Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Android based Phones / Tablets
Android based Phones / Tablets For all of your questions relating to the android mobile phones.
Old 05-23-2011, 18:50   #1 (permalink)
sidramobilecare's Avatar
Member: 888557
Sonork: 100.1608317
Thanks Meter: 27
Dell XCD 28 hard reset
hi friends
Dell XCD 28 hangs on logo
can someone please tell me how to hard reset or flash it
Old 06-10-2011, 05:53   #2 (permalink)
Member: 149938
Thanks Meter: 30
No solution ? no one can help ?
br.
Old 07-21-2011, 11:06   #3 (permalink)
Member: 1030416
Sonork: rinku_2k9
Thanks Meter: 15
dell xcd 28 hard reset any one have solution
Old 07-28-2011, 17:01   #4 (permalink)
chandan_123's Avatar
Member: 801212
Sonork: 100.1657902
Thanks Meter: 608
How to upgrade the Android 2.1 (Eclair) to 2.2 (Froyo) on a Dell XCD28:
Warning: Attempt at your own risk, although the method is fully tested but there can be unexpected results if you fail to follow the instructions properly.
Note:
1. In terms of hardware Dell XCD28 is none other but ZTE Racer and all ROMs available for a racer work on XCD28.
2. All your data shall be erased in the process. Contacts can be exported to SD card and after up gradation you can import them back to your phone from sd card.
Method:
Files required:
1. UniversalAndroot_1.6.1.apk
2. RecoveryManager_v0.36b.apk
3. recoverysu850 -
4. 2.2 Froyo ROM and Update
Steps:
1. Export all your contacts to SD card. Open contacts----Select Menu----Select Import/Export----Select Export to SD card (if prompted to choose contacts from a list the select all by clicking on menu and then click done).
2. Note down the IMEI no. of your phone by removing the battery or by dialing *#06# on your phone.
3. Connect your xcd28 to computer and open you sd card. Now create a new folder, name it as Androroot and copy all the downloaded files to it.
4. Disconnect you xcd28 from computer.
5. Open Filer on phone and open the folder Androroot.
6. Install UniversalAndroot_1.6.1 and open it.
7. Click on Root
8. Once rooting is complete.
9. Go back to androroot and install recovery manager and open it.
10. Provide superuser rights by clicking on allow.
11. Click on recovery and further install recovery.
12. Select the image file on recovery install popup and then confirm by clicking on OK.
13. Click on Reboot in recovery and confirm by clicking OK.
14. Phone will restart in recovery mode.
15. In this mode you can navigate in the menu list by using only volume increase/decrease keys and select a menu by pressing the power on/off button. Touch screen input is not operational in recovery mode.
16. Press these keys in sequence – volume decrease key—volume increase key--- volume decrease key. You’ll see a message on screen Back menu button enable (this enables your power button for selecting a menu option). Note: If you press volume increase—volume decrease—volume increase then it will disable the power button (back menu button).
17. Go to backup and restore option by pressing volume increase key and select by pressing the power button.
18. Select backup by pressing the power button.
19. This will backup your original phone configuration to sd card. The backup is stored in /clockworkmod/backup folder on SD card. This backup can be used to restore back to original firmware if you face any issue with the upgrade.
20. Once you see the backup complete option on your phone screen, navigate to wipe data/factory re option by using the volume keys and select it by pressing the power button.
21. Navigate to Yes – delete all u and select it by pressing power button.
22. When you see Data wipe complete on your screen, navigate to choose zip from sd card and select by pressing power button.
23. Navigate to androroot folder and select by pressing power button.
24. Select Android 2.2.zip using power button.
25. Navigate to Yes-Install Android and press power button.
26. Wait while android is being installed.
27. Once you see the message Install from SD card complete then repeat from step no. 22 but this time select the file update.zip in the androroot folder.
28. Once this installation is complete select go back and then select reboot system now.
29. Phone restarts in Android Froyo. At first boot it may take upto 5-10 mins.
30. If at first start you find your phone is in locked mode, not to worry we can unlock it for free.
31. Visit the site – Free Instant Unlock Codes for Alcatel, Huawei Modems & ZTE Mobile Phones on your computer. Enter your IMEI (noted in step 2), then select the service as ZTE and select ZTE racer in Models. Then fill in the verification code as displayed on the screen and click on order.
Old 09-22-2011, 08:49   #5 (permalink)
Member: 1659510
hey pls reply
hey i m also having the same problem my xcd28 hangs on login n my login process keeps on repeating please help asap
Old 03-23-2012, 08:36   #6 (permalink)
Member: 1195068
Thanks Meter: 8
[QUOTE=sidramobilecare;7353932]hi friends
press power button and down volume key u will get a menu and choose wipe userdata and restore factory settings with the help of volume keys press on off switch to ok u r phone will restart wait for five minuts ur problem is solve i did it 100%working.
Old 06-22-2012, 11:48   #7 (permalink)
Member: 1775395
Dell XCD 28 stuck on Dell Logo / FTM screen
When I switch on my XCD28, it hangs on the Dell logo screen. When i press power button and down volume key (as suggested on the forum), it gets stuck on FTM white screen.
Old 07-05-2012, 03:54   #8 (permalink)
Member: 998896
Thanks Meter: 15
ftm mode
[QUOTE=m.muthafa;8257549]
Originally Posted by sidramobilecare View Post
hi friends
its show only ftm mode ..only
press power button and down volume key u will get a menu and choose wipe userdata and restore factory settings with the help of volume keys press on off switch to ok u r phone will restart wait for five minuts ur problem is solve i did it 100%working any doubt musthafa_r2001@yahoo.com
Old 07-10-2012, 11:19   #9 (permalink)
.::TEJARAM::.'s Avatar
Member: 1681461
Sonork: 100.1650339
Thanks Meter: 925
how to hard reset dell xcd28 only ftm so ?
wbr
tejaram
Old 07-10-2012, 12:04   #10 (permalink)
Member: 1681461
Sonork: 100.1650339
Thanks Meter: 925
dell xcd28 only ftm so ????????????
wrb
tejaram
Old 10-19-2012, 18:33   #11 (permalink)
Crazy Poster
Member: 693055
Thanks Meter: 10
Dell model XCD28 pattern lock removed with the help of rickywyatt solution here is the procedure
if phone will go only in Boot Mode and not going in Recovery+ Hard Rest Mode Than it will work Possible it will work other Huawei Andriod sets (:
first thing if you want downloaded recovery then do so
* download this rickywyatt.rar (rickywyatt.rar) rickywyatt.rar
* ok take out the battery and wait 5 secs then put it back in the press the vol + and the power button it should boot only to the green android logo and the red light stays on
* extract it to your c:\ then install the drives if needed then click install-recovery-windows.bat once done the fone will reboot
* switch phone off the hold the vol- button and press the power button it will boot into recovery
next ....
* in recovery click wipe data/factory reset
* click apply sdcard:update.zip
* once complete click reboot system now
Old 02-04-2013, 08:21   #12 (permalink)
luckymobile jalandhar's Avatar
Member: 1002949
Sonork: 100.1582346
Thanks Meter: 228
after recovery how to install 'ftm' again
Old 03-11-2013, 13:30   #13 (permalink)
Member: 601200
Thanks Meter: 131
Originally Posted by asiftajju2009 View Post
I tried but nothing happen in cmd. showing waiting for device only.
pls reply.
Thanks in advance.
Old 04-16-2013, 12:22   #14 (permalink)
gsm_jeevan's Avatar
Member: 773423
Thanks Meter: 69
pls reply.
Thanks in advance.
Just press power button(don't need to press vol- and power ) and connect cable
the phone will be detect in command mode
after executed some commands the command window will close
the press volume - and power button
now you will get recovery mode
select wipe data (for selection use menu button ) select yes
finish
thanks who gave me the solution ...
Old 09-11-2013, 17:25   #15 (permalink)
Member: 546357
Thanks Meter: 3
Android Multi Tools v1.02b to unlocl
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 08-11-2006 15:29
nokia 5110 v5.28 stefan Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 58 08-14-2000 09:32
Websites with New Unlocking Software Supposedly for v5.28 - 5.30 Fahrenheit Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 05-17-2000 14:35
nokia 5110 v5.28 king76 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 05-07-2000 17:10
Anything new on Nokia 5.28? mona Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 04-29-2000 08:04
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.41286 seconds with 8 queries
Content Relevant URLs by vBSEO
