Old 04-28-2010, 17:19   #1 (permalink)
Member: 1146326
Thanks Meter: 11
nokia e71 blank screen problem
hi i have problem with nokia e71 when i start camera only blank screen comes up i saw this thread but does not help http://forum.gsmhosting.com/vbb/f299...lem-pm-859159/
any other suggestions ?
Old 04-28-2010, 17:25   #2 (permalink)
Member: 735092
Thanks Meter: 17
try to flash with eno firmware and then flash again with complete mcu,ppm and cnt if problem still same post the logs here so anybody can help you
Old 04-28-2010, 17:33   #3 (permalink)
Member: 1146326
Thanks Meter: 11
what is "eno" firmware?
Old 04-28-2010, 18:09   #4 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
ENO software handles all basic functions inside the device.
It is required to be flashed into the device when Combo Memory is Changed
due to by some wrong operations like; Downgrade Phone wrongly,
Flash with wrong Firmware, Erase Phone with wrong file or
Phone is on White or Blank display.
After flash with ENO Firmware your phone will be normalized and
then you simply flash again with correct firmware package,
select any product code according to your choice and press Flash button.
Old 04-28-2010, 18:20   #5 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
this eno for e71 rm-346 4shared.com - online file sharing and storage - download RM346_ENO_0741.10_08wk42.a34.fpsx
The Following User Says Thank You to alasmmar For This Useful Post:
Old 04-28-2010, 18:40   #6 (permalink)
Member: 1146326
Thanks Meter: 11
haven't used before can you tell me where to load it ?
Old 04-28-2010, 18:51   #7 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
just put this eno flash in ape v and click flash
Old 04-28-2010, 19:09   #8 (permalink)
Member: 1146326
Thanks Meter: 11
reading boot config 1 failed!
Flashing terminated with error(s) in 11.837 s
Old 04-28-2010, 19:14   #9 (permalink)
Member: 735092
Thanks Meter: 17
1st you make bus check and then scan save simlock..put the eno firmware as mcu and then flash after succesfully flash the eno firmware flash again with complete flash mcu,ppm,and cnt post result
Old 04-28-2010, 19:56   #10 (permalink)
Member: 1146326
Thanks Meter: 11
when i try to flash or bus check i get this error above
Old 04-28-2010, 20:13   #11 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
flash phone with ded usb
Old 04-28-2010, 20:45   #12 (permalink)
Member: 618025
Thanks Meter: 19
what should we do ? If dont have back up than write eno firmware imei no is not gone
sorry for my english
Old 04-28-2010, 21:01   #13 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,055
do backup on every steps!
MXkey Tips and Tricks - HOT SOLUTION ONLY HERE
Please visit the thread more oftenly.
The Following User Says Thank You to gbluez For This Useful Post:
Old 04-28-2010, 21:02   #14 (permalink)
alasmmar's Avatar
Member: 231153
Thanks Meter: 313
no bro just flash eno sw imei will not going
Old 04-28-2010, 21:08   #15 (permalink)
Member: 618025
Thanks Meter: 19
i have e 71 after flash its going in blank screen befor flash it work fine but slow than i flash it
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-05-2014 11:33
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 29 06-27-2014 21:31
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 48 05-12-2013 13:07
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.34694 seconds with 8 queries
Content Relevant URLs by vBSEO
