Unlock Server
Old 12-31-2010, 09:00   #1 (permalink)
Member: 137891
Thanks Meter: 19
samsung i5503
how to reset user code with zx3
Old 03-17-2011, 10:10   #2 (permalink)
Member: 701376
Sonork: 100.1611608
Thanks Meter: 57
i900,i5700,i5500,i5503 and other samsung full reset tricks
Tested I900 Hard Reset Codes
Step by Step Follow The Tricks To Get
1. REMOVE BATTERY & PUT IT BACK
2. HOLD VOLUME UP BUTTON & MIDDLE BUTTON (HOME BUTTON)
3. WHILE HOLDING THIS TWO BUTTON PRESS POWER BUTTON AND REALEASE(PRESS POWER BUTTON ONLY ONCE)
4.IT WILL POP UP WITH HARD RESET MENU
5. SCROLL DOWN TO FACTORY RESET WITH VOLUME DOWN BUTTON THEN PRESS CENTER BUTTON OR HOME BUTTON
6. THEN PRESS VOLUME DOWN BUTTON TO SELECT YES FACTORY SETTINGS THEN PRESS CENTER BUTTON
7. SELECT REBOOT DEVICE AND PRESS CENTER BUTTON
TESTED 1000% WORKING
Tested in I5503 Full Reset
Volume UP + Home + Power
and you should get the options menu reset.
tested in a new
samsung galaxy
Aya Balo Labat Karuman(ito bago lang kahapon)
Before you decide to flash the phone, try this should help in most cases...
First insert correct sim card power the phone and wait until the phone turns on, call the card from another phone and answer the call ... while the connection is activated, press the back button and you'll be in the menu, go into the dialer and click on the new call while the old is still active, then enter * 2767 * 3855 # and phone will return to the factory defaults on the condition as when it was taken out of the box .... make sure the connection must be switched on at all times while on the menu.
Dagdag pa......
Samsung Android Secret Codes
*#*#4636#*#* - Phone Information
[/URL]*2767*3855# - Hard Reset
*#*#7780#*#* - Factory Reset
*#*#7594#*#* - Change End Call/Power Option
*#*#197328640#*#* - Service Mode
*#*#273283*255*663282*#*#* - File Copy Screen (Backup Media Files)
*#*#526#*#* - WLAN Test
*#*#232338#*#* - Shows WiFi MAC address
*#*#1472365#*#* - GPS Test
*#*#1575#*#* - Another GPS test
*#*#232331#*#* - Bluetooth test
*#*#232337#*# - Shows Bluetooth device address
*#*#8255#*#* - GTalk Service Monitor
Codes to launch various Factory Tests:
*#*#0283#*#* - Packet Loopback
*#*#0*#*#* - LCD test
*#*#0673#*#* - Melody test
*#*#0842#*#* - Device test (Vibration test and BackLight test)
*#*#2663#*#* - Touch screen version
*#*#2664#*#* - Touch screen test
*#*#0588#*#* - Proximity sensor test
*#*#3264#*#* - RAM version
Codes to get Firmware version information:
*#*#4986*2650468#*#* - PDA, Phone, H/W, RFCallDate
*#*#1234#*#* - PDA and Phone
*#*#1111#*#* - FTA SW Version
*#*#2222#*#* - FTA HW Version
*#*#44336#*#* - PDA, Phone, CSC, Build Time, Changelist number
Old 06-10-2011, 05:43   #3 (permalink)
Member: 1110847
Thanks Meter: 4
[QUOTE=haron_d;7086416]i900,i5700,i5500,i5503 and other samsung full reset tricks
tested in a new
samsung galaxy
Dagdag pa......
*#*#44336#*#* - PDA, Phone, CSC, Build Time, Changelist number[/QUOT
any solution pls no luck for me...
Old 10-28-2011, 09:13   #4 (permalink)
Member: 1594469
Thanks Meter: 4
boss ilan beses q poh trinay.....ayw lumabas ng hard reset menu..pero tnx sdin poh .......
Old 12-17-2011, 22:07   #5 (permalink)
amit kanpur's Avatar
Member: 1033905
Sonork: amitsharma
Thanks Meter: 797
samsung i5530 hard reset not work ..................any solution
Old 12-23-2011, 08:50   #6 (permalink)
Member: 1215464
Thanks Meter: 3
Old 02-15-2012, 12:47   #7 (permalink)
karnataka's Avatar
Member: 161943
Sonork: 100.1609577
Thanks Meter: 7
not working
not working for i5503
Old 02-16-2012, 03:21   #8 (permalink)
Member: 1455284
I try this, is not working for i5503
lots of service manuals Nokia, Siemens Sony Samsung etc. -=KnOeFz=- GSM Mobile Links 4 11-16-2011 07:42
Samsung service soft. fido Samsung Flashers, Software, Firmware. 4 01-20-2011 07:17
I need pinout for samsung a100 laiyc x1x to x45/x50 1 03-31-2001 22:47
Samsung SGH-200 (Help me -I need eeprom.) jonwillow Old Ericsson Phones & Sony Phones 0 06-23-2000 09:38
I Trade software for Samsung hercules Old Ericsson Phones & Sony Phones 0 05-27-1999 14:14
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.34305 seconds with 8 queries
Content Relevant URLs by vBSEO
