Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Advance-Box
Old 03-18-2010, 02:39   #1 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,055
Arrow ATF Driver Installation Fix
hello all,
i just want to share, about how to fix such driver issue.
In other case you also will see "Unsupported driver" message, or you just see an empty screen like this when you opened ATF suite like bellow
Now go to device manager, Rigth click on both ATF device to uninstall it.
Click YES when windows confirm this device is about to romove
Next step, click Scan HW on this corner
Now you will see a driver installation wizzard,
Choose install from a list, point it to C:\Program Files\AdvanceBox Turbo Flasher\Driver\ATF_USB_Driver_2.06.00.
Do the same step on second wizzard.
Now ATF Driver shoul be fixed, and ATF suite will working correctly.
Hope it will be usefull for somebody.
The Following 5 Users Say Thank You to gbluez For This Useful Post:
Old 03-18-2010, 06:36   #2 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
can u share the driver too..
:d
i dont see any folder "ATF_USB_DRIVER_2.06.00"
only got one new folder "CDM 2.06.00 WHQL Certified"
is it same driver?
i always get error when init box, u know this problem.
AdvanceBox Turbo Flasher Found
Driver Version : 00020422
Library Version : 00030119
Initialize Device....
Init TRY : 1
Changing Clock to 15mhz..
Init TRY : 2
Init TRY : 3
INIT : FAILED
 -   -  TRY TO RESTART APPLICATION -  -   -
br,
kevin168
Old 03-18-2010, 06:53   #3 (permalink)
Member: 515413
Thanks Meter: 145
:d
is it same driver?
Init TRY : 1
Init TRY : 2
Init TRY : 3
INIT : FAILED
br,
kevin168
download latest version dus..you can find at there..
Old 03-18-2010, 07:17   #4 (permalink)
supportallgsm's Avatar
Member: 194074
Sonork: 100.1574944
Thanks Meter: 160
:d
is it same driver?
Init TRY : 1
Init TRY : 2
Init TRY : 3
INIT : FAILED
br,
kevin168
your box FIRMWARE is wrong need to wait for new firmware
Old 03-18-2010, 12:12   #5 (permalink)
kevin168's Avatar
Member: 183921
Sonork: 100.1590817
Thanks Meter: 205
this flashing problem should be fixed first.
as i know not all user facing this problem.
but didn't get any solution to fix this.
advance is really fast for flashing, but should be more stable.
br,
kevin168
Old 03-18-2010, 12:26   #6 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,055
br,
kevin168
put your naughty hands away from ATF. you teared the warranty seal don't you?
Old 03-20-2010, 02:53   #7 (permalink)
Member: 481619
Thanks Meter: 7
I need "ATF_USB_DRIVER_2.06.00" .Please upload link download, help me !
Old 03-20-2010, 02:59   #8 (permalink)
marvin03's Avatar
Member: 1015389
Sonork: 19830303
Thanks Meter: 500
all drivers found in here open your drive c look for it...
Old 03-20-2010, 03:35   #9 (permalink)
Member: 481619
Thanks Meter: 7
I install Version v2010.0.1.22 driver in folder C:\Program Files\AdvanceBox Turbo Flasher\Driver not folder name "ATF_USB_DRIVER_2.06.00" ,only folder name "CDM 2.06.00 WHQL Certified" and other folder .
When i used tool JAF end ,after used tool ATF then error :
Old 03-20-2010, 03:49   #10 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,055
Install old ATF version first. You will found more driver.
finally, someone wrote for me exactly what i mean
First conflict is with NSPro, and now also with ATF. Perhaps JAF coder always busy just to make such driver update.
Old 03-20-2010, 03:50   #11 (permalink)
probs's Avatar
Member: 745804
Thanks Meter: 32
theres a conflict between jaf and advance flasher..
dont use it in 1 computer, or else try to restart your computer every time you use jaf or advance.
now, i used two computer, one computer jaf and the other advance and no more problem.
Old 03-20-2010, 03:54   #12 (permalink)
gbluez's Avatar
Member: 73565
Thanks Meter: 5,055
no, it can work together.
But when you installing JAF driver, windows will prompt about old driver version. Always answer that confirmation with "No to all"
Old 03-20-2010, 05:33   #13 (permalink)
Member: 1001942
Sonork: 100.1581646
Thanks Meter: 22
try it ...............
Originally Posted by ulymar View Post
hi! remove ATFbox and install "CDM20600.exe and try again.
br,
Old 02-27-2014, 16:04   #14 (permalink)
Member: 1935244
Sonork: 174877s
i have not enter ATF support site plz help me.
Old 02-27-2014, 20:28   #15 (permalink)
..::Angel::..'s Avatar
Member: 643472
Sonork: 100.96901
Thanks Meter: 16,086
Could you please be more specific about your problem?
you can install fixed rev 1.0 and the latest version together? gprsman MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 02-11-2010 19:56
Problem after Pkeydriver install, software for driver installed but Pkey dont work mobile-elite BB5KING 0 12-03-2008 12:28
Installer Fix......please!! gbluez Cruiser Suite 0 06-21-2005 21:18
PST USB Drivers installation problems drunlock Motorola P2k 3 04-24-2003 10:09
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.56812 seconds with 8 queries
Content Relevant URLs by vBSEO
