Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Android based phones
Sony Android based phones General SONY Android based phones discussion, firmwares, solution, root, help
Old 01-20-2011, 12:14   #1 (permalink)
perspolis's Avatar
Member: 60103
Sonork: 108841
Thanks Meter: 1,314
Flash,Root,Unroot,installing Xperia X10/X10 Mini/X10 Mini Pro
Hi
This time the X10 ROM Flasher Tools Final version prepared for the update to 2.1 via the Flash Tool Tool
Developer Bin4ry little known by altering the structure more efficient programs.
All of these models, either a promise or flash ROM update is:
1. Online updates from the Sony Ericsson server.
2. Offline Update from the Executive Program and select the new ROM.
Offline Update (Offline)
* Supplies needed: Mini Usb Cable
انجمن جی* اس* ام ایران - صف*ه اصلی
* Software Requirements:
* Program Pdytr: Xperia Tools
* Program Pdytr: X10Flash-2.1-nonGui
* ROM file: Xperia_X10_2.1
* ROM file: Xperia_X10_Mini_E10_2.1
* ROM file: Xperia_X10_Mini_Pro_U20_2.1
Sony Ericsson Flash Xperia_X10
Android SDK, and drivers must have a phone.
For drivers
Sony Ericsson PC Companion Program
- Receive and file Xperia Tools to Extract:
- After receiving Xperia_X10_2.1 ROM and Extract it, the ROM files in the folder to copy the firmware!
Tip: Extract Files folder in the firmware of the Xperia Tools are!
- File Select Xperia Tools.bat run!
- Click the Flash option in the program.
- now, like the image below: Then click on Go Firmware select OK....
- in the phone system connect to the Flash Mode (hold down the Back button press the power button and had the better in this case connect the USB cable.) began to update the phone now will wait two minutes to update All will be clear and the phone
Old 01-20-2011, 12:21   #2 (permalink)
perspolis's Avatar
Member: 60103
Sonork: 108841
Thanks Meter: 1,314
Root,Unroot Xperia X10/X10 Mini/X10 Mini Pro
* Program run Xperia Tools.
* On the phone mode and connect the USB debaging following the path you are active:
Settings> Applications> Development and connect the phone to PC via USB
* Program Xperia Tools such as Root option click the image below.
* As you see in the image file z4root.apk through the program is installed on the phone then run it gets routed to your phone
* Clean with a run time option to remove installed applications and the phone is routed out and the primary mode Drmyayd factory.
Note: Root plus options on Android phones will work to root out phones also works for the following list:
  • Samsung Galaxy S - All variants
  • * Backflip
  • * SE XPERIA X10
  • * SE XPERIA X10 Mini
  • * SE XPERIA X10 Mini Pro
  • * Droid 2
  • * Galaxy Tab
  • * Galaxy I5700
  • * Galaxy 3 I5800
  • * Droid X
  • * Samsung Acclaim
  • * Cricket Huawei Ascend
  • * Motorola Cliq
  • * Huawei 8120
  • * Hero
  • * G1
  • * Optimus T
  • * Droid 1
  • * Garmin Asus A50
  • * Motorola Defy
  • * LG Ally
  • * Motorola Flipside
  • * Motorola Milestone 2
The Following User Says Thank You to perspolis For This Useful Post:
Old 01-20-2011, 12:29   #3 (permalink)
perspolis's Avatar
Member: 60103
Sonork: 108841
Thanks Meter: 1,314
Android programs to a complete installation quick and easy
One other interesting functions of these programs install on the phone with fun and fast way is to merge the features of this program is unique.
How to install:
* Get into Castom folder and open the apps folder.
* your choice apk files in this folder transfer.
Xperia Tools * now run the program.
* On the Flash mode and connect USB debaging following the path of the active:
* Customize option at this stage in the hit program.
* All applications as in the application form once you see the phone is installed.
Copy Right Reserved okay
The Following 4 Users Say Thank You to perspolis For This Useful Post:
Old 02-01-2011, 07:02   #4 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,890
Developer of this tool is
xda-developers
Bin4ry
Someone just modified the header title of this app.
Show minimum respect to original author.
The Following 3 Users Say Thank You to .:SUBRATA:. For This Useful Post:
5110 flash new software , need help steve Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 01-03-2015 04:41
Seeking for flash nokia 5110 old version (3 version) can exchange for new Tomas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 07-05-2014 11:33
Nokia Flash Content. Phantom Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 05-01-2000 23:28
need to flash 6110 paulomt1 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-16-1999 12:20
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.35623 seconds with 8 queries
Content Relevant URLs by vBSEO
