Unlock Server
Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Rocker Team products > RIFFBOX
Old 10-29-2010, 10:40   #1 (permalink)
Member: 522330
Thanks Meter: 18
Haw repair dead boot on LG GT540
Hi.Haw to repair dead boot on my LG GT540.The CPU is QUALCOMM MSM7227.Any body help me
Old 10-29-2010, 10:54   #2 (permalink)
Member: 522330
Thanks Meter: 18
Gt540
I have pinout for JTAG but i dont know haw to repair this phone
Old 10-29-2010, 11:21   #3 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Thanks Meter: 26,182
Hi,
This model is not supported at the moment. Also, as it seems, JTAG access is disabled in LG production phones.
However, You can send Your PCB to our dev team for test.
Contact me by PM for more details.
Old 02-11-2011, 09:26   #4 (permalink)
Member: 783012
Thanks Meter: 3
Seeking a full LG GT540 Optimus
Actually sought out the fact that the unit tightly refuses proshivatsya after Riff recover boot.
Old 02-12-2011, 18:01   #5 (permalink)
Member: 110088
Thanks Meter: 28
Gt540 boot done- flash KDZ not work
hello
I fixed the boot in the gt540 but I can not program this lg
The phone comes in a download mode, sees the computer installs the modem and com port. Still crashes when programming error. Here is the log of the KDZ
[16:09:31:984] : =============================================
[16:09:32:000] : Log is started on 11.02.2011, at 16:09:31:984,
executable: E:\gt540\KDZ FW UPD EN\KDZ_FW_UPD_EN\KDZ_FW_UPD.exe (ProcID: 0x00000f84),
compile time : Sep 8 2010 17:19:53
[16:09:32:000] : Version :
[16:09:32:000] : strFilename1 = V20
[16:09:32:000] : m_DlMode = 4, m_strBinaryPath = C:\Documents and Settings\All Users\Dane aplikacji\LGMOBILEAX\Phone\DZ_GT540AT-00-V20a-APP-XX-OCT-05-2010+0.dz, m_nSelectedImages= 70787108
[16:10:34:734] : Start Web Downloading
[16:10:34:765] : Get Usb Port
[16:10:35:984] : rsi.strFriendlyName=Port komunikacyjny (COM1)
[16:10:36:000] : Remove Port komunikacyjny (COM1)
[16:10:36:000] : rsi.strFriendlyName=Z3X BOX Serial Port (COM4)
[16:10:36:000] : Remove Z3X BOX Serial Port (COM4)
[16:10:36:000] : rsi.strFriendlyName=RIM Virtual Serial Port v2 (COM165)
[16:10:36:000] : Remove RIM Virtual Serial Port v2 (COM165)
[16:10:36:000] : rsi.strFriendlyName=LGE Android USB Serial Port (COM168)
[16:10:36:000] : FriendlyNameList[iii].szFriendlyName=LGE Android USB Serial Port
[16:10:36:031] : WM_COPYDATA ޽à şłż 1 - COM168
[16:10:36:031] : Port = COM168
[16:10:36:031] : Clear
[16:10:36:046] : Clear
[16:10:36:046] : UNKNOWN : Req(12) -> Rsp(13)
[16:10:36:062] : UNKNOWN : Req(12) -> Rsp(13)
[16:10:36:062] : >> DIAG_STATUS_F FAILED
[16:10:36:062] : >>Get Model Name [DIAG_VERNO_F]
[16:10:36:062] : Clear
[16:10:36:062] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:10:36:078] : BAD CONN MODE : Req(0) -> Rsp(3)
[16:10:36:078] : Clear
[16:10:36:078] : FAIL (No Phone)
[16:10:36:078] : GetModelName() Operation Failed Check Diag CMD
[16:10:36:078] : EMERGENCY Booting Mode
[16:10:36:078] : >>Get Model Name in Emergency Mode [DLOAD_VERREQ_F]
[16:10:36:078] : BS/GT540/7Dinformation
[16:10:36:078] : WM_COPYDATA ޽à şłż 0 - GT540
[16:10:36:078] : >>Get Mobile SW [DIAG_EXT_BUILD_ID_F]
[16:10:36:078] : DLOAD_NAK_F reason_msb = 6, reason_lsb = 6
[16:10:36:078] : [ DLOAD ERROR ] : NAK_INVALID_CMD
[16:10:36:078] : Phone_Diag_Status = FALSE
[16:10:36:078] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
[16:10:36:078] : [ DLOAD ERROR ] : NAK_INVALID_LEN
[16:10:36:093] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
[16:10:36:093] : [ DLOAD ERROR ] : NAK_INVALID_LEN
[16:10:36:125] : NV Write Fail : NV ITEM 9028(9028)
[16:10:36:234] : m_pPhoneCtrl->m_pDload->Dl_GetCommMode(&m_pPhoneCtrl->m_pDload->m_nCommMode)
[16:10:36:234] : >> GET DLOAD COMM MODE
[16:10:36:234] : Clear
[16:10:36:234] : [GetCommMode] Communication mode : 2
[16:10:36:250] : Pre Nand Download
[16:10:36:250] : >>Set Trusted Mode [DLOAD_NAND_SEC_MODE] sec_mode = 1 (1=trusted 0=NonTrusted)
[16:10:36:250] : WM_COPYDATA ޽à şłż 3 - TRUSTED MODE
[16:10:36:250] : Clear
[16:10:36:250] : [COM168] >>NandFlashInitWithFile(PARTITION TBL), BinType =8
[16:10:36:250] : NandFlashInitWithFile :: LG3GBinaryList[BinType].szBinaryTypeName = PARTITION TBL, BinType = 8
[16:10:36:250] : WM_COPYDATA ޽à şłż 3 - INIT PARTITION TBL
[16:10:36:265] : Clear
[16:10:36:265] : ޽à şłż TYPE_WPARAM_WRITE_TO_SDRAM 3
[16:10:36:265] : m_nSelectedImages= 70787108,Type= 3
[16:10:36:265] : [COM0] ޽à şłż TYPE_WPARAM_WRITE_AMSS 15
[16:10:36:265] : [COM168] >>NandFlashInitWithFile(AMSS MODEM HEADER), BinType =14
[16:10:36:265] : NandFlashInitWithFile :: LG3GBinaryList[BinType].szBinaryTypeName = AMSS MODEM HEADER, BinType = 14
[16:10:36:296] : WM_COPYDATA ޽à şłż 3 - INIT AMSS MODEM HEADER
[16:10:36:296] : Clear
[16:10:36:296] : >> AMSS FLASHING ...
[16:10:36:296] : ޽à şłż ProgreassiveBar Init wParam TYPE_WPARAM_PROGRESSIVE_POS=5 lParam(pos)=0 nResult=0
[16:10:36:328] : Sending Pkt Seq : 0
[16:10:36:328] : Clear
[16:10:36:328] : Sending Pkt Seq : 1
[16:10:36:328] : Sending Pkt Seq : 2
[16:10:36:328] : Sending Pkt Seq : 3
[16:10:36:328] : Sending Pkt Seq : 4
[16:10:36:328] : Sending Pkt Seq : 5
[16:10:36:328] : Sending Pkt Seq : 6
[16:10:36:328] : Sending Pkt Seq : 7
[16:10:36:328] : Sending Pkt Seq : 8
[16:10:36:328] : Sending Pkt Seq : 9
[16:10:36:328] : Sending Pkt Seq : 10
[16:10:36:328] : Sending Pkt Seq : 11
[16:10:36:328] : Sending Pkt Seq : 12
[16:10:36:328] : Sending Pkt Seq : 13
[16:10:36:328] : Sending Pkt Seq : 14
[16:10:36:328] : Sending Pkt Seq : 15
[16:10:36:328] : Sending Pkt Seq : 16
[16:10:36:328] : Sending Pkt Seq : 17
[16:10:36:328] : Sending Pkt Seq : 18
[16:10:36:328] : Sending Pkt Seq : 19
[16:10:36:328] : Sending Pkt Seq : 20
[16:10:36:328] : Sending Pkt Seq : 21
[16:10:36:328] : Sending Pkt Seq : 22
[16:10:36:328] : Sending Pkt Seq : 23
[16:10:36:328] : Sending Pkt Seq : 24
[16:10:36:875] : Error Read in WaitRsp
[16:10:36:875] : Sending Pkt Seq : 25
[16:10:36:968] : Error Read in WaitRsp
[16:10:36:968] : Sending Pkt Seq : 26
[16:10:36:968] : @@ Cable Disconnected - Writing : 5
[16:10:36:968] : Clear
[16:10:36:968] : WM_COPYDATA ޽à şłż 3 - Close Port
[16:10:36:968] : Close Port<<
[16:10:36:968] : [COM0] ERROR Dl_AsyncWrite() TYPE_LPARAM_UPGRADE_ERROR_WRITE_TO_FLASH
[16:10:36:968] : TYPE_WPARAM_UPGRADE_ERROR
[16:10:36:968] : ޽à şłż - TYPE_WPARAM_UPGRADE_ERROR Error Code = 4008
[16:10:37:156] : Log finished
The Following User Says Thank You to gadzetxp For This Useful Post:
Old 02-21-2011, 19:59   #6 (permalink)
Member: 6142
Thanks Meter: 37
Same problem here!
After repair boot,phone can go to download mode ,pc can detect but flashing not work! I try to flash with original flasher and vygis software too!
Old 02-21-2011, 21:55   #7 (permalink)
Member: 110088
Thanks Meter: 28
Vigis programmed or not. I do not want to switch in the boot flash
Old 02-22-2011, 17:22   #8 (permalink)
legija's Avatar
Member: 256342
Sonork: None
Hi,
We tested GT540 with v20D KDZ files.
Old 03-02-2011, 12:56   #9 (permalink)
Registered User
maryajne's Avatar
Member: 305964
Thanks Meter: 69
help GT540 dead boot
mr product supported help me about lg gt540 deadboot always like jtag connected properly
can help me about the settings
Open serial port...OK
Connecting to the RIFF Box...OK
Firmware Version: 1.18, JTAG Manager Version: 1.26
Selected Resurrector: [LG GT540]
Connecting to the dead body...OK
Detected dead body ID: 0x203C00E1 - CORRECT!
Set I/O Voltage reads as 2.61V, TCK Frequency is RTCK
Adaptive Clocking RTCK Sampling is: [Sample at 1 MHz]
Resurrection sequence started.
Establish communication with the phone...OK
Initializing internal hardware configuration...OK
Uploading resurrector data into memory...FAILED
ERROR: Memory access timed out.
Initializing internal hardware configuration...FAILED
ERROR: Read/Write memory failed during H/W Init.
Adaptive Clocking RTCK Sampling is: [Sample at 6 MHz]
Old 03-02-2011, 13:13   #10 (permalink)
kiken's Avatar
Member: 817951
Sonork: 100.1584874
Thanks Meter: 52
gt540 repair only use usb cable ! chk it gnd have good conneted?
i can use TeamViewer help u !if u want help .please contact me
Sonork: 100.1584874
b.r
hhrj
Old 03-03-2011, 03:24   #11 (permalink)
Registered User
maryajne's Avatar
Member: 305964
Thanks Meter: 69
up this thread help me please
Adaptive Clocking RTCK Sampling is: [Sample at 3 MHz]
Uploading resurrector data into memory...OK
Starting communication with resurrector...FAILED
ERROR: Wrong DCC data checksum.
ERROR: DCC Loader Execute failed. Terminating.
error like this
Old 03-03-2011, 03:32   #12 (permalink)
Registered User
maryajne's Avatar
Member: 305964
Thanks Meter: 69
Set I/O Voltage reads as 2.61V, TCK Frequency is 100 kHz
ERROR: Wrong DCC data length received.
Old 03-07-2011, 18:57   #13 (permalink)
gecata's Avatar
Member: 16994
Thanks Meter: 157
Same problem here. Is there any solution?
Originally Posted by roniri View Post
Same problem here!
Old 03-17-2011, 10:25   #14 (permalink)
Member: 682583
gt540 after repair imposible to flash
I just repaired boot in gt540 .Phone is connecting to pc in emergency mode but its imposible to flash i tried whit vygis . Please help
Old 03-17-2011, 10:44   #15 (permalink)
Member: 682583
aa i forgot about importand thing lcd looks like dead when i power it on . And one more thing phone when is going to download mode is unrecognized device and i assume becouse of that i cant flash it ..
6110 power does not stay on sc~micro Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-30-2014 08:14
what prog changes imei on 6110 and how do i do it? Ravetrancer Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 07-31-2012 20:09
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.79334 seconds with 9 queries
Content Relevant URLs by vBSEO
