Unlock Server
Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 02-11-2011, 16:34   #1 (permalink)
SenUnlock's Avatar
Member: 1415435
Sonork: 1595155
Thanks Meter: 82
Dead blackberry 8230 : how to recover ?
Hello,
i was wiping a blackberry 8230 with MFI multiloader and the process stopped right after the wiping stage.
Now the device can't connect to the computer , (not recognized by desktop manger, bbsak, jcmder)
when i plug it , the red light show still for 1 mn , then starts to blink 2 times every 2 seconds.
I foolowed a lot of tutorials about dead blackberry, none of them helped.
how to bring the device back to life ?
Thank in advance
Old 02-11-2011, 16:38   #2 (permalink)
Moderator
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 849
plug in your device without battery! and check if it is recognized! and post results again!
Old 02-11-2011, 16:45   #3 (permalink)
SenUnlock's Avatar
Member: 1415435
Sonork: 1595155
Thanks Meter: 82
already done, it is not recognized. thank for the advice
Old 02-11-2011, 16:48   #4 (permalink)
Moderator
axecom's Avatar
Member: 1424719
Sonork: 100.1619833
Thanks Meter: 849
Change USB cable!
Plug it in another port!
!if same!! maybe it's a hardware problem!!
The Following 2 Users Say Thank You to axecom For This Useful Post:
Old 02-11-2011, 16:51   #5 (permalink)
SenUnlock's Avatar
Member: 1415435
Sonork: 1595155
Thanks Meter: 82
thank for caring. I have already done that( change cable, use other ports, changed version of desktop manager). Phone was working fine before, so i don't believe it is hardware. thank you
Old 02-11-2011, 20:10   #6 (permalink)
Member: 1380170
Thanks Meter: 10
Man, put the usb cable with battery, and w8 15/30 min the phone switch on
Dont you see LED RED?
Old 02-11-2011, 21:43   #7 (permalink)
SenUnlock's Avatar
Member: 1415435
Sonork: 1595155
Thanks Meter: 82
yes, i see it. and the red light blinks when i press keys, but no connection to PC. thank you
Old 02-11-2011, 23:40   #8 (permalink)
luzer's Avatar
Member: 44659
Thanks Meter: 264
8230 is a cdma phone ...
Old 02-28-2011, 10:09   #9 (permalink)
Member: 1186246
Sonork: 100.1636911
Need blackberry... MFI empty software
Old 10-17-2011, 03:05   #10 (permalink)
Member: 1674035
How to get this MFI empty software.
Old 10-17-2011, 04:07   #11 (permalink)
Member: 1629736
Sonork: aayushjaiswal
Thanks Meter: 271
blackberry firmware
BlackBerry 5800 Device Firmware
http://rapidshare.com/files/33412111...94-telstra.exe
http://rapidshare.com/files/33173165....6.0.83-vd.exe
BlackBerry 5810 Device Firmware
http://rapidshare.com/files/33413712...d_3_6_0_73.exe
BlackBerry 6200M Device Firmware
http://rapidshare.com/files/33178415...8-Vodafone.exe
BlackBerry 6230 6280M Device Firmware
http://rapidshare.com/files/33358753...219-Rogers.exe
BlackBerry 6700M Device Firmware
http://rapidshare.com/files/33415691...8-Vodafone.exe
BlackBerry 7100C Device Firmware
http://rapidshare.com/files/33366420....0.292_CSL.exe
BlackBerry 7100M Device Firmware
http://rapidshare.com/files/33465350...afone__HK_.exe
BlackBerry 7130 Device Firmware
http://rapidshare.com/files/33179367....189_Telus.exe
BlackBerry 7200E Device Firmware
http://rapidshare.com/files/33412219...6_Cingular.exe
BlackBerry 7510 Device Firmware
http://rapidshare.com/files/33168911...2.37_Telus.exe
BlackBerry 7520 Device Firmware
http://rapidshare.com/files/33412309...2.37_Telus.exe
BlackBerry 7700M Device Firmware
http://rapidshare.com/files/33175852...219-Rogers.exe
BlackBerry 7290M Device Firmware
http://rapidshare.com/files/33472077...377_Rogers.exe
BlackBerry 7750M Device Firmware
http://rapidshare.com/files/33310355...2.29_Telus.exe
BlackBerry 8310 Device Firmware
http://rapidshare.com/files/33179407...75_SingTel.exe
BlackBerry 8100 Device Firmware
http://rapidshare.com/files/33237053...ar_Limited.exe
BlackBerry 8100C Device Firmware
http://rapidshare.com/files/33414000..._Telkomsel.exe
BlackBerry 8100M Device Firmware
http://rapidshare.com/files/33167219...A4.2.1.103.exe
BlackBerry 8110 Device Firmware
http://rapidshare.com/files/33179419..._A4.5.0.42.exe
BlackBerry 8110M Device Firmware
http://rapidshare.com/files/33361409...T_Wireless.exe
BlackBerry 8120 Device Firmware
http://rapidshare.com/files/33412551..._A4.5.0.42.exe
BlackBerry 8220M Device Firmware
http://rapidshare.com/files/33177662...174_Rogers.exe
BlackBerry 8300 Device Firmware
http://rapidshare.com/files/33373540...A4.5.0.102.exe
http://rapidshare.com/files/33474321..._A4.5.0.42.exe
BlackBerry 8310M Device Firmware
http://rapidshare.com/files/33167237..._A4.5.0.55.exe
BlackBerry 8320 Device Firmware
http://rapidshare.com/files/33414175...e_Vodafone.exe
BlackBerry 8350i Device Firmware
http://rapidshare.com/files/33179398....83_Nextel.exe
BlackBerry 8520 Device Firmware
http://rapidshare.com/files/33168110...72_Vodacom.exe
BlackBerry 8700M Device Firmware
http://rapidshare.com/files/33411319..._Proximus_.exe
BlackBerry 8707vm Device Firmware
http://rapidshare.com/files/33167846...A4.1.0.365.exe
BlackBerry 8707vM Device Firmware
http://rapidshare.com/files/33167349...A4.1.0.365.exe
BlackBerry 8800 Device Firmware
http://rapidshare.com/files/33474194...e_Vodafone.exe
BlackBerry 8800M Device Firmware
http://rapidshare.com/files/33167544..._A4.5.0.55.exe
BlackBerry 8820 Device Firmware
http://rapidshare.com/files/33374092...e_Vodafone.exe
BlackBerry 8900 Device Firmware
http://rapidshare.com/files/33414514...5.0.0.190.exe_
BlackBerry 8900M Device Firmware
http://rapidshare.com/files/33468350...odafone_UK.exe
http://rapidshare.com/files/33469104...A4.5.0.102.exe
BlackBerry 9000M Device Firmware
http://rapidshare.com/files/33471597...162_Rogers.exe
BlackBerry 9500 Device Firmware
http://rapidshare.com/files/33413623...odafone_UK.exe
BlackBerry 9700M Device Firmware
http://rapidshare.com/files/33714798...A5.0.0.321.exe
BlackBerry Tour 9630 Firmware v 4.7.1.42
http://hotfile.com/dl/77393211/9dc37...k.com.exe.html
BlackBerry Desktop
http://rapidshare.com/files/331793886/SR_MM.rar
http://rapidshare.com/files/334135590/Data1.cab
http://rapidshare.com/files/33177612...p_Software.rar
Old 10-17-2011, 04:52   #12 (permalink)
Member: 366714
Thanks Meter: 21
Originally Posted by SenUnlock View Post
Hello,
Thank in advance
Bro,
I also having same issue with BB 9000 and I'm suffering more than one month.
Most of them reply and given solutions even without understanding or read your post.
As I know your set dead during update or flash. So it's can't be HW fault.
Problem is set not detect by PC.
That means boot files ( Bootrom ) has damage. Try to find more about it.
How to add a language in 51xx/61xx tati Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 05-21-2013 19:20
How can I do a Welcome note for my 6110 a dosn't have any one ? Viper Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-18-2012 07:57
How to upload a new firmware... Brand Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 06-08-2012 18:29
news headlines to gsm phone mos Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 12-18-2011 11:00
Copy from one 6110 to another Leif Nielsen Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 06-10-1999 22:36
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.62380 seconds with 8 queries
Content Relevant URLs by vBSEO
