Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Chinese Models & Cloned Phones All China Phone Platforms like (MTK, Spreadtrum.. etc.) Cloned Nokia Nokla & Motorola . etc. Phones are included |
| | #1 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Oct 2008 Location: Bangledashe ctg
Member: 884989 Status: Online Sonork: 12000 Thanks: 945
| Repair Display Problem Of China Phone China Mobile Display Type- 1. Flex system 2. Connector/socket system Display Problem Come From- 1. Display Damage/Broken/ Broken Microchip area in display 2. Flex and parts damage 3. connector damage on both (pcb and display flex) 4. wrong software. 5. Display line broken from display connection to CPU. 6. CPU internal display section Damage. 1. Display Damage/Broken/Broken Microchip area in display For this type of problem, have no way without display change (every one know it). so just change display. Display Microchip area on display pane ![]() 2. Flex and parts damage Sometimes we can see with our won eyes where is broken flex line or any parts. but maximum time we can't see it normally. so we try to repair our display, when we confirm phone show display problem only for display panel not for any type of pcb defect. can we confirm it by replacing a good display on pcb. when we 100% confirm problem only on display panale than we can try to repair it. otherwise first fix other problem. For this type of problem can you repair flex cable with extra wire, but first need to calculate flex cable all line with multimeter. some times line cross flex cable 1 side to another side by in flex. so check them. and you try to change this type or parts, see picture ![]() though possible, change all parts from another display (which is broken but parts is ok) 3. connector damage on both (pcb and display flex) Connector/socket system display create problem from there connector. so check simpaley there all line with multimeter and fix them. though need join them with extra wire from direct pcb to display. also you can change both socket. 4. wrong software for wrong flash file or software problem we face white screen problem. so take any step before do 100% Confirm its not for software problem. we maximum time face this problem after flash or format. so after flash or format when a dead phone is power on. we can 90% confirm its for wrong version flash file. so first see your original flash file version than backup it and next flash phone with this same version new/another ok file. 5. Display line broken from display connection to CPU. 98% china phone display line going direct cpu and other 2% have display ic. and sometimes display line broken or break soldering from cpu to pcb middle point. just cpu bad soldering. so can you try to re-hot cpu with your won risk. also sometimes pcb internal line broken from cpu to display connection point. so check them and fix them. (but do it after changing a good cpu though still display not ok) 6. CPU internal display section Damage- Sometimes phone all section is working ok (without display) but have no display still after change a good display (soft ok also) now you need to change must be cpu. because many time i see phone all section work ok but have no display, after changing a good display phone is ok 100%. can anyone question, though its problem from cpu so how phone all section work ok. ans is - phone all section work ok because only display area damage internally in cpu but all other section have no problem. |
| The Following 9 Users Say Thank You to forid For This Useful Post: |
| | #2 (permalink) |
| maximum time we face problem for changing display for china phone, they all are not available in market, so we collect them from other same china phone. now problem is when we collect display from other same phone how we understood about this display version or model. plz see picture below ![]() here have 3 display, there size same and collect from same model phone, but here 2 display is similes but 1 is not same to other. so, now i think every member understood how can he get his display version from see display. its remember always- sometimes changing same display from same phone, we can't success for this- you must check phone software/ flash file version. because maximum time display working depend on software version. so don't worry. try to update you flash file, which have in collected display phone. and don't forgate to backup your current flash file before flash with new file |
| The Following 11 Users Say Thank You to forid For This Useful Post: |
| | #4 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: May 2007 Location: INdIa
Member: 517316 Status: Offline Thanks: 45
| Any solutions for dispaly showing upside down....................... I've changed broken dispaly of chinese phone with same one but dispaly showing upside down Any ideas please post here... |
| | #6 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Sep 2007 Location: Nairobi , Notikuo kwao
Member: 595815 Status: Offline Thanks: 16
| N82y UPSIDE DOWN DISPLAY Please help on this phone whose LCD has 35contacts.Its original screen shows ok but its broken. After fixing LCD with a slight difference it shows upside down.What can make this LCD DISPLAY UPRIGHT. |
| | #12 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: May 2006 Age: 33
Member: 282757 Status: Offline Thanks: 81
| working fine if phone goes idle , suddenly it goes upside down never come to normal screen again, big problem change several display, and flashed but same problem still remain |
| | #15 (permalink) |
| Junior Member ![]() Join Date: Oct 2009
Member: 1147614 Status: Offline Thanks: 9
| for inverted display problem in many china and micromax handset we get this kind of problem becaust of resistors on the display strip are not placed in their right place. You just change only resistors on the strip with the one on the damage original display and place them as they are on the original display. 10000000000000000% sucessfull try this. |
| The Following User Says Thank You to amitmalge For This Useful Post: |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Gather problems of China cell phones | agoodseller | Chinese Models & Cloned Phones | 0 | 12-15-2009 08:39 |
| Repair Display Problem Of China Phone | micro_hsr | Nokia Hardware & Hardware-Repair Area | 0 | 07-05-2009 07:56 |
| Skip Phone Code Of China Phones. | ashrafi580 | Chinese Miracle & PinFinder | 0 | 03-25-2009 12:52 |
| Please send your problem here,of china phone! | zhanglei5556 | Chinese Models & Cloned Phones | 3296 | 01-04-2009 14:56 |
| how to repair bad software of china phone | Mohsin-* | Chinese Miracle & PinFinder | 0 | 05-28-2008 10:23 |
