Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > iPhone ,iPod & iPad (Apple Inc. Products) > iPhone 2 / 3G / 3GS
Old 04-06-2009, 10:14   #1 (permalink)
kissssna's Avatar
Member: 810694
Thanks Meter: 30
iphone error 1611 any solution
while restoring my iphone itunes give an error 1611 any solution its automatically shuts off and stucks at recovery mode and if cable is removed it doesnot power on or shuts off if cable removed
Old 04-06-2009, 22:00   #2 (permalink)
lotfi17's Avatar
Member: 2616
Thanks Meter: 6
error 1611
Enter DFU mode manually and resart restoring
DFU mode: turn off iphone, hold HOME and POWER together in exactly 10 sec then release POWER and keep holding HOME until you hear windows warning for new hardware connected then release HOME, the phone must be black display means you are in DFU mode, otherwise with itunes logo means your phone is in Restore. Note: start you pc clock and count exactly 10 sec HOME+POWER .
The Following User Says Thank You to lotfi17 For This Useful Post:
Old 02-17-2010, 11:50   #3 (permalink)
andyvikas's Avatar
Member: 449069
Thanks Meter: 57
I Tried It in DFU mode too, But Still i am Getting This Error 1611, How to make it???
Old 02-17-2010, 12:45   #4 (permalink)
andyvikas's Avatar
Member: 449069
Thanks Meter: 57
iBoot-596.24
It is stuck on Recovery mode
Model A1203
Fcc ID: BCGA1203
SERIAL NUMBER :88815QQNOKH
16GB.
With iTunes it is giving 1611 error & cannot Proceed...
Please Guide how to make it.
Old 02-17-2010, 16:17   #5 (permalink)
Member: 164316
Thanks Meter: 6
ya, me too.. need solution.. stuck in recovery mode. iphone 3G 8gb... Restore always give error 1611.
Old 02-17-2010, 16:44   #6 (permalink)
ZoHaiB_(FoneGSM)'s Avatar
Member: 82666
Sonork: 100.108210
Thanks Meter: 283
update with 3.1.3 all Solved
Old 02-17-2010, 18:19   #7 (permalink)
Member: 164316
Thanks Meter: 6
tried
Tried but no success, any more solution ?
Old 02-17-2010, 19:38   #8 (permalink)
kissssna's Avatar
Member: 810694
Thanks Meter: 30
hey every one its hardware i have solvedddddddd it
Old 02-18-2010, 06:56   #9 (permalink)
andyvikas's Avatar
Member: 449069
Thanks Meter: 57
Hi Thats Sounds Really Great..
Please Share How did You make It!!
Thanks in Advance
Old 04-01-2010, 16:05   #10 (permalink)
Member: 94822
Thanks Meter: 3
Iphone error 1611
Hi brothers how r you brother it's hardware solution first change the battery & restore
if ur problem not solved change the charging cable after that restore again & ur problem will b solved
Old 04-01-2010, 16:14   #11 (permalink)
kissssna's Avatar
Member: 810694
Thanks Meter: 30
its not battery or charging cable problem its just a power brick
if battery is ok than no need to replace
Old 04-03-2010, 22:30   #12 (permalink)
Member: 764493
Thanks Meter: 25
care to share the solution?
Old 04-04-2010, 02:29   #13 (permalink)
Member: 1190954
Sonork: 100.1591671
Thanks Meter: 10
Originally Posted by andyvikas View Post
iBoot-596.24
Model A1203
Fcc ID: BCGA1203
16GB.
If your phones has problem with HW, pls check ROM ( serial flash ).
Old 04-04-2010, 20:48   #14 (permalink)
malikraghav's Avatar
Member: 649955
Sonork: 100.1615287
Thanks Meter: 99
Hello friends today i was found iphone error 1611 with very easy way but i test only on 3G not on 3GS and i am very happy
Old 04-05-2010, 15:35   #15 (permalink)
Member: 101228
change the battry it will 100% solve the problem
The Following User Says Thank You to fauzan_7866 For This Useful Post:
iphone 3g on "headset mode"?any solution jasimbinrashid iPhone 2 / 3G / 3GS 0 11-02-2009 10:13
iphone 3g on "headset mode"?any solution jasimbinrashid iPhone 2 / 3G / 3GS 0 11-02-2009 10:08
8100 DEVICE ERROR 394 Any Solution mbcommunication BlackBerry (RIM) 0 04-04-2009 20:27
Powered by Searchlight © 2015 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2015 DragonByte Technologies Ltd.
- GSM Hosting Ltd. - 1999-2015 -
Page generated in 0.47224 seconds with 8 queries
Content Relevant URLs by vBSEO
