Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Base Band 5 ( BB-5 )
Nokia Base Band 5 ( BB-5 ) Baseband-5 Phones: 2700 Classic , 2730 Classic , 3109c , 3110c , 3120c , 3250 , 3500c , 3600s , 3610 Fold , 3710 Fold , 3720 Classic , 5130 XpressM , 5200 / 5200b , 5220 XpressM , 5230 XpressM , 5300 / 5300b , 5310 / 5310b , 5320 , 5500 , 5530 XpressM , 5610 , 5630 XpressM , 5700 , 5730 XpressM , 5800 , 6085 / 6086 , 6110n , 6120c , 6121c , 6124c , 6125 , 6126 / 6133b , 6131 / 6133 , 6131 (NFC) , 6136 , 6151 , 6208 Classic , 6210n , 6212c , 6220c , 6233 , 6234 , 6260 Slide , 6263 , 6267 , 6270 , 6280 / 6288 , 6282 , 6290 , 6300 , 6300i , 6301 , 6303 Classic , 6500 Classic , 6500 Slide , 6555 , 6600 Fold , 6600 Slide , 6630 , 6650 Fold , 6680 , 6681 , 6682 , 6700 Classic , 6710 Navigator , 6720 Classic , 6730 Classic , 6760 Slide , 6790 Surge , 7210c , 7310c , 7370 , 7373 , 7390 , 7500 , 7510c , 7610c , 7900 , 8600 , 8800 arte , E50 , E51 , E52 , E55 , E60 , E61 , E61i , E62 , E63 , E65 , E66 , E70 , E71 , E72 , E75 , E90 , N70 , N71 , N72 , N73 , N75 , N76 , N77 , N78 , N79 , N80 , N81 , N82 , N85 , N86 , N90 , N91 , N92 , N93 , N93i , N95 , N95 8GB , N96 , N97 , N97 Mini , X3 , X6
Old 06-14-2009, 19:59   #1 (permalink)
Member: 691805
problem nokia n73 phone start-up failed. Contact the retailer.
when applying flash to this model, appears to me that, and also this.
Reading...
MCU SW version: V 05wk47v61.1
09-07-08
RM-133
(c) Nokia.
HW version: 7200
PCI version:
RFIC version:  17211721
DSP version: scarfe_mc.05wk46v50p2
Retu version: 15
Tahvo version: 22
Production serial number: CDE710461
Product code: 0515621
Module code: 0202856
Basic production code: 0545048
Flash code:
Order number:
Product specific data:
Long production SN:
ATO:
Default SN type:
IMEI plain: 354804014899774
IMEI spare to net: 3A 45 08 04 41 98 79 07
IMEI SV to net: 33 45 08 04 41 98 79 77 F8
LOCK STATUS:
CONFIG KEY: 0000000000000000
PROVIDER KEY: 0000000000000000
Provider: Unknown provider
Key Code count: 0, FBUS Code count: 0
as I solve this?
Old 06-14-2009, 20:06   #2 (permalink)
nasirkhan007's Avatar
Member: 553445
Sonork: 100.1585581
Thanks Meter: 8,181
Relock And Unlock Or Repair SL.........
The Following 2 Users Say Thank You to nasirkhan007 For This Useful Post:
Old 06-14-2009, 20:06   #3 (permalink)
masum_sohel's Avatar
Member: 852543
Thanks Meter: 2,250
write new rpl to solve it.............
The Following 3 Users Say Thank You to masum_sohel For This Useful Post:
Old 06-14-2009, 20:08   #4 (permalink)
Member: 146369
Thanks Meter: 118
If you do not have backup pm or RPL bacup, then you will have to buya new RPL
Old 06-14-2009, 20:15   #5 (permalink)
Member: 691805
not have backup pm or RPL bacup, there is some way to repair it?
Old 06-15-2009, 00:54   #6 (permalink)
Member: 182413
Thanks Meter: 350
try to use zulea Repair SL option.
Old 06-15-2009, 02:05   #7 (permalink)
Member: 691805
THAT DOES NOT WORK.:conf used:
Old 06-15-2009, 02:19   #8 (permalink)
xannix_7575's Avatar
Member: 847117
Thanks Meter: 68
it seems that your IMEI is still good make a back for it
then do ERASE but dont include PM area
do full flash, repair sl zone, write your bck up RPL
Old 06-15-2009, 03:27   #9 (permalink)
Member: 810100
Thanks Meter: 7
boss try use bb5 prince for contact retailer repair sl then unlock, , , , ,
http://www.mediafire.com/?sharekey=f...e6ba49b5870170
Old 06-15-2009, 03:59   #10 (permalink)
Member: 231600
Thanks Meter: 43
Only RPl file can help you!
Old 07-06-2009, 18:55   #11 (permalink)
Member: 574484
Sonork: 1584084
Thanks Meter: 29
i have n73 when power on show message phone startup failed contact the retailer.some time it working but some time show phone startup failed contact the retailer.i think its hardware fault.some body help me
JAF version 1.98.62
Detected PKEY: 9000CA92
Card life counter: 99.99%
P-key nokia module version 01.02
Detected JAF INTERFACE version: 01.B1, Driver version: 40000, Library version: 30107
JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\
JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\
JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\
JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Switching to serial...
Powering the phone...
Reading...
09-07-08
RM-133
(c) Nokia.
HW version: 6000
PCI version:
RFIC version: 17191719
Retu version: 15
Tahvo version: 21
Production serial number: SBH144666
Product code: 0529607
Module code: 0202855
Basic production code: 0527006
Flash code:
Order number:
Long production SN:
ATO:
Default SN type:
IMEI plain: 359738003248616
IMEI spare to net: 3A 95 37 08 30 42 68 01
IMEI SV to net: 33 95 37 08 30 42 68 71 F8
LOCK STATUS:
PROVIDER KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Searching for saved ini...
Checking for file C:\Program Files\ODEON\JAF\JAF_RM-133.ini
Saved INI not found, loading INI list...
Setting local mode...
Reading product code...
Product Code: 0529607
Searching for JAF saved location of ini...
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-133\
Searching for default location of ini...
Checking path: \Products\RM-133\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_3.0705.1.0.31_western_C00_PRD_cc.fpsx
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_rofx_3.0705.1.0.31_PRD.V11
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-133\N73_userarea_3.0705.1.0.31.U01
Languages in ppm: English,Simpl Chinese
Done!
Old 07-06-2009, 23:41   #12 (permalink)
Member: 1027923
Thanks Meter: 19
Relock And Unlock
try and post
Old 12-08-2009, 13:20   #13 (permalink)
yasintaj's Avatar
Member: 771334
Thanks Meter: 54
n73 phone startup failed contact the retailer hlp 9978509801 SOLUTION
Old 12-31-2009, 10:20   #14 (permalink)
yasintaj's Avatar
Member: 771334
Thanks Meter: 54
Old 12-31-2009, 10:39   #15 (permalink)
mobi_soft's Avatar
Member: 1126941
Sonork: 100.1651368
Thanks Meter: 2,302
here is 100000% solution...
http://www.ziddu.com/download/675228..._soft.rar.html
Nokia N73 Phone start-up failed contact the retailer powerplay83 Universalbox 10 12-10-2009 22:39
N73 Phone start-up failed. Contact the retailer. E-Tech Nokia Base Band 5 ( BB-5 ) 0 12-09-2006 22:42
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.53593 seconds with 9 queries
Content Relevant URLs by vBSEO
