Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > SPT BOX
Old 10-24-2011, 23:55   #1 (permalink)
Registered User
Member: 1359163
Thanks Meter: 34
samsung s3600i network problem[SOLVED]
Hi brothers ,
I have problem with sams s3600i with restart and blinking
I flash this one pieces with flash file from spt support
then repair imei , and now I have problem with network
any solution to repiair network problem ? (how to write good eeprom , maybe this can help) ?
Old 10-25-2011, 17:45   #2 (permalink)
SPTTEAM's Avatar
Member: 535033
Thanks Meter: 17,738
press restore ee then select eeprom file and write it if havent eeprom file allready then get working phone press backup ee first and make backup eeprom from good phone
Old 10-25-2011, 22:58   #3 (permalink)
Registered User
Member: 1359163
Thanks Meter: 34
It`s possible to download good eeprom from spt support ?
Old 10-26-2011, 11:24   #4 (permalink)
SPTTEAM's Avatar
Member: 535033
eeprom file inside C:\program files\spt\E2p folder if there havent mean havent this phone eeprom just can read from good phone
Old 10-26-2011, 15:29   #5 (permalink)
Registered User
Member: 1359163
Thanks Meter: 34
maybe there is a bug in this model on spt program because
when i try to Restore ee, then I have
Press Power On Key ...
Connect Phone OK.
Initialize Phone ...
Timeout !
Total Time: 22.37 s
there is no way to search and set new eeprom from c:/program files
so what is the solution ?
Old 10-27-2011, 08:36   #6 (permalink)
SPTTEAM's Avatar
Member: 535033
its not bug i think u should try just via rj45 without connect usb and speed select 921600
Old 10-27-2011, 11:28   #7 (permalink)
Registered User
Member: 1359163
Thanks Meter: 34
When I change speed to 921600 and use only rj45 com,then still have
Connect Phone OK.
Timeout !
Total Time: 120.87 s
any solution ?
Old 10-27-2011, 17:32   #8 (permalink)
SPTTEAM's Avatar
Member: 535033
try another pc i think your pc have installed SE driver or box
Old 10-28-2011, 11:59   #9 (permalink)
Registered User
Member: 1359163
Thanks Meter: 34
I use, setool, dreambox, so I have installed s-e drivers, this is only way to uninstall it , to flash eeprom with spt ??
Old 10-28-2011, 17:10   #10 (permalink)
SPTTEAM's Avatar
Member: 535033
yes coz swift and sysol platform many phone use se chip thats why make conflict
Old 10-28-2011, 21:30   #11 (permalink)
Member: 1510100
Thanks Meter: 17
ow i have ask setool not work with spt i mean if u install setool worning for spt
please spt team explan
Old 10-28-2011, 21:46   #12 (permalink)
Registered User
Member: 1359163
Thanks Meter: 34
YES BRO, but in oldest version I write eeprom to sams e250 , and this procedure be usefull. In this model s3600I this procedure is not active.
Today, I uninstall all samsung drivers, restart pc, install spt with samsung drivers, but still same problem.
Old 10-28-2011, 23:47   #13 (permalink)
wgmmmx1's Avatar
Member: 1139057
Sonork: 100.109924
Thanks Meter: 3,584
Man can you read ?? Problem are SE drivers no samsung.
Install spt software on computer that you not have SE box installed or uninstall ALL SE DRIVERS after uninstall all SAMSUNG drivers and after try and now will work ok.
Old 10-30-2011, 23:42   #14 (permalink)
Registered User
Member: 1359163
Thanks Meter: 34
Yes, bro , but I try on two othere computer (never s-e drivers installed) and still same problem , better check this bug,
Old 10-31-2011, 10:20   #15 (permalink)
SPTTEAM's Avatar
Member: 535033
here i have tested mate without test i not answer you here work may be your cable or box problem ?
Sim card sleep mode problem with 6130 ratzfatz Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 04-21-2014 05:52
6150 Lock Problem Zeljko Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-16-2013 09:16
GId1 problem old_man Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-18-2006 16:21
6110 5.47 sw unlock problem gsms Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 11-21-1999 19:43
HELP: Problem with 5110 Xabi Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 07-16-1999 01:44
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.62511 seconds with 8 queries
Content Relevant URLs by vBSEO
