Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 09-01-2008, 10:32   #1 (permalink)
svchost's Avatar
Member: 841080
Thanks Meter: 163
how reset nokia 5310 xpressmusic security code????
hi brothers how can i reset nokia 5310 xpressmusic security code i have usb cable not service cable ......
Old 09-01-2008, 11:42   #2 (permalink)
Member: 676024
Thanks Meter: 24
try jaf & connect usb mode
Old 09-01-2008, 11:46   #3 (permalink)
frnd_4_gsm's Avatar
Member: 279604
Sonork: 100.1582858
Thanks Meter: 202
Use 5310 F-bus Cable With Modified (3k Registor) In Side The Cable
Old 09-01-2008, 11:51   #4 (permalink)
gsmtime's Avatar
Member: 541092
Thanks Meter: 59
Just do factory default if reading codes not be accepted when doing several attempts.
The Following User Says Thank You to gsmtime For This Useful Post:
Old 09-01-2008, 12:54   #5 (permalink)
murthyy's Avatar
Member: 265133
Thanks Meter: 149
i dont think u can reset ur code with usb cable
The Following User Says Thank You to murthyy For This Useful Post:
Old 09-01-2008, 15:41   #6 (permalink)
sorinm's Avatar
Member: 10964
Thanks Meter: 280
on some models it works by dead usb flashing but is the 'long way around' solution
The Following User Says Thank You to sorinm For This Useful Post:
Old 09-01-2008, 17:14   #7 (permalink)
vmin81's Avatar
Member: 304251
Thanks Meter: 786
use modified fbus to put fone test mode then factory set or try try by dead usb method
Old 10-15-2008, 09:17   #8 (permalink)
Member: 217853
Thanks Meter: 13
its have only one solution,if you have only usb cable need to flash.
Old 11-13-2008, 14:27   #9 (permalink)
Member: 899760
Sonork: jomanuelin
then u buy service cable
Old 11-13-2008, 15:27   #10 (permalink)
hicvb7's Avatar
Member: 483440
Sonork: 1577958
Thanks Meter: 134
You can reset the phone code by usb cable but after full flash with Factory Set ticked
Regards
Old 11-14-2008, 01:13   #11 (permalink)
richiricherd's Avatar
Member: 594580
Thanks Meter: 132
Just connect a resistor 4.7 k between grond (-) and bsi (o) on battery contacts to force local model, then connect to pc and use NSS for factory reset, dont need to flash..
Old 11-14-2008, 10:50   #12 (permalink)
robean's Avatar
Member: 538410
Sonork: 100.1590750
Thanks Meter: 149
just do set defualt in UB or read info for ur code
Old 11-14-2008, 11:00   #13 (permalink)
xerraco's Avatar
Member: 890926
Thanks Meter: 1,107
Thread Started in Sep. 1, I think its all OK now.
Old 11-14-2008, 14:03   #14 (permalink)
Member: 597927
full factory with JAF
Old 11-15-2008, 04:43   #15 (permalink)
.::MD_AKTER::.'s Avatar
Member: 552244
Sonork: 100.1578827
Thanks Meter: 176
Who told you Security lockable phone will be connect with usb mode. Can you do it ?
NCK Code for Nokia 5310 XpressMusic bifftard Nokia Base Band 5 ( BB-5 ) 1 12-23-2008 19:01
Nokia 5310 XpressMusic equalizer issue elchirurgo Nokia Base Band 5 ( BB-5 ) 3 05-06-2008 16:57
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.31006 seconds with 8 queries
Content Relevant URLs by vBSEO
