Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GPGIndustries Support section > Distributed Devices by GPG > Dragon Box
Dragon Box Chinese Phone Tool
Old 04-09-2011, 05:44   #1 (permalink)
Member: 736137
Sonork: qwsa
Thanks Meter: 14
Nokia B200 3 sim Active china mobile
i cannot connect this phone.please give me solution dragon team.
i need remove security code
Old 04-09-2011, 05:53   #2 (permalink)
Cheater -Don't Deal with him-
Member: 1050335
Sonork: 100.1602801
Thanks Meter: 4,170
Post some more info about your phone(CHIP,Jack name,ETC) and what error come during connecting
Old 04-09-2011, 05:54   #3 (permalink)
33872's Avatar
Member: 442421
Thanks Meter: 68
select tracker & connect wait processing after save restore setting
Old 04-09-2011, 06:41   #4 (permalink)
SHIJILFONOTLY's Avatar
Member: 351924
Sonork: 100.1581941
Thanks Meter: 12,195
bro what error u faced?
look this video
GPGDragon Demo videos powered by SHIJILFONOTLY
Old 04-09-2011, 06:58   #5 (permalink)
RATHISH.TR_ALUVA's Avatar
Member: 439555
Sonork: 100.1603756
Thanks Meter: 131
sir
Gfive u869 came with invalid sim
try to change imei when entering to meta phone gets power on in normal mode so cant write imei...
then i flashed with other file (downloaded from this forum) it works perfectly.
when try to call it restarts again with invalid sim...
any solution??
log:
Initializing...
DA_LIB_VER_3.2.1.3
Tip: The phone must be able to power-on normally
It is sensing the pinout fast,please hold on the phone Power key
RXD=12 TXD=10
Connecting...Please hold on the POWER key until the red gauge is going...
BB:6226, HardwareVer:8A02, SoftwareVer:8A01
Read info...ok, Waitting enter meta...
Connection time out.
Old 04-09-2011, 07:19   #6 (permalink)
Member: 1050335
Sonork: 100.1602801
Thanks Meter: 4,170
Change your handset imei with IMEI option(Not use tracker)
Old 04-09-2011, 07:53   #7 (permalink)
Registered User
Member: 737047
Sonork: 1614214
Thanks Meter: 31
b200 china
i have alread connected 3 mobiles set and contact with me on my id
asad_love36@yahoo.com
i will give connectivity image contact and do not forget tanx
bye take care
gpgdragon team.
The Following User Says Thank You to asadkhali For This Useful Post:
Old 04-12-2011, 13:16   #8 (permalink)
Member: 207561
Thanks Meter: 37
rizwan bahi china mobile B200 not be conecet my phone lock i wany code deafould i have gop dragon box plz help me...............urgant
Old 04-12-2011, 13:25   #9 (permalink)
Member: 1050335
Sonork: 100.1602801
Thanks Meter: 4,170
If your face this problem come "BOOT set failure, continue to scan...
Sense failure"
so you need connect your handset via RX/TX point from board
Old 05-02-2011, 13:13   #10 (permalink)
Member: 946381
Thanks Meter: 80
nokia b200 imei problem. phone can't connect with computer
Old 05-02-2011, 13:20   #11 (permalink)
Moderator
Faheem Anjum's Avatar
Member: 399832
Thanks Meter: 22,295
show log here .............
Old 05-02-2011, 13:23   #12 (permalink)
Member: 1050335
Sonork: 100.1602801
Thanks Meter: 4,170
Use this method Dragon School<<< Problems and Solutions >>> and must post me result
Old 07-06-2011, 11:12   #13 (permalink)
Member: 1325952
Sonork: chahat
sir ji 100% working thnx for code gpg dragon
Old 07-29-2011, 15:57   #14 (permalink)
Member: 701004
Thanks Meter: 96
one more mobile not unlock by gpg dragon
Wanli w6
there is not pin out on circuit
Initializing...
DA_LIB_VER_3.4.1.2
RXD=1 TXD=2
Any errors please select another boot and try again.
Failed to read HardCode, REG=0x80000008
Error: Failed to read REG=0x80010008
Error: Failed to read REG=0x84010008
Error: Failed to read REG=0x80001008
Old 07-30-2011, 06:00   #15 (permalink)
Moderator
Member: 399832
Wanli w6
Initializing...
DA_LIB_VER_3.4.1.2
RXD=1 TXD=2
what flash chip inside the phone ?
use right tab for right flash chip
The Following User Says Thank You to Faheem Anjum For This Useful Post:
Need software upgrade for Nokia 5110 ptkrf Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 29 06-27-2014 21:31
New Nokia Software!!!!!!! Jefferson Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 48 05-12-2013 13:07
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.34286 seconds with 8 queries
Content Relevant URLs by vBSEO
