Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 08-11-2010, 10:49   #1 (permalink)
Member: 481933
Sonork: 100.1582701
Thanks Meter: 107
nokia 5130 strange charger not supported
hi friends
nokia 5130c when off mode it show continuesly charging but battery not stored
& in on mode it show charging for 2 sec then charger not supported
i replaced resistance r2071 near sim tray but same
remove charging track capister but same
reball betty ic but same
replace betty ic but same
anyone solve this problem
thanks in advance
wbr vicky
The Following User Says Thank You to nazar2008 For This Useful Post:
Old 08-11-2010, 11:24   #2 (permalink)
Member: 1005207
Sonork: 100.1613287
Thanks Meter: 39
brothers try to make music like rolling die if you die before the first song should RPL
The Following User Says Thank You to iyus_service For This Useful Post:
Old 08-11-2010, 12:49   #3 (permalink)
Member: 481933
Sonork: 100.1582701
Thanks Meter: 107
Originally Posted by iyus_service View Post
brothers try to make music like rolling die if you die before the first song should rpl
brother i did as u say but it is ok . Songs play without any problem .
Pls help
thanks for replay
wbr vicky
Old 08-11-2010, 13:23   #4 (permalink)
Member: 1005207
Sonork: 100.1613287
Thanks Meter: 39
try change ic avilmas if you still can not check path BSI
Do not forget to click the thank
Old 08-12-2010, 06:12   #5 (permalink)
Member: 481933
Sonork: 100.1582701
Thanks Meter: 107
try change ic avilmas if you still can not check path bsi
do not forget to click the thank
problem not solved yet to change availma ic its same
pls help expert
thanks in advance
wbr vicky
Old 08-12-2010, 07:10   #6 (permalink)
kiran84's Avatar
Member: 504441
Thanks Meter: 29
Dear remove betty ic and service the board with alma and fix betty ic and see...try it..good luck...
Old 11-06-2010, 16:55   #7 (permalink)
Member: 257418
Thanks Meter: 8
i have same problem in 5130 charger not supported
I changed BETTY chang Charging IC diode,
replace 47k but problem not solved
Old 03-10-2011, 06:53   #8 (permalink)
Member: 1423086
Thanks Meter: 4
yes i fase the problem charging continuous but battery no charged pls help me
Old 03-10-2011, 08:34   #9 (permalink)
PANTECH N B R's Avatar
Member: 927663
Sonork: www.pantechinfo.com
Thanks Meter: 38
[IMG]http://4.bp.********.com/_EBtMYGOEg0c/TSHQRyGdjVI/AAAAAAAAAhY/LDvGOtFkzsM/s1600/Nokia+2700c+charging+not+supported+solution..jpg[/IMG]
The Following User Says Thank You to PANTECH N B R For This Useful Post:
Old 08-04-2011, 07:11   #10 (permalink)
Member: 1508286
thanx bro, the solution was perfect for my 5130c
Old 08-27-2011, 17:06   #11 (permalink)
amit.alag's Avatar
Member: 373527
Thanks Meter: 64
solution is perfect 1000% good job bosssss
Old 04-12-2013, 14:19   #12 (permalink)
Member: 1915652
Sonork: ssailtd@gmail.com
Sir i want to bbm8520 charging ways track pls urgent........
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-05-2014 11:33
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 29 06-27-2014 21:31
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 48 05-12-2013 13:07
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.37453 seconds with 8 queries
Content Relevant URLs by vBSEO
