Unlock Server
Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > BlackBerry (RIM)
BlackBerry (RIM) Blackberry phones discussion, firmwares, tutorial, media, repairs.
Old 12-20-2008, 07:12   #1 (permalink)
Member: 759961
MFI Multiloader Error!unable to disable suspend on USB & Unable to cast COM object???
Hi guys im new to this!
when I try to open the MFI multiloader I keep getting these two errors...
no its not the internet connection. I have it off before and during
I even went and disabled the suspend on the USB
I have Vista 64-Bit, I think thats it but I know people that have the same and it works for them!
if someone can help me here I would really appreciate it!
Thanks in advance!
Old 12-20-2008, 07:23   #2 (permalink)
::.::RAMJAN::.::'s Avatar
Member: 258172
Thanks Meter: 10,345
1st Download & instle latest blackberry desktop manager v4.7.0.32 , link here , WITHOUT select Automatic Update service
Old 12-22-2008, 04:29   #3 (permalink)
Member: 759961
Can Someone Please help me plzzzzzzzz!!! im desperate! i cant get it to open, i even made another user as administrator and nothin, same thing!
please people! help me! come on, it's almost christmas, make that your gift to mine! the favor will me returned!
Old 12-22-2008, 05:59   #4 (permalink)
Member: 101681
Thanks Meter: 31
Pls specify what errors you are getting ?.
Old 12-22-2008, 07:25   #5 (permalink)
Member: 759961
sDinesh, i have these two pop ups!
1. "unable to disable suspend on USB. access to the registry key 'HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servi ces\USB' is denied"
2. "Unable To Cast COM Object of Type 'BBDEVMGR.DeviceManagerClass' To interface type 'BBDEVMGRlib.Idevicemanager'. This operation failed because the queryinterface Call on the COM component For the interface with IID '{C716830B-AOF4-46DF-B82A-548CFB08755E}' failed due to the following error: Class not registered (exception from HRESULT:0x80040154 (REGDB_E_CLASSNOTREG)).
thanks man!
Old 12-22-2008, 07:51   #6 (permalink)
Member: 920965
Thanks Meter: 12
Maybe the problem is Vista itself ? Have you tried it on another computer, or OS ? Follow the exact instructions, install the loader using the setup file, then extract the files you downloaded into that same folder overwriting the files. It should definitely work.
The suspend USB error I've never heard of
Old 12-22-2008, 09:50   #7 (permalink)
Member: 118959
Thanks Meter: 5
I had the same error but I realised I was connected to the internet, so disconnected and all worked fine.
Maybe that's your problem.
Old 12-22-2008, 18:21   #8 (permalink)
Member: 759961
yeah man, in theirs its all good, does it have to do that since i have 64 bit i had to download a different 2.0 framework? I followed the exact exact instructions and nothin! I just click disable WLAN
Old 12-22-2008, 19:08   #9 (permalink)
Member: 258172
@Diegoquijada.. Your windows Vista or Xp ?
I think you forget to instle MMLSetup setup exe
Read & do again this thread in sticky
Old 12-22-2008, 21:00   #10 (permalink)
Member: 759961
what MMLSetup setup exe
where is that file located???
Old 12-23-2008, 01:26   #11 (permalink)
Member: 924380
Thanks Meter: 32
Vista cause too much trouble use XP
Old 07-20-2009, 09:09   #12 (permalink)
Member: 836308
MFI Multiloader error with Vista - unable to disable suspend on USB.Acces to the regi
for this error
unable to disable suspend on USB.Acces to the registry key 'HKEY_LOCAL_MACHINE\System\CurrentControlSet\Servi ces\USB' is denied
download and apply the zip file from this link:
http://forums.planetz.com/download/file.php?id=4443
It makes the necessary changes in the registry key.
rgds
Old 05-19-2011, 21:42   #13 (permalink)
Member: 1579455
Hi guys,
someone tried to unlock the Torch 9800? I got from MFI "Unable to connect to bootimage"
Thanks.
Old 05-19-2011, 22:50   #14 (permalink)
Member: 416710
Thanks Meter: 368
Originally Posted by williamdub View Post
Hi guys,
Thanks.
this mfi not work for new security phones, so wait for new mml crack or server base, or wait dm3.
The Following User Says Thank You to Celhack For This Useful Post:
Old 05-20-2011, 08:55   #15 (permalink)
Member: 527046
Thanks Meter: 77
or buy the code
how much it cost your 9800?
how much it cost one unlock code?
The Following User Says Thank You to hyber_99 For This Useful Post:
unable to cast com object of type RIMRA-HELP zonetrichur BlackBerry (RIM) 6 04-04-2010 07:12
unable to cast com object error faceache BlackBerry (RIM) 1 09-17-2009 07:02
BB 8100 Unable to cast COM object of type 'RIMRADIOCOMLib.RIMRadioObjClass' to interf khaalsa BlackBerry (RIM) 3 09-03-2009 15:36
Unable to cast COM object of type 'RIMRADIOCOMLib.RIMRadioObjClass' to interface type riskyboi BlackBerry (RIM) 1 07-22-2009 21:10
MFI multiloader error plz help me G.S.M Don BlackBerry (RIM) 7 12-07-2008 02:33
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.51829 seconds with 8 queries
Content Relevant URLs by vBSEO
