Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 08-20-2008, 21:37   #1 (permalink)
Member: 58180
Any chance to repair - IMEI: 12345610654321? on Nokia 5610?
Dear Nokia BB5 Experts,
I've one Nokia 5610 with IMEI: 12345610654321?
History of phone: It was an empty phone with no imei from factory.
Someone tried to get it alive but had no lock. Since, is has this strange imei.
I've tried with several Software to read ASK but have no success (File is always empty).
Trying to Flash end with an error in JAF: Cmt root hash keys are wrong... aborting!
Here some LOG from JAF:
Searching for phone...
found
Reading info...
Battery level: 3765 mV
MCU SW version: V 04.81
22-11-07
RM-242
(c) Nokia
HW version: 1000
PCI version:
RFIC version:  17141714
DSP version:
ICPR71_07w43
LCD version: SHARP
PPM version: V 04.81
22-11-07
RM-242
(c) Nokia
C
BT MCM version: 2222-101B
Retu version: 15
Tahvo version: 22
Content Pack version: Content: c
V 04.81
22-11-07
RM-242
(c) Nokia
Production serial number: CNI177319
Product code:
Module code: 0203378
Basic production code: 0515121
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 12345610654321?
IMEI spare to net: 1A 32 54 16 60 45 23 01
IMEI SV to net: 13 32 54 16 60 45 23 11 F6
Master Code: 1370355423
Done!
Lese imei...
C:\Programme\ODEON\JAF\ProgData\12345610654321?_CR T_backup_2120208.pm
Fertig!
Backup CRT OK!
P-key nokia module version 01.01
Init usb communication...
Found
Reading SW version...04.81
Reading battery value...3754 mV
Init usb flashing...
Reading flashid... 128k flash detected.
CMT: 220C00EC <=> SAMSUNG (SEC) -> K5G1257ATM
APE: 00000000 <=> Flash -> not detected
Verifing ADL communication... Status byte 2
Is threre a chance to revive this phone by Software or should I throw it in the garbage?
Thank you very much!
Kind regards
The Following User Says Thank You to CologneGSM For This Useful Post:
Old 08-20-2008, 22:11   #2 (permalink)
g-gabber's Avatar
Member: 192652
Sonork: No
Thanks Meter: 121
You need RPL ...
Here is described your problem and solution ... F.A.Q About BB5 Contact Retailer Locked For All Provider & RPL WRITE.
The Following User Says Thank You to g-gabber For This Useful Post:
Old 08-20-2008, 22:19   #3 (permalink)
Member: 447849
Sonork: 100.1604076
Thanks Meter: 566
IF you have CRT backup then you will restore CRT easily
and another procedure .... you will have to buy rpl for your fone
B.R.,
Sonu
found
Reading info...
22-11-07
RM-242
(c) Nokia
HW version: 1000
PCI version:
DSP version:
ICPR71_07w43
LCD version: SHARP
22-11-07
RM-242
(c) Nokia
C
Retu version: 15
Tahvo version: 22
V 04.81
22-11-07
RM-242
(c) Nokia
Product code:
Flash code:
Order number:
ATO:
Default SN type:
Done!
Lese imei...
Fertig!
Backup CRT OK!
Found
Kind regards
Old 08-20-2008, 22:21   #4 (permalink)
Service4Gsm.de's Avatar
Member: 811992
Sonork: 100.1584257
Thanks Meter: 162
Hello
Whom you want mobile phone bottles, dan you have two possibilities once with 7 pin Fbus cable bottles or with USB cable, but whom mobile phone is geflasht the dead, then must you then the Manuel bottles!
Old 08-20-2008, 22:49   #5 (permalink)
Member: 58180
@g-gabber
As I wrote before I can't read any ASK. The file is always empty.
Where can I find a PM File for Nokia 5610?
@sonujawed
I have no CRT Backup
@Service4Gsm.de
Sorry, I didnt understand what you mean.
You can write me german by a PM
Old 08-21-2008, 11:53   #6 (permalink)
Member: 447849
Sonork: 100.1604076
Thanks Meter: 566
You Have To Calculate RPL For Your Fone
B.R.,
Sonu
@g-gabber
@sonujawed
@Service4Gsm.de
Old 09-11-2008, 20:42   #7 (permalink)
dsd
Member: 307049
Thanks Meter: 47
Have the same problem whit a 5610b
Any solution
The phone not have imei.... are virgin....
*#92702689# Serial number -------------
have write pm and now have imei in *#92702689#
but *#06# 123456
Read ask but error on calculate rpl
Old 09-12-2008, 11:22   #8 (permalink)
halongmobile's Avatar
Member: 45580
Thanks Meter: 48
yes i have 2 psc n6500s .........read ASK by (dss2, MT-BOX ) sent SEVER buy rpl.........not ok ? help me
Old 09-12-2008, 11:37   #9 (permalink)
software zone's Avatar
Member: 494167
Thanks Meter: 294
read ask with dss get rpl from (rpl father server)calcolate rpl perfect.i was also have this problem,phone imei was 12345....now phone is working 100% ok.
Old 09-12-2008, 12:18   #10 (permalink)
Formingus's Avatar
Member: 322417
Thanks Meter: 510
on some phones like on my nokia 5700 even rpl can't correct imei
Write rpl ok same thing imei 12345610654321?
Working on that
wbr Formingus
Old 09-12-2008, 12:38   #11 (permalink)
Member: 798117
Thanks Meter: 266
i have 6680 its rpl is currupt and imie 12344557878?
after write rpl set was ok work good and imie was same 12344557878?
Old 09-12-2008, 13:00   #12 (permalink)
Crazy Poster
Member: 6801
Thanks Meter: 14
you will not be able to write a new IMEI to an "empty-board" phone.
even if you create ask file and sent it for rpl calculation, nokia server will not process it because the RAP-ID is not in the nokia-database, therefore no IMEI is assigned to this RAP-ID and therefore you canīt get rpl file.
phone will also not accept rpl file from any other phone(like it was possible on DCT4..)
only solution for bb-5 empty board is, to put RAP from another used-phone(that had correct IMEI) into your "empty board" and then make ask/rpl procedure.
regards,
The Following User Says Thank You to gsmdeluxe For This Useful Post:
Old 09-12-2008, 13:30   #13 (permalink)
Formingus's Avatar
Member: 322417
Thanks Meter: 510
regards,
talk about rpl file that can be calculated
personaly for my self i know that my imei is on database
but after write rpl imei is again corrupted so
i don't ask for rpl i save by my self
Regards
Old 03-01-2009, 08:30   #14 (permalink)
kapilgupta's Avatar
Member: 681945
Thanks Meter: 413
from where can i get bb5 rpl?and how much logs?
Old 03-01-2009, 18:32   #15 (permalink)
Member: 332730
Thanks Meter: 68
i have read pm file 308 for rm-84 (n70) after flash there is error in cell phone start up failed contact retailer anyone help me plz
how to repair Watch Dog on Nokia 6263 RM-207 after unlocking with Mx-Key Boshko_Alfa MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 02-15-2010 14:50
is there any chance to repair this w/o bkp? cristi_slob MXKEY Nokia Flasher and Unlocker (by Alim Hape) 1 12-24-2009 05:18
Any chance to unlock Nokia 6630 which locked by 3 network on UK ? D4yw4lk3r Nokia Base Band 5 ( BB-5 ) 4 10-08-2006 06:46
Any chance to reset user lock on T39m GSM Deals Old Ericsson Phones & Sony Phones 5 06-04-2002 20:00
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.40122 seconds with 8 queries
Content Relevant URLs by vBSEO
