Old 04-18-2009, 05:48   #1 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,055
Arrow MXkey Tips and Tricks - HOT SOLUTION ONLY HERE
  • 1. Always select correct 'Generation' first before any operation.
  • 2. Always Use "Scan" if you're working with non dead phone, this will help mobileEx to use 'correct' spesific setting for any phones attached to box.
  • 3. "BUS Check" with setting safe flash ticked, will perform boot squence, display boot information (upp id, flash manufacture, flash address) and automatically safe phone's rpl.
  • 4. Make sure phone is in correct mode for any FBUS/NON flashing operation,
    - example: in Tuning & Testing page, phone should be in TEST MODE, else will be best if the phone is in LOCAL MODE.
    Do phone mode change manually if needed.
  • 5. When doing jobs on working phone, for any operation (add language, locks, etc), DCT4 and BB5, it is better to save its security data (RPL, certificate, pm, etc) first before you do anything else. Just in case...
  • 6. If you noticed, there was a differences of flashing speed between FlashID/Manufacturer the option 'Fast flash' should not be enabled for "INTEL" flash chip.
  • 7. If you need only to change the language, select file setting as NORMAL. then check 'Language Only"
  • 8. "Safe Flash" will save RPL backup from flash mode, and currently NOT supported for ASIC type 11 phone, so dont be checked. For this phone please do a PM backup since RPL backup from flash mode not yet supported. All other DCT4 asic is supported. Yes, even the dead one.
  • 9. Use "Restart" button every time you need to refresh the connection or restart the phone.
  • 10. Unlock "Security Code" on all DCT4,DCT4PLUS(Asic 2),WD2, TIKU without loosing any user data(phonebook, msg, etc) even counter already blocked? Yes, it is possible using mobileEx. Just do a "BUS Check" and you will see "Master Code" , use this code as the security code(this code readed from the phone and 100% will work both for CDMA or GSM phones).
Run on first time, choose which module to execute
Customizing Your Suite
Configure Nokia Tool
Open Nokia Service Tool, and click on this corner
* Enabled Imei changes -> if checked Imei/Esn changes will visible.
Kindly check for your local law for this operation.
* Auto backup ... -> Backup RPL on BUS check ( for DCT4)
* Auto Create DP folder if not exist
This is for directory creation specialy for .nfp extraction. Inside those directory, mcu, ppm, and cnt will be placed.
* Default FBUS timeout
This will set FBUS timeout (higher value = low speed but more accurate)
* Highlight market item
This will highlight the character you choosed. For example on picture, it highlighted on Indo, APAC, MD, and -X.
You will see like this when you selecting files from product code
Server : this is for your ask>rpl service. choose which one is fastest from your location.
And this is the setting for your firmware directory
thats for now, will add more info
Best Regards
The Following 236 Users Say Thank You to gbluez For This Useful Post:
Old 04-26-2009, 17:31   #2 (permalink)
Alim Hape's Avatar
Member: 43548
Thanks Meter: 2,190
Unhappy [Tips] What you should know about mobileEx - MXKEY in practice
Here i will explain in step to save your time and optimize the job when using mobileEx, specially with 'Nokia Tool'.
- Always select correct 'Generation' first before any operation.
- Always Use "Scan" if you're working with non dead phone, this will help mobileEx to use 'correct' spesific setting for any phones attached to box.
- Make sure phone is in correct mode for any FBUS/NON flashing operation,
example: in Tuning & Testing page phone should be in TEST MODE, else will be best if the phone is in LOCAL MODE.Do phone mode change manually if needed.
- For any operation, specially newly released phones, its better to save its security data (RPL + full pm) first before you do anything else.
- if you noticed, there was a differences of flashing speed between FlashID/Manufacturer
the option 'Fast flash' should not be enabled for flash chip "INTEL"
- if you need only to change the language, select file setting as NORMAL. then check 'Language Only" should do the job
- "Safe Flash" will save RPL backup from flash mode(even a DEAD one except ASIC11 phones).
- Use "Restart" button every time you need to refresh the connection or restart the phone.
- Use "..."(Read Phone Mode) button at the right of the phone mode combo to check if the phone if connected and synchronized.
- mobileEx loads your selected "Products" folder to the phone model list, so make sure you have set the correct folder ("Options").
- to be continued.
The Following 59 Users Say Thank You to Alim Hape For This Useful Post:
Old 04-29-2009, 04:37   #3 (permalink)
Alim Hape's Avatar
Member: 43548
Thanks Meter: 2,190
First Drive:
Nokia Service Tool Configuration:
- Open mobileEx.exe
- Choose interface(UFS/JAF/MTBOX/..), Push "Connect"
- Click on the "star" logo, this is "Appl Modules Loader", Choose "Nokia Service Tool".
- Wait for few second, until Nokia window is loaded.
- Click on "quote" logo (at the right side of the star logo), Choose "Config".
this is the Main Configuration Settings for Nokia.
~General Settings
- Imei Changes
Tick this if you want to use the Imei changes features (check you country law first !!!)
- Auto Backup important data on "BUS Check" (for DCT4 only)
When doing BUS check, RPL will be back up.
- Save as <IMEI>_<TIMESTAMP>_back.RPL
if you check this, the backup will be generated with timestamp every time you "BUS check", else will only save first time.
- Show Detailed Info
Recommended for Advance User, This will allow to display information log in detail.
- Automaticaly select Generation on "Scan"
Correct Generation will be automaticaly selected when you Scan the phone, for example: if you have DCT4 phone connected but active generation is BB5, after you scan product generation will be set to "DCT4"(Not applicable for DEAD phone')
- Auto create DP folder if not exist
New Folder in "Products\<PHONE_TYPE>" will be made, if not exists.
- Default FBUS Timeout
Default is 5000 ms= 5 second.
Less=Faster respond but might have problem with phone which has longer booting time(WD2/BB5)
- Highlight Market items.
Usefull for fast select product code for spesific market.
Enter whatever keyword you want, for example if you choose "EURO,UK" then 'Market Name' which contain word: EURO or UK will be highlighted.
~ Server
You could change here the MXKEY server host, someday when we need to change them. Default is: nkrpl.biz
~ Directory
Select "Products" folder in "Data Package 1"(Default=C:\Program Files\Nokia\Phoenix\Products).
Select "Data Package 2" folder in "Data Package 2"(Default=C:\Program Files\Common Files\Nokia)/(Optional)
Select "Wintesla" Directory(Default=C:\Wintesla).
BR.
The Following 42 Users Say Thank You to Alim Hape For This Useful Post:
Old 04-30-2009, 19:03   #4 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,772
Some PC or PC with new OS
after open main soft.mxkey disappear in few second.
mostly cos smartcard reader conflic or not signed
try reinstalling this driver
br,
The Following 44 Users Say Thank You to Andra For This Useful Post:
Old 05-08-2009, 05:40   #5 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,772
Explain how to deal with the mx-key
this tutorial by hamada-almasry
thanks for supporting us
Now explain how the flash
more video check here
br,
The Following 41 Users Say Thank You to Andra For This Useful Post:
Old 05-20-2009, 13:43   #6 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,772
someone who have trouble with flashing BB5
perhaps this Flash Update can help
download
br,
The Following 23 Users Say Thank You to Andra For This Useful Post:
Old 06-09-2009, 12:46   #7 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,772
online logger in ver 3.2 rev 1.0
not showing
thick this item
br,
The Following 29 Users Say Thank You to Andra For This Useful Post:
Old 06-17-2009, 21:24   #8 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,772
BB5 SL2 Unlocking step
Backup IMEI + PM308 before Unlock
big thanks to mr.sahil2000ind
for info.
The Following 89 Users Say Thank You to Andra For This Useful Post:
Old 06-19-2009, 06:54   #9 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,772
backup Phone book
note:
Phone must be Local Mode for this operation
br,
The Following 57 Users Say Thank You to Andra For This Useful Post:
Old 07-12-2009, 21:36   #10 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,772
flashing error in v3.2 revision 3.0, Public-Release
Error while erasing, Result: 00000000000000 , 0
Flashing terminated with error(s)
RX Buffer:
or
Using device: UFS_USB V2.8 (c) SarasSoft 2007.
Library version: 1.0.0.7931(21-03-2010), 1.0.0.12676(21-03-2010)
ASIC ID: 0x2292 [UPPCosto ver: 1.3]
SecondaryBoot: u3_2nd.fia [DCT4] version: 4.76.0 revision: 0.7 size: 0x9A8
Supported Ids: 3040, 2292, 2293, 3162, 3166, 3168
BootLoader not responding, mostly RAM problem !
or
Sorry, Unable to find flashloader for this FlashID !
RX Buffer: F7F372
check cable,make sure have rx2 pin in BB5 phone
try set fia flash
http://www.youtube.com/watch?v=<object width="480" height="385"><param name="movie" value="http://www.youtube.com/v/5MNx6LTRpdU&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/5MNx6LTRpdU&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="480" height="385"></embed></object>
br,
The Following 112 Users Say Thank You to Andra For This Useful Post:
Old 07-13-2009, 19:18   #11 (permalink)
1NOKIA1's Avatar
Member: 946569
Thanks Meter: 326
RX Buffer:
or
RX Buffer: F7F372
try set fia flash
br,
this fia file not working for all phone bcz :
bus check for nokia 5700 with fia files 8.49.19... give this error:
SYSTEM ASIC ID: 000000010000022600010006400C192101021103 [RAPIDO3G ver: 1.11]
EM1 ID: 00000295
EM2 ID: 00000B22
PUBLIC ID: 0AB00008E87D005847B3379EE82E876AE421EBC5
ASIC MODE ID: 00
ROOT KEY HASH: 9A28E119033B91D14D22838C86D0D53C
ROM ID: A8C1D6713E691FF8
 RAPIDOv11_2nd.fg: [BB5] version: 8.36.0 revision: 2.0 size: 0x3A80
 Supported RAP Ids: 0003192101001203, 000C192101001203, 4003192101001203, 400C192101001203, 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
Error sending loader (0200000000F172)
and with old fia files 8.6.1... no error found
RAP Data :
EM1 ID: 00000295
EM2 ID: 00000B22
ASIC MODE ID: 00
 RAPIDOv11_2nd.fg: [BB5] version: 1.30.0 revision: 0.0 size: 0x3AC0
 Supported RAP Ids: 0003192101002003, 000C192101002003, 4003192101002003, 400C192101002003, 4003192101011103, 400C192101011103, 4003192101021103, 400C192101021103, 4003192101031103, 400C192101031103, 4003192101011105, 400C192101011105, 400C192101021105, 400C192101031105
FlashID0: 00EC 0030  - 0040 0121 [Samsung K5W1G13ACM-DJ60,1 Gbits] type: ONENAND,RAP
ExtBUSC: 0000 0000 0000 0000 0000 0000 0000 0000
ExtDEVC: FFFF 0000 - 0000 0000
 RAPIDOv11_algo.fg: [XSR 1.5] version: 1.35.0 revision: 0.0 size: 0x272B0
RAP PAPUBKEYS ID: 3D66090E94F3701646DA91CCD35BBAC22E5CBF73
Original Imei: 35396401500381
Original Product code: 0557255
Bluetooth ID: 001A16A62DDD
Phone Type: RM-230 (Nokia 5700)
SW Version: V 03.83.1 21-06-07 RM-230 (c) Nokia
Imei plain: 35396401500381-7
Product Code: 0557255
Language Pack:
- not available.
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7:   1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following 24 Users Say Thank You to 1NOKIA1 For This Useful Post:
Old 07-14-2009, 01:19   #12 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,772
@1NOKIA1
thanks for corrected,
maybe need manual configuration for this flash update,
will info coder for easy use,doesnt need manually change folder before flashing
br,
The Following 14 Users Say Thank You to Andra For This Useful Post:
Old 08-13-2009, 20:02   #13 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,772
1.Option
2.Server
3.Server List
4.Pick Server
5.Go Support
- Credit lost
- Reset Password
- Change Email
br,
The Following 25 Users Say Thank You to Andra For This Useful Post:
Old 09-13-2009, 02:47   #14 (permalink)
Andra's Avatar
Member: 976728
Sonork: 1589709
Thanks Meter: 4,772
since update v3.2 revision 5.0, Public-Release
we introducing new feature part of Erase Flash .
~ SAFE Erase will Protect PM Data from erase specially when doing 'Erase WHOLE flash'.
~ Usefull for recovering a DEAD phone without loosing SIMLOCK DATA
called as -> SAFE Erase.
Mean is Erase Flash area "WithOut" PM Data Area ( include Simlock ).
lets me give some sample
this case i have 5300 RM-146 can local mode
so i backup first RPL anf PM
if can't local mode,with this metods we can backup RAP NPC ( by selecting RAP )
this operation doesn't need local mode.
Go Erase Flash.
Dont forget tick Safe Erase Flash ..
after finishing erase , go tab flashing .
and flash by your phone market.
here phone info after flashing ..
if before not damage , then you have lucky.
doesnt need RPL to repair
last restore your IMEI , PM auth , Write PM without 308 area
lets do some good work
br,
The Following 38 Users Say Thank You to Andra For This Useful Post:
Old 11-06-2009, 15:57   #15 (permalink)
fred's Avatar
Member: 12411
Sonork: 100.113572
Thanks Meter: 812
[MXKEY - TIPS] MXKEY in practice - What you should know about mobileEx -
here is a simple hint how to solve IMEI changes not appearing on newly installed v5.6
1. uninstall the old mxkey software.
2. delete everything inside C:\mobileEx\3.2\
NOTE: do not delete the folder 3.2 just the files inside it.
3. click start menu => RUN => regedit => HKEY_CURRENT_USER\Software\mobileEx
right click on the mobileEx then delete.
look below:
4. click start menu => RUN => regedit => HKEY_LOCAL_MACHINE\SOFTWARE\mobileEx
look below:
5. Now install the latest version of your MXkey..
below you can see BEFORE and AFTER the guide was made.
Before:
After:
hopes this helps other having a problem about a clean installing of their MXkey.
freddy
www.gsmph.com
The Following 39 Users Say Thank You to fred For This Useful Post:
Cell Phone Tips and Tricks - Students and Cell Phones murtaza_nns Off Topic Zone 3 10-05-2009 21:59
My tips and tricks and questions for N73 6280 etc pearsonjohnboy BB5BOX 7 03-06-2008 13:58
Ah no, its dummy S40 phone and unfortunately S60 tip and trick doesn’t works on that apocalypso Nokia Base Band 5 ( BB-5 ) 0 06-25-2007 14:05
D500 tips and trick over here!!!!!! austinchan SWIFT Platform 4 06-07-2005 14:40
9210 Tips and Trick #1 and #2 X-Shadow Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 11-26-2001 01:26
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.60884 seconds with 9 queries
Content Relevant URLs by vBSEO
