Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > HTC > HTC & Smartphones ( WM Without Touch)
HTC & Smartphones ( WM Without Touch) HTC, I-mate, Qtek, HP, Hitachi, and many other SmartPhones Windows CE base devices
Old 03-12-2007, 19:05   #1 (permalink)
Member: 46347
Thanks Meter: 3
how to get Tmobile Dash into bootloader
i have one on Tmobile USA(excalibur UK), just stops at the tmobile logo, i cant get the phone into the bootloader so i can flash it, any help?
phone is not liquid damage, the customer used a cheap aftermarket battery, phone didnt power up , i heated up the CPU , powered up , keypad did not work first , and now phone stuck at the logo.
Old 03-13-2007, 19:56   #2 (permalink)
Bert's Avatar
Member: 596
Sonork: 100.33096
Thanks Meter: 498
Hello
What did try to make it into boot loader mode by key pressing or use the upgrade software? for this situation some times can be the flash chipsometimes can be the sw problem. pls tell me more info. good luck!
Regards
The Following User Says Thank You to Bert For This Useful Post:
Old 04-03-2007, 16:04   #3 (permalink)
Member: 449231
Smile Hard Reset
Hello m8s,
When the Tmobile Dash is powered off... press and hold the 2 softkeys (the 2 buttons above the home button and back button) and then power button for 1-2 seconds.... and then release the power button. After that just press the Call (green) Button to perform a full format.... This is known to help with phones freezed at startup logo. Make sure the battery is fully charged. Or else you will fail to complete the full format.
Best Regards,
Delio
Old 06-10-2007, 12:57   #4 (permalink)
Member: 30124
Sonork: 100.1590000
Thanks Meter: 7,895
i am also default this set but i want know how to unlock this mobile any information please post here
Old 06-10-2007, 13:13   #5 (permalink)
Member: 30124
Sonork: 100.1590000
Thanks Meter: 7,895
thanks for info butt i need unlocking of this mobile have any info post here
Old 09-10-2007, 21:07   #6 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 682
Originally Posted by pencrorepair View Post
Hello m8s,
Best Regards,
Delio
that does not work for my dash, I know this works for other htc but dash maybe different to hard reset, how to? tnx.
Old 09-10-2007, 23:56   #7 (permalink)
mrfixit's Avatar
Member: 60899
Thanks Meter: 682
ok i found 2 options from
http://www.htcwiki.com/page/The+Dash+FAQ?t=anon
OPTION 1
Press Start -> Accessories -> Clear Storage, press enter to launch, you will be prompted to type "1234" and to press Enter. If you do this you will lose all contents and the Dash will be restored to its original configuration. It takes about 5 minutes for it do this and reboot.
If you are locked up and can't get to the Clear Storage utility, turn the phone off; hold down the two softkey menu select buttons (above the home and <- buttons); press power on while still holding the buttons down and follow the prompts on the screen. Timing is critical on the latter option, so if you miss it once, try again.
OPTION 2
(THIS IS WHAT T-MOB TECH SUPPORT WILL ADVISE YOU TO DO)
MASTER RESET PROCEDURES UPPDATED ON 7/23/07
I had to follow the correct steps twice before the reset took effect so don't give up after the first try. Start with Dash powered off.
1. PRESS AND HOLD BOTH SOFT KEYS.
2. WHILE HOLDING DOWN SOFT KEYS, PRESS AND RELEASE THE POWER BUTTON, WAIT 3-5 SEC. (PHONE SHOULD POWER ITSELF ON BY DOING THIS)
3. RELEASE THE TWO KEYS SOFT KEYS.
4. WHEN SCREEN ON DASH LOOKS LIKE IT'S IN DOS FORMAT, PRESS SEND (GREEN ANSWER KEY)
Old 09-26-2007, 23:50   #8 (permalink)
Member: 280117
Thanks Meter: 8
works great. thanks tested 100%
How to get F480 (Tocco) into emergency download mode for flashing? .:GSM International:. UST Pro II 3 02-19-2012 14:59
how to put tmobile shadow into flash mode? RotKT HTC & Smartphones ( WM Without Touch) 1 09-12-2009 04:47
How to get the F330 into flash modus? hejwazzup QUALCOMM Models (3G) 0 12-25-2008 13:04
How To Get A T209 Into Test Mode bengrippin UST Pro II 4 01-26-2007 08:35
How to get ringtones into 3210 pong38 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-02-2000 22:37
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.47644 seconds with 8 queries
Content Relevant URLs by vBSEO
