Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Martech products > MARTECH CARS Category
Old 09-16-2010, 20:05   #16 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
RCDPRO PC V0.0.3.2 - Ford V by Sony, RCD300 by Visteon
Latest version of RCDPRO PC allows to decode units made by Sony or Visteon with mc9s12 chip build in.
Currently supported:
- Ford C307/C214-MP3/RDS 4M5T-18C815-BH by Sony
- Ford CDX-FS214, C307/C214-MP3/RDS 4M5T-18C815-BK by Sony
- Ford CDX-FS132, CD132 MP3/CDS 5S7T-18C815-BG by Sony
- Ford CD132 4M5T-18C815-BJ by Sony
- Ford CD340-NAV 6M2T-18B988-AC by Sony
- VW RCD 300 1K0 035 186P, VWZ7Z2 by Visteon
Download it:
http://martech.pl/download/RCDPRO/rcdpro.zip
RCDPRO Tools works only on Martech CLIP device.
Martech Team.
martech.pl :: Forum index
The Following 2 Users Say Thank You to Tech mobil For This Useful Post:
Old 09-18-2010, 13:08   #17 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
MicroWire support over Martech CLIP !
Next protocol is supported, from now you can have MicroWire read/write/verify over you CLIP device :-)
How it works ? It's simply, you are making wires and the rest process is executed on CLIP, totally without PC.
Both modes are possible: with desoldered microwire memory, or in circuit (in board programming).
Supported:
- 93C06 (256b Serial MicroWire bus EEPROM)
- 93C13 (256b Serial MicroWire bus EEPROM)
- 93C14 (1Kb Serial MicroWire bus EEPROM)
- 93C46 (1Kb Serial MicroWire bus EEPROM)
- 93C56 (2Kb Serial MicroWire bus EEPROM)
- 93C66 (4Kb Serial MicroWire bus EEPROM)
- 93C76 (8Kb Serial MicroWire bus EEPROM)
- 93C86 (16Kb Serial MicroWire bus EEPROM)
You must have RCD or RCD PRO activated to run this tool.
Download it: MicroWire Tools v10
User manual (diagrams, connections, photos, how to upload):
MicroWire Tools Manual English
You can also use public support, here you can find datasheets for memories too:
(CLIP folder)
This is not the end of new protocols in support
Best regards
Martech Team
Old 10-11-2010, 09:20   #18 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
RCDPRO PC V0.0.3.4 - VW RCD310 / Skoda Swing by Delphi + Honda Navi
This time we bring solution for Delphi units like:
- Skoda Swing 5J0 035 161C SKZ4Z2
- Skoda Swing MP3 1Z0 035 161G SKZ4Z2
- VW RCD310 EU 1K0 035 186AA VWZ4Z2
Radios are based on 24lc32 memory, you can read real code directly from chip or get code from dump.
RCDPRO was updated also for decoding Honda navigations:
- Honda BB712PC Navi 39541-S9A-G021-M1 by Alpine
- Honda BB714PH Navi 39541-S9A-G510-M1 by Alpine
Full pack supports many various types, check models list:
http://martech.pl/download/PINOUTS/rcdpro_full.pdf
Martech Team.
MARTECH Team - Official WebSite
Old 10-21-2010, 10:04   #19 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
RCDPRO V0.0.3.9 - RNS510 service functions
From now you can service RNS 510 navigations directly from PC, available commands:
- Read Info
- Write Code (0000-9999)
- Repair - Write Date
- Repair - Write Part No. (ex. 1T0035680B)
- Repair - Write Serial No. (ex. VWZ6Z7H1234567)
- Eject CD, Test Radio
- Set LCD colours (white, red, blue, green, black)
- Test LCD (center, control, dps, touch, line)
- Set Logo (Skoda, Toureg, Passat, Seat)
- Set TV/VIDEO Free - on/off
- Changing coding system - configuration: China, Europa, Japan, North America.
- You can also activated HDD, DVD
This allows to convert units from one to other region.
All functions except tv free needs test mode before perfoming operations.
Use your RNS510 interface to connect. Some functions depends on navi firmware.
Update is FREE for all RCD PRO users.
Actual models list supported by RCD PRO
Download: Link
Martech Team
The Following User Says Thank You to Tech mobil For This Useful Post:
Old 10-22-2010, 11:32   #20 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
Motorola MC9s12 Flasher via BDM protocol on Martech Clip
Supported processors:
- MC9s12A128
- MC9s12B128
- MC9s12D64, MC9s12DG128, MC9s12DG256, MC9s12DP512, MC9s12DG128
- MC9s12H128, MC9s12H256, MC9s12HZ128, MC9s12HZ256, MC9s12HZ64
- MC9s12XD256, MC9s12XD64, MC9s12XDG128, MC9s12XDP384
- MC9s12XDP512, MC9s12XHZ256, MC9s12XHZ512
For now supported is reading eeprom, we will update for writing, also different flash sizes.
How to connect ? 4 wires:
PORT1.4 - BKGD
PORT1.5 - RESET
PORT2.1 - Vdd (+5V)
PORT2.7 - Vss (GND)
You can use it for radios, dashes and others hardware with 9s12 on board..
For example: Skoda Stream, RCD300, Ford V by Sony, Chrysler P0509165AB-A..
http://martech.pl/download/RCDPRO/MC...lasher_v10.zip
Flasher is FREE for RCD PRO users and works only on CLIP.
Martech Team.
Martech Team
Old 10-25-2010, 20:14   #21 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
MC9S12xx Decoder V1.0
Application designed for Martech Clip, allows to service radios based on MC9S12xx processors.
Available functions:
- reading details about radio (part, serial number)
- reading original radio code
Whole operation takes seconds and runs directly on Clip (no need to use PC computer)
Currently supported models:
- Skoda Stream (all versions) and Dance
- VW RCD300 (all versions)
- Ford by Sony (ex. CD132, C307, CD340 - units from so called V and M series)
- Chrysler (P05064362AA, P0509165AB)
MC9S12xx Flasher V1.0
It covers:
MC9s12A128
MC9s12B128
How to connect ? (it's in tool build in also) 4 wires:
PORT1.4 - BKGD
PORT1.5 - RESET
PORT2.1 - Vdd (+5V)
PORT2.7 - Vss (GND)
We advise to connect external CLIP power supply instead of USB cable !!
Martech TEAM
Old 11-02-2010, 17:24   #22 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
RCDPRO V0.0.4.0 - VW RCD510 / Skoda Bolero by Delphi
This time we bring unique solution for Delphi units like:
- VW RCD 510, 3C8 035 195, VWZ4Z3H
- Skoda Bolero, 1Z0 035 156G, SKZ4Z3K
Navigations are based on S29GL128 flash chip, you must read flash and then use RCD PRO to get code.
Next solutions coming soon
Martech Team.
Old 11-05-2010, 20:55   #23 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
LOCK13 Tool for Martech Clip
Martech Team presents new application to repair Ford radios with Locked10/13.
It's FREE for ALL RCD or RCD PRO USERS - one condition is you must have CLIP.
The first version supports the following models:
- Ford 3000
- Ford 4000
(Radios are based on MC68HC05L28)
Main application features:
- Reset counter and repair bad entries (lock3, lock10, lock13)
- Built-in calculator for M Series
The transmission path consists of only two lines, this simplify the system connection to a minimum.
The procedure for deleting Locked 10/13:
- Install applications on your Clip device
- Select Code Calculator, and generate the proper code for the radio (the serial number is located on the side of the label, such as M123456)
WARNING! Double-check your serial number and count the correct code to the radio.
Entering the wrong code will block the radio constantly.
- Connect the Clip to the radio as it's described in the program (two data lines and ground)
- Connect the power supply to the radio (remember about two GND and two +12V signals), turn on the radio
- Choose a model and function LOCK13 Remover, press OK to start the process
- After a moment on the radio display you see the "CODE" and you will be able to enter a code
- Properly written code will restore the functionality of the radio again
Download it: http://martech.pl/download/CLIP/LOCK...3_Tool_v10.zip
Connection diagram:
Warning about CLIP connection:
- pins are counted from right to left side (taking in mind keyboard top, for example GND signal which is on port2, pin seventh from right side).
- from modular plug all signals are mirrored - pin 1st is counted from left plug side
Support for more radios in the next updates.
Martech Team
Old 11-12-2010, 13:43   #24 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
RCDPRO V0.0.4.1 - BP radios in support
Latest Update brings code reading on following models:
- BP6386, Blaupunkt, 169 C1V2 MP3 ( Fiat )
- BP5348, Blaupunkt, 188 CD VA ( Fiat )
- BP5349, Blaupunkt, 188 MP3 ( Fiat )
- BP5355, Blaupunkt, 199 CD + MP3 ( Fiat )
- BP6329, Blaupunkt, 199 CD + MP3 ( Fiat )
- BP6330, Blaupunkt, 199 CD + MP3 ( Fiat )
- BP5354, Blaupunkt, 199 CD ( Fiat )
- BP6327, Blaupunkt, 199 CD ( Fiat )
- BP6328, Blaupunkt, 199 CD ( Fiat )
- BP8397, Blaupunkt, 199 EU CD MY08 ( Fiat )
- BP8398, Blaupunkt, 199 EU MP3 MY08 ( Fiat )
- BP7389, Blaupunkt, 312 Black MP3 SB05 ( Fiat )
- BP6383, Blaupunkt, 312 MP3 (Fiat 500) ( Fiat )
- BP7388, Blaupunkt, 312 MP3 Japan ( Fiat )
- BP4383, Blaupunkt, 848 CD SB03 ( Lancia )
- BP3392, Blaupunkt, 937 CD 147 ( Fiat )
- BP4392, Blaupunkt, 937 CD MP3 147 ( Fiat )
- BP3395, Blaupunkt, 937 CD MP3 Japan ( Alfa Romeo )
- BP6697, Blaupunkt, 937 CD MY **** ( Fiat )
- BP5327, Blaupunkt, 937 CD VA ( Alfa Romeo )
- BP3301, Blaupunkt, 937 CD ( Alfa Romeo )
- BP6699, Blaupunkt, 937 MP3 Japan MY ( Alfa Romeo )
- BP6698, Blaupunkt, 937 MP3 MY **** ( Alfa Romeo )
- BP5328, Blaupunkt, 937 MP3 VA ( Alfa Romeo )
- BP6308, Blaupunkt, 939 CD MP3 Japan ( Alfa Romeo )
- BP6302, Blaupunkt, 939 CD SB05 ( Alfa Romeo )
- BP5332, Blaupunkt, 939 CD ( Alfa Romeo )
- BP5334, Blaupunkt, 939 MP3 Japan ( Alfa Romeo )
- BP5333, Blaupunkt, 939 MP3 ( Alfa Romeo )
- BP5353, Blaupunkt, Punto 199 CD + MP3 ( Fiat )
- BP5352, Blaupunkt, Punto 199 CD ( Fiat )
- BP4336, Blaupunkt, Punto CD MY03 ( Fiat )
- BP2375, Blaupunkt, Punto CD ( Fiat )
Download it:
You can use SPI Tools to read 95320 (all above are based on this) and RCDPRO to read code.
Next updates on the way
Martech Team
Old 11-15-2010, 22:30   #25 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
Martech Team presents next version of LOCK13 Tools, this time for Ford 5000 / 6000 / 7000.
Application works on Martech Clip with RCD or RCD PRO activation.
LOCK10/13 for radios based on MC68HC11PA8
Hardware required:
- Martech CLIP with RCD or RCD PRO activation
- Wires for making connection from cpu test points
- 12V Power Supply
Radios based on this CPU can be repaired via following ways:
- by connecting to CPU testpoints on radio pcb
- by connecting to service connector which is placed on the rear wall of the radio
Due to the stability and effectiveness of combination we suggest a connection to the TXD / RXD signals, located directly on the motherboard.
Test points are located underneath the radio and on the other side - near the main processor unit.
CLIP we connect directly to the radio, using three cables to the points located on the underside of the radio, according to the scheme:
- Clip PORT1.4> TXD - test point, shown at left
- Clip PORT1.5> RXD - test point, shown at right
- Clip PORT 1.7> GND - left side of capacitor
In the event that the board had other pinout, in general it should be connected as follows:
- Clip PORT1.4> TXD PIN1 of radio processor
- Clip PORT1.5> RXD PIN64 of radio processor
Example of connection of the CPU side:
The second way the servicing of these models is the connection to the test pins on the connector, located between the power connector and the speaker connector.
Please connect directly to the radio CLIP with three wires, according to the scheme:
- Clip PORT1.4 > TXD fifth pin connector (from top)
- Clip PORT1.5 > RXD sixth pin connector (from top)
- Clip PORT1.7 > GND (eg at the GND pin power connector)
Check example video :
YouTube - Ford Lock10 Lock13 Remover with Martech CLIP
Download it:
http://martech.pl/download/CLIP/LOCK...3_Tool_v11.zip
Next models in updates.
Martech Team
Old 11-29-2010, 20:17   #26 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
MC9S12xx Decoder V1.1
- added new version support for models with shifted data in eeprom
(mostly Skoda Stream with MC9s12DG256 cpu)
- next connection pinout is uploaded in support forum, in sticky thread
- app works more smoothly and faster now
SPI Tools V1.1 & MicroWire Tools V1.1
- revised saving data process, adjusted backup options
Download it :
http://martech.pl/download/CLIP/MC9S...12_Decoder.zip
http://martech.pl/download/CLIP/SPI/SPI_Tool.zip
http://martech.pl/download/CLIP/MICR...Wire_Tools.zip
Martech Team
Old 12-05-2010, 20:03   #27 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
RCDPRO V0.0.4.2
- BP2257, Blaupunkt, S4-SS(C) Six Disc ( Opel )
- GHP1000, Grundig, Challange CL2200 ( Ford )
- Kenwood, KDC-DNX5240BT
- Visteon, DVD MB8008 6M2J-19C043-AA/AB/AC ( Ford )
- VWZ4Z7J, Delphi, RCD 510 Prem-8 ( VW )
(second version of latest Dephi release for USA market)
Download it
Martech Team
Old 12-07-2010, 14:46   #28 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
Spansion Flasher V1.0 for Flash memories with SPI Bus
This tool allows to read/write flash memories used in latest car radios/navigations and various gsm phones.
Available commands:
- Read, Write, Erase, Verify Flash
- Help (Pinout)
First version supports Spansion S25FL128P which had been used for example in RNS 315.Similar chips but with different memory architecture can be found in gsm phones too.
We are able to add more supported Flashes, all depends on your needs.
Application is FREE and works with RCD or RCD PRO activation, it works on CLIP only.
Download it: http://martech.pl/download/CLIP/SPI/SPI_Flasher.zip
Regards
Martech Team
Old 12-13-2010, 10:12   #29 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
RNS 315 EU by Technisat supported by RCD PRO !
We are pleased to present to decoding application for latest RNS 315, 3C0 035 279.
Supported functions:
reading out original radio code
keyboard test mode
(application for these models: RCDPRO_RNS315_vXX.prg (where XX its current version)
You can download user manual and application from PRO section on martech.pl/forum.
Regards
Martech Team
MARTECH
Old 12-15-2010, 09:59   #30 (permalink)
Tech mobil's Avatar
Member: 186466
Sonork: 100.112959
Thanks Meter: 8,388
LOCK13 Tool for CC20 / CC40 / CC60 is READY !
Next version of LOCK13_Tool.prg is out. This time it covers:
Mercedes Benz Truckline 24V:
- CC20
- CC40
- CC60
Easy connections directly from CLIP to radio pcb with two wires. Can't be easier and faster
This version includes BETA test for Ford with ST92 mcu, feel free to test.
Actual tool version you can download from:
http://martech.pl/download/CLIP/LOCK13/LOCK13_Tool.zip
Actual USER MANUAL:
ENGLISH: http://martech.pl/download/CLIP/LOCK13/LOCK13_EN.pdf
POLISH: http://martech.pl/download/CLIP/LOCK13/LOCK13_PL.pdf
A reminder:
- application is free for every RCD or PRO user, it works only on CLIP device.
Martech Team
MARTECH
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 29 06-27-2014 21:31
DES key Driver black Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 8 02-08-2014 03:50
8810 mbus-cable zfrank Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-19-1999 17:41
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.47487 seconds with 9 queries
Content Relevant URLs by vBSEO
