ZZ KEY
Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 03-03-2009, 04:35   #1 (permalink)
lxa786's Avatar
Member: 163725
Thanks Meter: 137
blackberry bold 9000 red light blinking
need help please,
i did unlock blackberry bold 9000 with MFI and flash with BlackBerry Desktop Manager,
After done flash get error os not found or some thing after that phone goes dead
Red light blinking when you put usb data cable or charger.
Now the big problem is phone not attach to the computer any more so please
Need your help how can I get alive,
Please donít forget to answer because is *******r phone and its been more then one week to keep the phone,
Iím really very thanks to the person who gives me the solution
THANKS VERY MUCH
The Following User Says Thank You to lxa786 For This Useful Post:
Old 03-03-2009, 05:51   #2 (permalink)
Member: 4691
Thanks Meter: 37
No worries my friend all you need is to download the latest sfi files and dont forget to download the latest flashfile update were you can download it at www.blackberry.com , look for the country provider were your phone is lock to.then run MFI loader again and make sure ( TURN OFF) ur internet conection and dissable autostart.after the click PHONE INFO,UNLOCK, at the very end of the process it will ask you to FULL FLASH YOUR PHONE,open the Blackberry desktop manager the click the UPDATE for your dead phone.it takes a while to finish and after flashing it will ask you to ente "S.T.A.R.T" after typing start then it wil reboot and DONE .
Hope this helps you
Old 03-25-2009, 17:55   #3 (permalink)
lxa786's Avatar
Member: 163725
Thanks Meter: 137
phone not conecting to the computer not showing any com port just red light blinking how do i conect to the computer?
Old 07-13-2009, 17:08   #4 (permalink)
Member: 5778
Thanks Meter: 10
i have the same problem
any suggestion ?
Old 07-14-2009, 01:20   #5 (permalink)
Member: 1073598
Pull up Desktop Manager and open up the application loader. When you attempt to update your software you'll notice it won't pick up ur phone because of the usb problem u r having. At this time, connect ur phone to the USB cable and immeditately click on OK once u see ur USB PIN.
this will recover ur phone and then u can try the multiloader all over again. sry, I'm not an expert so this is the only way I know of. It happened to me too and I'm still stuck with a locked 8900
Old 07-14-2009, 06:35   #6 (permalink)
Member: 311255
Thanks Meter: 3
I have some problem please Help!!!! red blink only, cant detect with PC..
Old 07-17-2009, 08:14   #7 (permalink)
Member: 4691
Thanks Meter: 37
You must provide fully charge battery then download the latest desktop manager for 9000 then plug in the usb cable.its should recognize new hardware or RIM , after that quickly Click Detect device and it will look USB PIN,Then Go to Restore mode to flash it with the latest updates.
Old 07-17-2009, 09:24   #8 (permalink)
Member: 266767
Sonork: 100.16010222
Thanks Meter: 20
Please remember the main problem here is that the computer does not recognise the blackberry at all. Ther is no USB connection not even for a second.
Now the question is how to get the computer to recognise the device.
Any experiences to share, please ?
Old 07-23-2009, 00:20   #9 (permalink)
Member: 1080578
i have exactly the same problem. red light blinks.
i think nothing helps in my case. probably the radiolaptool was too much...
Old 07-23-2009, 04:33   #10 (permalink)
Member: 926425
Thanks Meter: 33
hi
connect bb without battery it will connect ur bb to computer and when it shows connecting jvm put the battery and ur bb will flash and if it didnt work then use usb cable bb5 tiger 3 in one
thank
khalid khan
Old 07-24-2009, 22:25   #11 (permalink)
Member: 1081195
Thanks Meter: 6
Problems or Issues with MFI loader.......
Guys, I toasted a brand new Blackberry Bold..... I spent the better part of a Day researching how to resolve the problem......
I will post links below which you should read "thoroughly"!!!!!!!!!!! There are answers to many things there......
Where to look for help with issues:
http://myblackberrybahamas.blogspot....ding-bold.html
http://forum.gsmhosting.com/vbb/arch.../t-652388.html
8800 handles is locked need help
Frequently Asked Questions About BlackBerry phones
Download & Guide MFI Multiloader for blackberry unlock
I also followed these instructions "to the letter", I encourage you to "read" and understand "before" you act!!!!!!!!!!!
*** IMPORTANT- DO NOT DISCONNECT YOUR DEVICE UNLESS THE INSTRUCTIONS STATE TO DO SO ***
MFI loader Instructions....
Downloads:
1. VSM file for your carrier, you will need to search the internect using google....
2. MML Installation http://rapidshare.de/files/45231476/MMLSetup.msi.html
3. MML Data (Torrent Download) http://www.mininova.org/tor/2125273
Installation Instructions:
1. Run MMLSetup.msi
2. Locate the Directory C:\MML & Unzip MML.zip into this directory (this will install files into the MML directory, ***select overwrite all***)
3. The VSM file is for recovering from a botched update.
Here is a short version of what to expect.
1. Disable your connection to the internet (cable or wifi)
2. Launch MFI Loader and ensure auto start is checked & "full erase" is UNCHECKED!!!!!!!!!! (Very Important)***********
3. Connect your device via USB Cable
4. Let it do it's thing until you see a "FAIL" in the MFI Loader, your device will have a white screen with an error message "No Application...... Factory OS"...... Don't Panic!!!!!!!
5. Unplug your device, close & open the MFI Loader & ensure "Autostart" is UNCHECKED....... Hit ctrl+alt+shift+f12 keys all at the same time & a menu will be presented......
6. Plug your device back in and select Load VSM.... you will have to locate where you stored the VSM file, click on it and indicate to open / run...... you will see a message "VSM file loaded successfully"...... this takes less than a couple seconds.....
7. Turn On your Internect Connection again, launch the desktop manager & load the OS for your device ( or the one you wish to use, please ensure it is compatible with your device)......
8. Your Done!!!!! Pat yourself on the Back!!!!!!
NO WARRNTY IS EXTENDED SHOULD YOU ELECT TO FOLLOW THESE INSTRUCTIONS..... UNDERSTAND THAT YOU DO SO *** AT YOUR OWN RISK *** THERE ARE MANY THINGS THAT CAN GO WRONG, if something occurs, do a google search on the error message presented..... as I stated in the beginning................ I toasted (BRICKED) a brand new Blackberry Bold............. used the above & some other things to correct errors I encountered................... and can say.................. I AM USING THAT DEVICE without any ISSUES!!!!!!!
I wish you GOOD LUCK!!!!
The Following 6 Users Say Thank You to vpu2 For This Useful Post:
Old 01-06-2010, 13:38   #12 (permalink)
Member: 331337
Thanks Meter: 50
hi, i had fully working 9000 bold. it was switching on and evrything was fully working until i bought another 9000 bold dead. i thought it might be battery problem in dead phone so i swapped battery from the phone dead phone to working one. now i m trying to switching my working phone with its own old battery which was working fine but its not switching on. there is no red light coming on for some reason. any idea why its doing that. please help
Old 01-13-2010, 13:02   #13 (permalink)
Member: 331337
Thanks Meter: 50
hi guys.i had 2 phones blackberry bold 9000. both was not switching on and was not charging when i used to connect to charger. i tryied everything but i had no luck with both them. now i tryied something else, i took battery out for 48 hours and didnt do nothing. after 2 days i put battery in the phone and i put it on charge amazing after few min. its start showing charging. both phon working fully now.
please try this. make sure you take battery out for 2 days and do not connect to charger. after 2 days put battery in and connect phone with charger. leave for about 10min it should start switch on.
The Following User Says Thank You to twin army For This Useful Post:
Old 04-01-2010, 22:36   #14 (permalink)
ansari123's Avatar
Member: 292789
Thanks Meter: 609
need help please,
THANKS VERY MUCH
any suggestion ?
Old 06-27-2010, 11:21   #15 (permalink)
Member: 1297888
Thanks Meter: 77
bold 9000 red blink and short
Which components should I execution...?
pls give me picture..
what is the meaning of bb9000 bold red light blinking? rashidbinu BlackBerry (RIM) 4 11-23-2009 04:14
Blackberry 8700v red light blink ahmad bashir FuriousGold | Powered by FuriousTeam 1 03-05-2009 18:21
blackberry 8900 just red light blinking help simlock BlackBerry (RIM) 2 02-23-2009 11:45
BLACKBERRY 7290 RED light blinking only ? harish35200 BlackBerry (RIM) 2 12-24-2008 07:37
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.38122 seconds with 8 queries
Content Relevant URLs by vBSEO
