Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Sony Ericsson > Sony Ericsson
Sony Ericsson
  • ARM Inside: A3618,R600,T100,T100c,T102,T105,T106,Z200,J200,J200i,J200c, J210,J220,230,Z300 etc.
  • AVR Inside: R520,T200,T202,T226,T226m,T226s,T230,T237,T238,T290,T290a,T290c,T290i, T300,T302,T306,T310,T312,T316,T39,T65,T68,T610,T616,T618,T628,T630,T637,P800,P802, P900,P908,P910,Z600,Z608.
  • New ARM Inside (SEMC):D750,F500,J300,K300,K310,K500,K506c,K508,K510,K600,K608,K610,K700,K750,K790,M600, P990,S700,S710,W300,W550,W600,W700,W800,W810,W900,V600,V630,V800,Z1010,Z300,Z500,Z520,Z530,Z550,Z800.
  • CR 16B Inside:T66,T600,T600c,T602.
  • ODM:J100.
  • C Series: C510, C702, C901, C902, C903, C905
  • G Series: G502, G705
  • K Series: K630, K660, K850
  • T Series: T700, T707, T715
  • V Series: V640
  • W Series: W508, W595, W705, W715, W760, W890, W902, W910, W980, W995
  • Z Series: Z750, Z770, Z780
  • Reply
    Old 02-24-2010, 11:08   #1 (permalink)
    Member: 482670
    Thanks Meter: 125
    How to flash PDA G900 by setool??
    that is no respone....got 2 g900 new set when i insert usb cable or com cable has nth to respone..pls help ..
    USBFLASH DRIVER VERSION 02.02.00.05
    CFG:000000000000
    PLEASE IGNORE "PRESS POWER ON" MESSAGES !!!!
    PROCEDURE WAS STOPPED BY USER
    CAN'T DETECT PDA
    PDA setup failed
    Elapsed: 14 secs.
    CFG:000000000000
    wat is this problem ????
    Old 02-24-2010, 11:29   #2 (permalink)
    Moderator
    Faheem Anjum's Avatar
    Member: 399832
    Thanks Meter: 22,390
    fst of all PDA phone just flash with USB cable ..... no need to mark in setting tab .. just choose the file rar type and press flash button connect the set with c button no 2 and 5 button try and replay
    Old 02-27-2010, 03:53   #3 (permalink)
    Member: 482670
    Thanks Meter: 125
    sry dont understand by ur means?? i try ur idea no click any option setting but still same on no respond from phone.. me from malaysia so i nid to choose whict file from support area? there only got SG ,TW , HK.. ~~
    Old 02-28-2010, 07:09   #4 (permalink)
    roney_nexus's Avatar
    Member: 288504
    Sonork: .:100.1587032:.
    Thanks Meter: 2,255
    download needed firmware package.
    add it to firmware area on PDA tab.
    DO NOT UNZIP PACKAGE, JUST ADD IT AS IS.
    on settings,check "signed mode"
    press flash....
    The Following 5 Users Say Thank You to roney_nexus For This Useful Post:
    Old 03-20-2010, 09:43   #5 (permalink)
    eepromyu's Avatar
    Member: 73378
    Sonork: Eprom
    Thanks Meter: 167
    SIGNED MODE (USING SERVER)
    CFG:100100000000
    writing "F:\setool\g900\G900_MR2_WORLD1__R9N002_R1F_R6K842 _R6K836_.zip"
    Processing package
    F:\setool\g900\G900_MR2_WORLD1__R9N002_R1F_R6K842_ R6K836_.zip
    detected MASTER on COM202, SLAVE on COM202
    llbug: COM202 open error: "Access is denied"
    slave can't be inited
    PDA setup failed
    Break.
    Elapsed: 161 secs.
    CFG:100100000000
    Processing package
    detected MASTER on COM202, SLAVE on COM208
    PDA EROM VERSION: 1202-0238 R1A01
    package not contains ISP files
    Processing ACPU files
    PROCESSING: Core OS
    FILE FLASHED OK
    PROCESSING: ROFS1
    FILE FLASHED OK
    PROCESSING: ROFS1 Extension
    FILE FLASHED OK
    PROCESSING: ROFS2
    FILE FLASHED OK
    PROCESSING: USERDATA
    FILE FLASHED OK
    fetched MASTER on COM202, SLAVE on COM208
    NEW SECURITY (RESPIN) PHONE
    ChipID:7100,EMP protocol:0301
    PHONE STATE: "RETAIL"
    FLASH CID: 0053
    Speed:921600
    OTP: LOCKED:1 CID:52 PAF:1 IMEI:35388602145534 CERT:RED
    LDR:060524 0930 LIECXC1325414_DB2000_FLASHLOADER_R1A003
    FLASH ID:2010
    Processing CCPU files
    PROCESSING: R5C01_CXC162175_CCPU_fs_EN_Red_CID53_DB2001.softwa re
    CURRENT FLASH FILE CID:53
    SSW uses full hash, hash len is: 160
    Will flash 8 blocks...
    PROCESSING: R9N002_CXC162037_CCPU_EN_MO_Red_CID53_DB2001.softw are
    SSW uses full hash, hash len is: 2120
    Will flash 106 blocks...
    Processing update files
    LDR:070405 1245 NPA1_CXC1327363_1_SEMC_CS_LOADER_1_P1E
    loader GDFS startup executed
    PROCESSING: R6G804_CAH1621133_Settings_TY_LockRemoved.gdfs
    Writing GDFS var 0002/06D6/0001
    Writing GDFS var 0002/06D4/0005
    Writing GDFS var 0002/06D3/000F
    Writing GDFS var 0000/0094/0001
    PROCESSING: R6K842_CAH1621133_PUQData_TY_World1.gdfs
    Writing GDFS var 0002/079E/0053
    Elapsed: 519 secs.
    The Following User Says Thank You to eepromyu For This Useful Post:
    Old 10-09-2011, 12:54   #6 (permalink)
    Member: 388272
    Thanks Meter: 18
    cant going gdfs pls help me
    Old 10-09-2011, 13:19   #7 (permalink)
    Member: 302596
    Thanks Meter: 270
    @ karthi_mysite
    fallowed what the previous solution stated.
    Old 10-09-2011, 13:44   #8 (permalink)
    Member: 388272
    Thanks Meter: 18
    cant going gdfs for g900
    Old 10-24-2011, 07:43   #9 (permalink)
    Member: 182513
    Thanks Meter: 24
    DETECTED PORTS [MASTER COM51,SLAVE COM52]
    PROCESSING: Core OS
    FILE FLASHED OK
    PROCESSING: ROFS1
    FILE FLASHED OK
    FILE FLASHED OK
    PROCESSING: ROFS2
    FILE FLASHED OK
    FILE FLASHED OK
    FAILED TO SETUP PHONE
    Break.
    Old 10-24-2011, 09:36   #10 (permalink)
    Member: 867442
    Sonork: 100.1602740
    Thanks Meter: 142
    g 900 working very slow
    CFG:000000000000
    DETECTED PORTS [MASTER COM57,SLAVE COM58]
    FLASH CID: 0053
    Speed:921600
    LDR:070410 1354 NPACXC125871_DB2000_PRODUCTIONIDLOADER_P3B
    FLASH ID: 8964
    OTP LOCKED:1 CID:52 PAF:1 IMEI:35388602556177 CERT:RED
    ACTIVE CID:53 COLOR:RED
    phone model (from GDFS): G900
    part number: FAD-3022019-BV
    Phone part version: 1203-6566 R9N002
    Organizer part version: 1203-8784 R6K842
    CDA part version: 1204-3148 R6K836
    CCPU part version: 1203-6568 R5C01
    USERCODE:0000
    Elapsed: 33 secs.
    Old 10-24-2011, 09:39   #11 (permalink)
    Member: 867442
    Sonork: 100.1602740
    Thanks Meter: 142
    but when i flash it starts flashing continuosly even after writing second file n then gives error
    CFG:000000000000
    writing "D:\SETUP\SE TOOL\es tool sony\G900\G900_MR2_WORLD1__R9N002_R1F_R6K842_R6K83 6_.zip"
    Processing package
    PROCESSING: Core OS
    FILE FLASHED OK
    PROCESSING: ROFS1
    FILE FLASHED OK
    FILE FLASHED OK
    PROCESSING: ROFS2
    FILE FLASHED OK
    FILE FLASHED OK
    FLASH CID: 0053
    Speed:921600
    FLASH ID: 8964
    CURRENT FLASH FILE CID: 53
    Will flash 8 blocks ...
    Will flash 106 blocks ...
    FLASH CID: 0053
    Speed:921600
    FLASH ID: 8964
    writing "D:\SETUP\SE TOOL\es tool sony\G900\G900_R6K842_CUST_BLX_1207_6259_R8A.zip"
    Processing package
    PROCESSING: Core OS
    FILE FLASHED OK
    PROCESSING: ROFS1
    FILE FLASHED OK
    FILE FLASHED OK
    PROCESSING: ROFS2
    FILE FLASHED OK
    pda flash block timeout (0/2112)
    Break.
    Elapsed: 865 secs.
    how to flash G900 PDA on setool? Brother Hui Sony Ericsson 6 02-27-2010 22:30
    How to flash PDA G900 on setool v9.15060?? Brother Hui SETool2 1 02-24-2010 10:55
    How to unlock SE G900 by SETOOL GOLAM SETool2 2 03-02-2009 12:13
    How to flash PDA of P800 because freeze on logo start up? gsmnice Sony Ericsson 0 11-11-2004 21:41
    How to flash PDA in 9110? gsmsalers Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 03-29-2003 16:48
    Powered by Searchlight © 2015 Axivo Inc.
    vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
    - GSM Hosting Ltd. - 1999-2015 -
    Page generated in 0.33597 seconds with 8 queries
    Content Relevant URLs by vBSEO
