Unlock Server
Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 4 / 4S
iPhone 4 / 4S iPhone 4 / 4S
Old 08-24-2010, 20:56   #1 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 319
Cannot listen on port 80! TSS Server will not work
08/25/2010 00:44:29.531 NOT running as administrator OR your hosts file is not editable - Cannot listen on port 80! TSS Server will not work!
Old 08-24-2010, 21:21   #2 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 319
08/25/2010 01:20:03.015 The Real Firmware Umbrella - v4.02.05 by semaphore
08/25/2010 01:20:03.031 For help click here
08/25/2010 01:20:03.031 Connect a device to continue...
08/25/2010 01:20:03.171 NOT running as administrator OR your hosts file is not editable - Cannot listen on port 80! TSS Server will not work!
08/25/2010 01:20:03.187 Caching shsh files...
08/25/2010 01:20:03.203 Found [2] shsh files to cache...
08/25/2010 01:20:03.484 Cached [2] shsh files
08/25/2010 01:20:05.031 You are using the current version of TinyUmbrella.
08/25/2010 01:20:05.421 Device Detected - Device: iPhone3GS 4.0.2 (8A400) Model: MC133B/A Name: iPhone UUID: FC12F470E69120EFFD2E45DB19E50A02FAD01A39 Baseband: 05.13.04 - 6.4_M3S2
why TSS Server not opening up ?
Old 08-24-2010, 22:52   #3 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 319
Anyone have this issue before ??
Please help me out
b/c these addresses not working ...
74.208.105.171 gs.apple.com
#127.0.0.1 gs.apple.com
74.208.10.249 gs.apple.com
I have all the backups in SHSH format ...
what is wrong here .
Old 08-24-2010, 23:06   #4 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
Thanks Meter: 98
close all programs like web browser's icq msn skype , that could posibly use the port 80 ,
even itunes and try again
Old 08-24-2010, 23:48   #5 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 319
All applications closed but still Tss server not connects ... Dont know why the Fcuk ...
But i solved the problem by editing hosts file .. unfortunately i was editing wrong Hosts file which was made by Tinyumbrella sofware ..
Goto Folder Windows/system32/drivers/etc
then
Goto Tools , Folder Option , View & Untick " Hide Protected Operating System Files ( Recommended ) "
then the Other Hosts file will showed up ..
Add address 74.208.105.171 gs.apple.com ... & ready to BOOM
Old 08-25-2010, 00:11   #6 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
Thanks Meter: 98
glad to hear you made it up rock that iphone
Old 08-29-2010, 00:33   #7 (permalink)
falcon2's Avatar
Member: 116295
Thanks Meter: 12
Hallo everybody
i have this problem on 1 week and i can not fix it.
it always shows "NOT running as administrator OR your hosts file is not editable - Cannot listen on port 80! TSS Server will not work"
i edited hostsfile on folder Windows/system32/drivers/etc and i run as a Admin, but it did not help.
and when i testing in my friends computer the TSS server working
what is problem on my pc??
check please here if this is correct!
Old 08-29-2010, 15:20   #8 (permalink)
falcon2's Avatar
Member: 116295
Thanks Meter: 12
What is wrong here,why nobody wants to help me???
Old 08-30-2010, 17:55   #9 (permalink)
Member: 1382479
Had the same problem but ... no need for Tiny Umbrella as you already modified your hosts file (as I read here: Can't edit "hosts" file - SiNfuL iPhone). So you could try that!
The Following User Says Thank You to paximadia For This Useful Post:
Old 08-30-2010, 21:07   #10 (permalink)
ebry's Avatar
Member: 127240
Thanks Meter: 80
How to check what is running on port 80
Open Command Prompt window by typing Cmd in Run command box or Start Search, and hit Enter.
Type in the following netstat command:
netstat -o -n -a | findstr 0.0:80
The following line of results should be returned:
TCP 0.0.0.0:80 0.0.0.0:0 LISTENING (????) <- here you will see process IP or PID
Now open Windows Task Manager ( Ctrl+Alt+Del)
Go to Precesses -> View -> Select Columns and mark PID (Process Identifier)
Close Windows Task Manager and open again. Now check PID on the list and google the name.
The Following 2 Users Say Thank You to ebry For This Useful Post:
Old 09-06-2010, 21:53   #11 (permalink)
Member: 1043229
Hello
if you have kaspersky on your pc disable it
it happend to me so i disabled the kaspersky and it worked perfectly
try it
kaspersky is blocking the tss server
Old 09-06-2010, 22:16   #12 (permalink)
falcon2's Avatar
Member: 116295
Thanks Meter: 12
try it
I have Eset Nod32
and i disabled when i run tss server but it did not help
Old 09-07-2010, 06:00   #13 (permalink)
iki
iki's Avatar
Member: 61851
Sonork: 100.1604862
Thanks Meter: 98
try it right click on tinyumbrella and run as administrator ?
Old 09-07-2010, 12:53   #14 (permalink)
Member: 442749
Thanks Meter: 16
Umbrealla software will identify ECID or We have to write ECID?
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
"Deskey Device driver not found" ?? Please help DivAdonis Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-28-1999 14:56
how the **** do i make wintesla 6.03 work Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-16-1999 08:41
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.42732 seconds with 8 queries
Content Relevant URLs by vBSEO
