Unlock Server
Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / 3G / 3GS
Old 09-25-2010, 07:30   #1 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 707
iPhone 3G Error 3194 When Restoring! (Solution)
This iPhone 3G OS 4.0, when jailbreaked and unlocked resulting to NO SERVICE or no signal at all. Since I don't want to upgrade it to a newer firmware to avoid me using wifi, because this thing is not available!
So I'll restore this phone to repeat the process of jailbreak and unlock, but Sadly enough, for you guys who wanted to erase or restore your iPhone 3G into iOS 4 using iTunes 9.2 will be out of luck, since Apple is no longer signing the version 4.0 anymore. Instead if you insist on restoring your iPhone 3G into iOS 4.0 instead of 4.1, you’ll have error 3194 on iTunes.
[img]http://1.bp.********.com/_jzFOOHRsqBM/TJ2QotEE5VI/AAAAAAAAAxk/hd6_5peYQrQ/s400/error+3194+1.png[/img]
This is unfortunate, you can not upgrade your iPhone 3G officially, but.
You can still restore it unofficially.
Basically when iTunes showing “Verifying with Apple bla…”, that means iTunes is checking for signature from Apple’s signature server. And guess what, Apple no longer sign your iOS 4.0 firmware which makes your device is not eligible for restore, unless you update with iOS 4.0.1, this is one way for apple to force its customer to upgrade into the latest firmware, so all hacks will be eliminated if one is provided in Apple’s latest firmware version.
Now, we can bypass this signature checking when iTunes contacting Apple by changing the server from Apple’s Signature Server into Cydia’s clone of Apple Server.
Now here's the STEPS to be you to restore the same OS in your iPhone 3G!
It’s easy (for Windows):
1. Fired up your cmd.exe, and make sure you have administrator privileges.
2. Type this is: CD \WINDOWS\SYSTEM32\DRIVERS\ETC
3. Type this: edit hosts
4. Add this to the last line: 74.208.10.249 gs.apple.com
5. Restart your iTunes.
6. Put your iPhone 3G in recovery mode, by turn off the device first and pull the plug from your PC. Then press Home Button and connect your iPhone into your PC, then wait until the Recovery Icon shows up (iTunes icon with cable above it).
7. Now, restore your iPhone with your firmware iOS 4.0 (in windows using Shift + Restore, in mac using Options + Restore)
8. Voila, it will be restored succesfully, it’s fully working on my iPhone 3G.
You should notice the number 4 step is the bypass server, by pointing Apple Authentication domain into Cydia’s Server IP Address, this is trivial in unix, and thankfully, we can do this in Windows.
On Mac, it’s the same, except for the cmd.exe and the cd thing should be into /etc/hosts…
Enjoy your Jailbreak Restore…
Here are some screen cap while editing and restoring:
[img]http://1.bp.********.com/_jzFOOHRsqBM/TJ2SEinAbBI/AAAAAAAAAxo/V4wUmPhR4g4/s400/error+2.png[/img]
[img]http://1.bp.********.com/_jzFOOHRsqBM/TJ2TBCEjxxI/AAAAAAAAAxw/QQ2H5OFms6A/s320/error5.png[/img]
[img]http://1.bp.********.com/_jzFOOHRsqBM/TJ2Tv1moPnI/AAAAAAAAAx0/e0VXq0H35gQ/s320/error6.png[/img]
After those process, I use redsn0w_win_0.9.5b5-3, then the NO WIFI unlock for iOS 4.0 that can be search all over the net!
The Following 17 Users Say Thank You to yobb For This Useful Post:
Old 09-25-2010, 08:50   #2 (permalink)
Member: 65039
Thanks Meter: 13
Hot water is exist long time ago, but you late.
In present time this solution is not working for 3g, 3gs lower than 4,1.
Regards,
Old 09-25-2010, 11:00   #3 (permalink)
yobb's Avatar
Member: 337450
Thanks Meter: 707
Regards,
Ok, have you try? Ill try and post if it really not work...
Old 09-25-2010, 11:26   #4 (permalink)
babalsingh's Avatar
Member: 1024766
Sonork: GSM MASTERS
Thanks Meter: 229
ya its work but who save shsh blobs on saurik server...
Old 09-25-2010, 12:21   #5 (permalink)
Member: 65039
Thanks Meter: 13
You can check on saurik server.
You can save shsh blobs only for 4.1 ver....
Old 10-06-2010, 09:34   #6 (permalink)
Member: 962855
thank you very much i just tried and it works but your explanation is some weird, you can just tell to add the IP to host. thank you very much
Old 10-06-2010, 09:58   #7 (permalink)
KINK's Avatar
Member: 2200
Thanks Meter: 266
any solution for error 3002?
Old 10-06-2010, 10:04   #8 (permalink)
Member: 644210
Thanks Meter: 73
iphone 3g is always be supported by that solution...
but what we need is the solution for 3gs and iphone 4... can't downgrade even with modified host and tinyumbrella.. nay new solution?>
Old 10-07-2010, 03:26   #9 (permalink)
Member: 108951
Thanks Meter: 26
wwwwwwaaaaaaaaaaaaaaaaaaswwwwwwwwwwwwwww its succed with me...
i was can't restore Iphone 3gs to any firmware...n thank u yobb u help me its work now
The Following User Says Thank You to omarfilali For This Useful Post:
Old 10-09-2010, 09:26   #10 (permalink)
Member: 121185
Thanks toYobb
Solution works 3gs 401
Old 10-09-2010, 10:16   #11 (permalink)
Member: 173946
Sonork: 100.1585498
Thanks Meter: 32
Thanks for good information.......
Old 10-09-2010, 10:28   #12 (permalink)
https's Avatar
Member: 1263932
Thanks Meter: 181
Contains many wrong and correct information.
You can downgrade 3G phones always, no need for shsh, but just not through iTunes; you need to use redsn0w. iTunes since 9.2 checks for correct shsh (not the 3G), so you can circumvent this check by not using iTunes.
Remember that this does NOT work for 3GS; 3GS phones will check shsh to install firmware, so you need shsh backup on Cydia to downgrade.
For both you cannot downgrade baseband to unlock; we're talking about jailbreak only.
Error 3002 means you pressed Update instead of Restore button.
Old 10-09-2010, 10:34   #13 (permalink)
Member: 220736
Thanks Meter: 83
i will try and report................
Old 10-09-2010, 11:25   #14 (permalink)
Member: 994459
Thanks Meter: 11
this method is working 3g 100%
thanks sir this method is working done
Old 10-12-2010, 03:55   #15 (permalink)
VODAFONES's Avatar
Member: 747968
Sonork: 100.1621353
Thanks Meter: 443
[IMG]http://1.bp.********.com/_jzFOOHRsqBM/TJ2QotEE5VI/AAAAAAAAAxk/hd6_5peYQrQ/s400/error+3194+1.png[/IMG]
[IMG]http://1.bp.********.com/_jzFOOHRsqBM/TJ2SEinAbBI/AAAAAAAAAxo/V4wUmPhR4g4/s400/error+2.png[/IMG]
[IMG]http://1.bp.********.com/_jzFOOHRsqBM/TJ2TBCEjxxI/AAAAAAAAAxw/QQ2H5OFms6A/s320/error5.png[/IMG]
[IMG]http://1.bp.********.com/_jzFOOHRsqBM/TJ2Tv1moPnI/AAAAAAAAAx0/e0VXq0H35gQ/s320/error6.png[/IMG]
its work !! thanks bosss
The Following User Says Thank You to VODAFONES For This Useful Post:
where to find a working program all they have some errors ?? fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 12-12-2012 12:26
My 5110 v5.11 have a strange error.., it resets it self every 60second luuk Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 24 08-11-2006 15:29
HEX for CLIP to restore Factory Defaults X-Shadow Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 02-28-2000 14:59
The multiple errors of Winlock ... ??? Genata Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 09-20-1999 19:12
error (1002) simlock3.dll winopen fondas Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 08-28-1999 15:57
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2014 -
Page generated in 0.46462 seconds with 8 queries
Content Relevant URLs by vBSEO
