Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 02-19-2010, 07:28   #1 (permalink)
Member: 1014826
Thanks Meter: 52
Thumbs up nokia 1200 Contents Package Extracting Failed: Process Failed, Repowering Mobile
1st Boot: Ok, DCT4, UPP: 2292 [Rh-99] [2.0.9.0]
2nd Boot: u3_2nd.fia, Ver: 4.79.0
Fl0: 0x01000000-0x013FFFFF,00208828,St M58MR032
Algorithm: u3_st_i.fia, Ver: 4.79.0
Algorithm Ok, MSID: 84167EAE3D758EDBC7F2EF394C
Decoded MSID: 3E4EBAE9-00110FA3-A8000000
Encoded FAID: 77688210-0C69F39F-8BFE0B0B
IMAGE: rh99_05.230
Area1: 0x01000000-0x0100FFFF Erased, Time: 00:01
Area2: 0x01010000-0x013AFFFF Erased, Time: 01:05
Area3: 0x013B0000-0x013EFFFF Erased, Time: 00:05
Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
MCU Flashing Completed, Time: 00:13
IMAGE: rh990_nai5.23mg
Area1: 0x01380000-0x013AFFFF Erased, Time: 00:03
CNT Flashing Completed, Time: 00:00
Extracting Contents Package ...
Init Local Mode Failed
The Following 6 Users Say Thank You to romey_singh2 For This Useful Post:
Old 02-19-2010, 07:43   #2 (permalink)
Ramzan khan's Avatar
Member: 405696
Thanks Meter: 146
earse full flash and then again write full flash.write pm.full factory set.if still problem then check hardware
Old 02-19-2010, 07:50   #3 (permalink)
farihabest's Avatar
Member: 617692
Thanks Meter: 306
its because of not goto to local mode for writing PPM file. So flash with UB and all will be okey.
OR
Erase.
Flash with latest version
then pm and ui settings
The Following 3 Users Say Thank You to farihabest For This Useful Post:
Old 02-19-2010, 15:56   #4 (permalink)
metals's Avatar
Member: 811779
Thanks Meter: 242
no need c**lone just fallow as above means just erease full then flash ui after write pm full factory setting every thing become ok don't care about version anyway 5.23 is the best
Old 02-19-2010, 17:38   #5 (permalink)
khalidjan's Avatar
Member: 624551
Sonork: 100.1584837
Thanks Meter: 578
just drop the down point. I mean the last point should not be touched with cable. Put some thing on the last point, flash it & post result.
Old 02-21-2010, 09:28   #6 (permalink)
Member: 981175
Thanks Meter: 3
entering into local mode/test mode is BSI path fault. check ur cable inside BSI resister( should be 5.1k).or press & hold pwr button of mobile whn msg appears entering local mode.
chk & post result.
The Following 2 Users Say Thank You to iets For This Useful Post:
Old 02-21-2010, 09:36   #7 (permalink)
sajohaker's Avatar
Member: 698071
Sonork: 100.1622915
Thanks Meter: 245
downgrade use old version and flash phone .....phost rezult.......
Old 02-21-2010, 10:26   #8 (permalink)
software zone's Avatar
Member: 494167
Thanks Meter: 294
use easy cable.100/100% tested even you can flash unlock with any device with out problem
Old 02-21-2010, 15:28   #9 (permalink)
shiburock's Avatar
Member: 973277
Thanks Meter: 195
Angry Contact service
Originally Posted by romey_singh2 View Post
1st boot: Ok, dct4, upp: 2292 [rh-99] [2.0.9.0]
2nd boot: U3_2nd.fia, ver: 4.79.0
fl0: 0x01000000-0x013fffff,00208828,st m58mr032
algorithm: U3_st_i.fia, ver: 4.79.0
algorithm ok, msid: 84167eae3d758edbc7f2ef394c
decoded msid: 3e4ebae9-00110fa3-a8000000
encoded faid: 77688210-0c69f39f-8bfe0b0b
image: Rh99_05.230
area1: 0x01000000-0x0100ffff erased, time: 00:01
area2: 0x01010000-0x013affff erased, time: 01:05
area3: 0x013b0000-0x013effff erased, time: 00:05
area4: 0x017c0000-0x017effff out of chip bounds
area5: 0x01fc0000-0x01feffff out of chip bounds
mcu flashing completed, time: 00:13
image: Rh990_nai5.23mg
area1: 0x01380000-0x013affff erased, time: 00:03
cnt flashing completed, time: 00:00
extracting contents package ...
Init local mode failed
contents package extracting failed:
Process failed, repowering mobile
use only easy cable then flash your phone
10000000000000000% your problem solved
br,
shibu rock
The Following 8 Users Say Thank You to shiburock For This Useful Post:
Old 02-22-2010, 21:56   #10 (permalink)
Crazy Poster
Member: 687988
Thanks Meter: 11
Thumbs up do ERASE first;
then full flash, 100% ok, tested by me.
The Following User Says Thank You to SMLATLAS For This Useful Post:
Old 02-23-2010, 04:23   #11 (permalink)
shanryzen's Avatar
Member: 743601
Sonork: 83392409
Thanks Meter: 93
if you use all of this ways that they gave 100% cpu problem
The Following User Says Thank You to shanryzen For This Useful Post:
Old 02-23-2010, 13:57   #12 (permalink)
StRaNgE PeRsOn's Avatar
Member: 391445
Sonork: 100.1583575
Thanks Meter: 361
try only MCU and CNT then flash PpM seperately
post results
Old 02-23-2010, 13:58   #13 (permalink)
Member: 391445
Sonork: 100.1583575
Thanks Meter: 361
If no luck then try to flash with latest version
Old 05-19-2010, 08:51   #14 (permalink)
-=Meltech09=-'s Avatar
Member: 1084363
Thanks Meter: 109
IMAGE: rh99_05.230
here is your 100% solution..
just follow this trick...
then fullflash it again
The Following 9 Users Say Thank You to -=Meltech09=- For This Useful Post:
Old 05-20-2010, 11:58   #15 (permalink)
Member: 901335
Sonork: 100.1652281
Thanks Meter: 144
use easy cable u r problem will be solve . tested 100% . after flash post result.
The Following User Says Thank You to bigmarsa For This Useful Post:
1200 Contents Package Extracting Failed sr8787 Nokia Hardware & Hardware Repair 8 09-28-2010 13:10
1200 Contents Package Extracting Failed sr8787 Nokia Hardware & Hardware Repair 10 08-25-2009 03:23
1200 Contents Package Extracting Failed sr8787 Nokia Hardware & Hardware Repair 1 08-20-2009 09:23
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.72090 seconds with 9 queries
Content Relevant URLs by vBSEO
