Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Saras Boxes > HWK
Old 05-28-2011, 09:38   #781 (permalink)
Odia The Ultimate's Avatar
Member: 4042
Thanks Meter: 23,714
Originally Posted by krishna24 View Post
hwk upgrade ok with support suit setup-v02.02.000.exe.But when i trying to instal hwk major suit setup v02.02.000.exe it shows An error(-5006:0x80070002)has occured while running the setup.Plz.help me
Download the file again.
Odia.
The Following 4 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 06-02-2011, 11:05   #782 (permalink)
Member: 110484
Thanks Meter: 15
Authentication stage error: Error: Server returned unrecognized reply help..
Old 06-02-2011, 11:35   #783 (permalink)
Member: 4042
Exclamation
SERVER STATUS - USE Panel V 2.3.0.7 - Upgrade/Installation/Support Server Problems
The Following 2 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 06-22-2011, 04:55   #784 (permalink)
Member: 834083
plzz help sir, install ufs hwk 2.02, install cannot continue, aborting
iDelete this folder C:\Program Files\InstallShield Installation Information\{585C5E36-62B1-4CA1-827B-83C4A4486CA5} -
Delete this folder C:\Program Files\InstallShield Installation Information\{E22E26FA-575A-4122-BB39-90321F1CF19C}
log update hwk
---------- HWK upgrade started:6/22/2011 8:27:21 AM ----------
-- Target Id : 62 CF 1 10
-- UFSx Boot : UFxBoot V2.2 (c) SarasSoft 2003.
-- UFSx Firmw.: UFS_USB V2.8 (c) SarasSoft 2007.
-- UFSx S/N : *************
-- Features : 00000001
-- Licence 5 : True
-- UFSx Vendor: TORNADO
-- HWK ID : ***********************
-- HWK Status : 1, DL: 0
Locating HWK Upgrade server...
HWK Upgrade server found!
Preparing connection to server...
Connecting to HWKUpgrade server...
Server connection successfully established.
Authenticating on server...
Authentication successfull.
Checking upgrade client version...
Your upgrade client is up-to-date.
Upgrading HWK...
HWK upgrade process completed.
---------- HWK upgrade finished:8:27:31 AM ----------
install HWK_Major_Suite_v02.02.000.exe,
i download twice this file
use xp sp2
Old 06-22-2011, 05:37   #785 (permalink)
GsmMunna's Avatar
Member: 66937
Sonork: 100.93433
Thanks Meter: 4,965
Must re-download hwk Major Setup & try to install again.!
Munna.
The Following User Says Thank You to GsmMunna For This Useful Post:
Old 07-02-2011, 09:39   #786 (permalink)
Member: 357827
Thanks Meter: 13
installation error with usb driver
he says that:
the current langage is not supported by the device installation wizard.
contact the vendor.
please give me solution.
The Following User Says Thank You to rajoarthur For This Useful Post:
Old 07-02-2011, 11:16   #787 (permalink)
Member: 4042
Originally Posted by rajoarthur View Post
he says that:
contact the vendor.
Update the driver manually, open device manager, right click UFSx device and select Update Driver Software and then select the folder:-
x:\Program Files\SarasSoft\UFS\UFS_USB_Driver
Odia.
Old 07-04-2011, 08:25   #788 (permalink)
Member: 357827
Thanks Meter: 13
Odia.
not accepted!!
still the same
Old 07-04-2011, 09:55   #789 (permalink)
Member: 1162991
Sonork: 100.1608.571
Thanks Meter: 4
hello Sir..
i have encountered to my hawk..
it sees..
BAD ENVIRONMENT :-1- BAD LIBRARY
Clean System for Obsollete USB Drivers
i already reinstall all of components my hawk..
then i installed again..But steel problem..huhu
[quote]my current version 2.2.00
any suggestion..
thanks and advance..
br:
Old 07-04-2011, 10:19   #790 (permalink)
Member: 4042
not accepted!!
still the same
You may still have the message but your drivers will have been updated and all is ok to proceed with the install.
Odia.
The Following User Says Thank You to Odia The Ultimate For This Useful Post:
Old 07-04-2011, 10:20   #791 (permalink)
Member: 4042
Is it not very clear that the message is about USB Drivers, not software.
Odia.
Old 07-04-2011, 11:47   #792 (permalink)
Member: 1162991
Thanks Meter: 4
Odia.
tell me how it fixed that problem sir..?
it's always show when i run HWK_SUPPORT_SUITE_SETUP.EXE.
i did reinstall all drivers,then install again,but dissame problem..
i can't used my hawk..
Old 07-05-2011, 08:37   #793 (permalink)
Member: 357827
Thanks Meter: 13
DPInst_32 driver can not be instaled with SP2.
What wrong please?
Old 07-05-2011, 11:16   #794 (permalink)
Member: 4042
What wrong please?
Odia.
The Following 3 Users Say Thank You to Odia The Ultimate For This Useful Post:
Old 07-26-2011, 15:45   #795 (permalink)
tavo_unlock's Avatar
Member: 817412
Sonork: 1618066
Thanks Meter: 53
Exclamation install hwk in two pc different
You can install hwk in two different pc how??
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 29 06-27-2014 21:31
I neeeeed NCDS 2.0!!!! plzz!!!! ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 06-16-2011 09:59
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.16873 seconds with 9 queries
Content Relevant URLs by vBSEO
