3B3B 3B3B3B3B3B3B3B383ABB3B3BD3FBC2C5C4C4C4C6C4C4C6C7C7 C6C3C7C6C3C3E3DBD3DBFBD3FBBB3B3B3B3B3B3B3B3B3B3B3B 3B3BBB3B3B383CC1F3C6CBC3C4C4C6C4C4C6C4C3C6C2C7C7C2 C3C7C3C3C1
error: wrong answer: BB
warning: rom info information not found, possible reasons:
- old firmware type w/o rom info information
- empty (completely or partially erased) flash chip
- damaged firmware
- damaged hardware (bad soldered or damaged flash chip)
> if phone works fine just ignore this warning <
ffs/eeprom address can not be detected, value from database assigned: 00D00000/00300000
sec info (detailed) detection...
searching sec info#1...
error: wrong answer: 3B
search sec info#1 finished
error: wrong answer: FA
error: connection lost
Finished, time used: 26 sec
==== [7/21/2011 4:09:07 PM] ====
module v3.97
Action: read flash
====> Boot ...
error: can't detect device
in case of initial connection problem: on/off "Boot baudrate autoselect"
Boot Fail
==== [7/21/2011 4:15:09 PM] ====
module v3.97
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
==== c:\InfinityBox\MModule\MModule.exe [7/21/2011 4:15:55 PM] ====
Infinity-Box - About
BB5 Easy Service Tool [BEST] -
Infinity-CDMA Tool
PinFinder Adapter
Language Pack Editor Dongle
Content Extractor Dongle
Old 07-22-2011, 11:03   #5 (permalink)
Member: 1002949
Sonork: 100.1582346
any permanent unlock solution
Old 07-22-2011, 14:59   #6 (permalink)
Member: 1002949
Sonork: 100.1582346
please let me confirm permanent unlock is available?
Old 07-23-2011, 15:34   #7 (permalink)
Member: 1002949
Sonork: 100.1582346
read 311 gfone error
module v3.97
Device: G-Fone-311-Aircel
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
chip: 0011:1C8D:000C
status: FF
Boot Done
flash: 98000300000001:2BEA0000000000
flash: Toshiba AMD/Fujitsu std [T 0008x004000 007Fx020000] 16Mb
Initialize Done
====> Set baud ...
921600
Set baud Done
warning: wrong cs at 0x00002754, retry...
rom info structure: [protected] type (04), 1 record(s)
TCL-ID is absent
error: wrong answer: 91
error: can't read startup code area #1
rom info ver: 04
sw version: XG01_GSM_K103_INDIA_128_PCB01_GSM_MT6223P_S00.V1_0 0_01_M100106EN0-I02.BIN
project-id: V1.00.01_M100106EN0-I02, 23DEAA2C
ffs offset/size [01]: 00E00000/00200000
TCL-ID is absent
ffs/eeprom address assigned: 00E00000
operation aborted
Finished, time used: 20 sec
Old 07-23-2011, 18:56   #8 (permalink)
Member: 1002949
Sonork: 100.1582346
where is support ? Why there are problems in reading flash files
Old 07-24-2011, 08:34   #9 (permalink)
Member: 1002949
Sonork: 100.1582346
311 flashing read error
module v3.97
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
warning: wrong cs at 0x0000A754, retry...
warning: wrong cs at 0x0000BF54, retry...
TCL-ID is absent
error: wrong answer: D7
rom info ver: 04
TCL-ID is absent
error: wrong answer: 00
Finished, time used: 35 sec
Old 07-24-2011, 08:36   #10 (permalink)
Member: 1002949
Sonork: 100.1582346
temporary unlock works
gfone 311 too
module v3.97
Model: G-Fone-311-Aircel
19200 autodetect
CPU: MT6223
high speed boot On
status: FF
Date: 2000.00.00
Version: 1.0
Version: V1.00.01_M100106EN0-I02
Version: BIRD23C_GEMINI_08A_HW
80 byte(s) read
imei: 9******************
connection Ok
186 byte(s) read
38 byte(s) read
Phone lock: Off
Phone code: 1122
174 byte(s) read
reading data...
972 byte(s) read
lock[1] code: + 90750051
- read unlock codes
Old 07-26-2011, 10:12   #11 (permalink)
YellowBoss's Avatar
Member: 1043909
module v3.97
Action: read flash
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
status: FF
Boot Done
Initialize Done
====> Set baud ...
921600
Set baud Done
TCL-ID is absent
rom info ver: 04
TCL-ID is absent
operation aborted
it may be a result of bad cable/drivers. Try to use FTDI cable instead of your existing cable and see results.
Old 07-26-2011, 10:14   #12 (permalink)
YellowBoss's Avatar
Member: 1043909
Are you sure that 311 model unlocked temporary but not permanently ?
Old 07-27-2011, 10:34   #13 (permalink)
Member: 1002949
Sonork: 100.1582346
i am using gpgdragon cable (detecting by their own software ) because my infinity pinfinder cable is damaged
Old 07-27-2011, 10:37   #14 (permalink)
Member: 1002949
Sonork: 100.1582346
i suspect that it worked because when i inserted other sim rather than aircel it showed real banner i was in hurry so i did'nt check it was relocked or not
Old 08-23-2011, 15:52   #15 (permalink)
Sony_computers's Avatar
Member: 570022
COM3 [VCP1] selected
module v4.01
Action: "sp-unlock"
unlock method: standard fast
Unlock procedure can be faster if you skip ffs/eeprom area backup procedure.
Do you want to disable ffs/eeprom backup ?
ffs/eeprom backup disabled
====> Boot ...
19200 fixed
Connecting, wait...
CPU: MT6223
high speed boot On
chip: 0011:4FEA:000C
status: FF
Boot Done
Initialize Done
====> Set baud ...
115200
Set baud Done
TCL-ID is absent
rom info ver: 05
sw version: L98AIRCEL_PCB01_GPRS_MT6223P_S00.L98_AIRCEL_V8_0_5 .BIN
project-id: L98_AIRCEL_V8_0_5, 00000000
TCL-ID is absent
Check firmware integrity Done
====> Check firmware content ...
Check firmware content Done
====> Backup required data ...
Backup required data Done
====> Patch required data ...
lock area found
lock area found
Patch required data Done
====> Special operation ...
detecting parameters to apply patch area 1...
error: area 1 can not apply patch
Special operation Done
====> Write ...
Write: lock-area-1
Write: lock-area-4
Write Done
====> Finalization ...
Finalization Done
Finished, time used: 2 min 17 sec
IR between 6150 and IBM TP 600 favdijck Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 11-15-2011 12:08
FREECALLING HACKED SIM CARDS AND PROGRAMMERS SEE FREECELL'S NEW SITE FOR MORE!!! FREECELLUK Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-26-1999 22:48
wt603 and .pkd ARt Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 0 06-13-1999 19:18
Page generated in 0.44703 seconds with 11 queries
Content Relevant URLs by vBSEO
